"Cold air" calibrated mass air meter? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 10-02-2011, 12:43 AM Thread Starter
uneedav8's Avatar
Wink "Cold air" calibrated mass air meter?
I see all the mass air meters come in "regular" or "cold air" calibrated. Is this just dependent whether you are running a factory air box as opposed to having a conical air filter clamped on? Or is this depending on whether or not there is any bends in front of the mass air meter? I have a K&N FIPK? Which one should I get? Cold air or regular? Thanks.
uneedav8 is offline
post #2 of 10 Old 10-02-2011, 04:17 AM
frankstang's Avatar
Trader Feedback: (115)
Tell the MAF manufacturer what air intake setup you have and they'll tell you which one you need.
If you're buying used, the cold air meters are usually calibrated for a bend before the meter. Be aware that some cold air meters originally came with a screen to straighten the airflow. These are rarely included with used meters. Running without one could cause problems.
frankstang is offline
post #3 of 10 Old 10-02-2011, 07:09 PM
ARCANGL's Avatar
Trader Feedback: (76)
what MAF are you looking at?
the stock one is fine... i doubt you are outflowing it.
if you are 90mm LMAF
ARCANGL is offline
post #4 of 10 Old 10-02-2011, 10:32 PM Thread Starter
uneedav8's Avatar
My car is 2K GT. I bolted on an intake and 75 throttle body. I have the stock mass air which I am told is 80mm. It does not feel like it is getting enough air to the engine now. I know many don't think the intake and TB is a good idea for an N\A car. I did read every 4.6 test I could find on throttle body and intake upgrades and realize there is a loss of torque and hp on the bottom end. At the same time I realize there needs to be a funneling effect, I know the size ratio of the mass air to throttle body matters.
uneedav8 is offline
post #5 of 10 Old 10-02-2011, 11:48 PM
ARCANGL's Avatar
im not against tb/plenum combo's on mild bolt-on cars... but adding a MAF wont help a thing. The stock 80mm will support even a cam swap.
but if you must, get a 90mm Lightning MAF...
ARCANGL is offline
post #6 of 10 Old 10-03-2011, 07:40 AM
KanuckiStang's Avatar
How are you making this judgment? Are you logging MAF readings? Got dyno charts and AFRs?
Log MAF readings while out beating up on the car. That will tell you if you need to upgrade. If the MAF is not saturating -- i.e. reaching it's maximum output voltage before the engine has reached its maximum air flow demand -- it's not really a restriction. Hell, even if the MAF is saturating, it's essentially an 80mm (3.15") diameter open tube. How much pressure drop do you think is occurring over its length?
I doubt a N/A, bolt-on GT is reaching the flow limits of an 80mm MAF.
2002 MGT | Kenne Bell 1.7 @ 9psi | 3.73s | Comp 262AH | Bullitt suspension | Bullitt front brakes | FRPP UCAs | Steeda catback | Innovate WB AFR | Autometer boost
2010 Subaru WRX STi STP/DGM | Cobb Stg 2
2014 CBR500R
KanuckiStang is offline
post #7 of 10 Old 10-03-2011, 08:04 AM
ARCANGL's Avatar
^^ agreed, i shoulda thought about telling him to datalog MAF ad counts
ARCANGL is offline
post #8 of 10 Old 10-03-2011, 11:01 AM
Was the car tuned previously ?
93GRNLX is offline
post #9 of 10 Old 10-03-2011, 10:39 PM Thread Starter
uneedav8's Avatar
No, the car has never been tuned. I guess I am finding a way to regain some of the loss of torque and hp on the bottom end. Besides a power adder, I guess the answer sounds like keep it stock.
uneedav8 is offline
post #10 of 10 Old 10-04-2011, 09:45 AM
Doing a tune on the car will help add some of the low end torque back to it but also get the best out of the added air flow from the other parts you have changed , the stock MAF is fine until you are using a blower or turbo
93GRNLX is offline
