Trouble Code of P0320 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 11-18-2009, 11:40 PM Thread Starter
stanglvr808's Avatar
Car is acting really dumb. It will start then die. It started earlier today and I drove home from work, in traffic, it died when I pulled into the garage. Checked the trouble codes and came up with one, P0320 Ignition/Dist Engine Speed Input Circuit Malfunction. Anyone have any experience with this code and where I should start looking to correct it? This car has been a three month project and I just got it running. HELP!!
stanglvr808 is offline
post #2 of 9 Old 11-18-2009, 11:53 PM
RazorbackMustang's Avatar
I'm going to guess a crankshaft position sensor malfunction. The cam position sensor has its own code, so it wouldn't be my first guess.
Lucas
2011 Mustang GT
2013 Fusion Titanium
RazorbackMustang is offline
post #3 of 9 Old 11-19-2009, 12:39 AM
Chrm97PI's Avatar
well post info on car/setup/electronics would be help for starters
Chrm97PI is offline
post #4 of 9 Old 11-19-2009, 03:49 AM Thread Starter
Sorry about that. Car is a stock 96 Mustang GT w/auto trans. The motor was replaced with a stock 97 GT motor. Only mod to the car is an UPR o/r xpipe with mil eliminators. Replacement motor has 67xxx miles on it. Car was just finished and back on the road.
post #5 of 9 Old 11-25-2009, 06:18 PM
Well hell, didn't know it was a NPI car. That code obviously still applies though. You're having an ignition coil problem with #5. Swap the coil packs, reset the codes, see if the code comes back and/or the letter in the code changes.
Lucas
2011 Mustang GT
post #6 of 9 Old 11-25-2009, 08:44 PM
nyuk98gt's Avatar
stanglvr808:
IAC? The "starts OK but dies immediately" is a classic symptom of a faulty IAC valve.
You can try cleaning the IAC (many, many threads here on the topic) but you are better off buying an OEM Ford/Motorcraft IAC valve (i.e.--not an aftermarket part).
HTH,
Chris
2012 GT RTR 6MT; performance white / charcoal
* 3.73's, FRPP ProCal tune, MGW Gen3 shifter, FR GT500 Touring axlebacks, BMR LCAs, Steeda Panhard bar & brace, JLT PCV catchcan
nyuk98gt is offline
post #7 of 9 Old 11-26-2009, 10:05 AM
Chrm97PI's Avatar
Originally Posted by nyuk98gt View Post
stanglvr808:
HTH,
Chris
if thats the case it will run if you keep your foot slightly on the gas..?
just a fyi, the pinpoint test has 64 tests in it for this code and this code can be set from numerous different sources. does it run rough or anything like that
Chrm97PI is offline
post #8 of 9 Old 11-26-2009, 08:30 PM
nyuk98gt's Avatar
Chrm97PI:
Yes, Sir, the engine will run if you just crack the throttle. It is tricky to keep it alive and the quick solution (sometimes doesn't work) is to clean the IAC valve.
Hope you're not snowed in up there on Thanksgiving.
Chris
nyuk98gt is offline
post #9 of 9 Old 11-27-2009, 12:33 AM
Chrm97PI's Avatar
what snow? and yes, clean or replace the iac and that should fix the code
Chrm97PI is offline
