Pinion gear is STUCK!!! What do I do? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 06-28-2002, 08:33 AM Thread Starter
Exclamation Pinion gear is STUCK!!! What do I do?
I am in the middle of a 4.10 gear install on my '00 GT and I can't get the pinion gear out. I have removed the differential, removed the pinion nut, and pulled the pinion flange but the gear wont come out!
This is the only thing the article I'm using for instructions says about taking it out: The pinion should fall loose from the front bearing, but if it doesn’t, a little “persuasion” with a hammer will do the trick. I have tried A LOT of persuasion with a two pound sledge and I can't get it to shake loose.
I want to go to the track tomorrow but if I can't get this damn thing out I don't know what I'm going to do. Anyone have any ideas?
~Mike~
kwkcpe is offline
post #2 of 10 Old 06-28-2002, 10:52 AM
Whack that sum***** HARD about 5 times with that 2lb sledge and it will come off. The problem is the small pinion bearing is basically pressed onto the pinion gear when you tighten down the pinion nut. You will need to hit it pretty hard to get it to come off.
James
The Internet's 1st Mustang Enthusiasts Club
IslandVobra is offline
post #3 of 10 Old 06-28-2002, 11:42 AM
BTLFED's Avatar
Like James said whack the funk out of it. I would also put the pinion nut on the pinion so you dont damage the threads of the pinion. A messed up nut is better than fubar'd threads.
BTLFED is offline
post #4 of 10 Old 06-28-2002, 11:52 AM
Freakboy4.6's Avatar
I have a 2000GT and we had to hammer the crap outta that thing to get it out. We hammered it so hard, in fact, that we ended up mashing the end.
Oh well, I'll never need it.
2000 GT:
PTK Street Dominator turbo kit w/GT40 head unit, C4 tranny, 8-point cage, stock engine, other little stuff:
1/8 mile best: 6.87 @ 100.7 mph 1.53 60' 11.5#'s boost.
Freakboy4.6 is offline
post #5 of 10 Old 06-28-2002, 12:00 PM
Stuck gears
I had the same problem heat them with a torch, then use a heavy mallet.
2001 GT Convert.
2001topless is offline
post #6 of 10 Old 06-28-2002, 12:18 PM
If you access to air tools hit it with a air chisel, the rapid vibes can remove it easier and safer than heavy blows with a hammer.
Dwayne
96 GTS SVO Blown and 2 many bolt on's to list.
Got Vibes? read this
Show me a loser (Shannan Wheeler)..........and I will show you a Liar and a Thief.
46GTSblown is offline
post #7 of 10 Old 06-28-2002, 12:46 PM Thread Starter
Good deal. I had never been in the rear of a car newer than '89 until now, I was hoping there wasn't something I was missing.
Those are some good ideas. I pretty much did the best I could with the hammer last night. /confirmed rather loudly by my wife who HAD been in bed asleep... I said "oops, at least I didn't wake the baby" I always try to find the good in a situation /
I guess when I get home I'll try one more time with the hammer, but if that doesn't work I guess I'll go to my Dad's to borrow an air hammer.
I don't have (or have ready access to) a torch so I hope I don't have to have heat.
Thanks for the replies guys!
~Mike~
kwkcpe is offline
post #8 of 10 Old 06-28-2002, 01:21 PM
96gts4.6L's Avatar
Same exact thing happened to me, and I ended up not being able to get the pinion back in once I had gotten it out. I guess that's what Ford service is for.
~Kris
1996 GTS/248A
NPI heads (stock), Naturally Aspirated, 153K+ miles, weight w/ driver - 3080 lbs.
Houston Raceway 02/05/06 (959 Density Altitude):
13.447 @ 99.75, 60' - 1.810
8.597 @ 80.94, best 1/4 mph 101.69
Founding member of
- Budget Drag Racer's Association
96gts4.6L is offline
post #9 of 10 Old 07-01-2002, 11:25 AM Thread Starter
I thought I would let you guys know how it turned out.
The air hammer didn't make any difference. I got a bigger 3lb sledge and beat on it until my arm gave out. I called my dad and he came over with a "ladys foot" pry bar. I was able to hook the back of the gear with the bar and pull some tension on it while my dad whacked it some more.
This FINALLY worked but we had to grind the mushroom off the threaded part of the pinion gear so it would fit through the bearing.
After I pulled the pinion seal (I ruined it with the hammer) and got the front bearing out, I found out why is was so hard to get out. The inside of the bearing that slips on the pinion gear had rust on it. I guess somehow water got in there and formed a bond of rust between the pieces.
BTW the 4.10 kicks all forms of a$$!!! Best mod so far!
~Mike~
kwkcpe is offline
post #10 of 10 Old 07-01-2002, 02:53 PM
~Mike~
Mine had the same rust on it and it was a mother to get out. We put the pinion nut back on to keep from destroying the pinion threads, but we had to use the same BFH
Bullitt 2936
87LXHatch is offline
