"Service Engine Soon" light just lit up on my '99 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 11-09-2009, 09:07 PM Thread Starter
"Service Engine Soon" light just lit up on my '99. EDIT: Got code "P0172"
EDIT: "P0172" Bank 1 Rich came out
What's goin on with my car? I just got this car recently. Passed smog & did a Mobil-1 oil change less than a month ago. 72,xxx on the odometer right now. Car runs great as I just got 290 miles out of my last fill up. It drives the same as it always has, just the light came on all of a sudden. I don't really beat on the car, just cruising most of the time. Only thing I did different was put in some 7eleven gas yesterday. I usually run Chevron or Shell. Service light came on this morning Any suggestions/opinions would be appreciated
'89 Coupe-Kurgan Tuned 498/491RW, Vortech Si, 351W, & Ice Cold AC
STREETFIGHTER50 is offline
post #2 of 14 Old 11-09-2009, 09:29 PM
badass03gt's Avatar
02 sensor failure possibly?? could be several things but its prob something related to that.
17 inch Deep dish mach ones, Powerslot rotors, Hawk pads, , 15% tint all around.Mods gone starting over sucks!!!!!
badass03gt is offline
post #3 of 14 Old 11-09-2009, 09:45 PM
go to autozone and get the code pulled on it.
1sxyfox is offline
post #4 of 14 Old 11-09-2009, 10:02 PM
Hiwaystar's Avatar
Loose gas cap will throw a code.
Tropic Green Y2K GT
P-1SC, MM Stuff (393rwhp/390rwtq)
Hiwaystar is offline
post #5 of 14 Old 11-09-2009, 10:03 PM
84_rustang_gt's Avatar
dpfe is pretty common.. or egr valve pressure sensor as some call it
adderall and xanax combined say that i am paying attention but i do not care
84_rustang_gt is offline
post #6 of 14 Old 11-09-2009, 11:54 PM Thread Starter
gas cap is tight. what is "dpfe"?
post #7 of 14 Old 11-10-2009, 12:19 AM
idk the meaning!! but it is the egr pressure sensor.. has two vaccume hoses running to it from the egr tube. the tent to get clogged. replaced many of them on 99 and up fords.. they consist of a egr below threshold, or system lean bank 1 and 2 codes....
post #8 of 14 Old 11-10-2009, 09:44 AM
Do this before you do anything else. It's all just wild speculation until you know what the the codes are.
1996 GT Deep Forest Green 5 Speed Coupe
PI cams & Intake | Steeda Timing Adjuster | O/R H-Pipe | S197 Mufflers | Pro 5.0 Shifter & FRPP Knob | S197 Seats | Wing Delete | '98 Cupholder Console Conversion
patman0322 is offline
post #9 of 14 Old 11-10-2009, 02:24 PM
Exactly! It could be many things...
2001 Black GT, 5 Speed, K&N,
SLP LM II's, New OEM Lights, Continental ExtremeContact, 03-04 Cobra bumper and hood.
Yea basically a stock ride but she still runs and looks great!
Jeff Dude is offline
post #10 of 14 Old 11-10-2009, 06:53 PM
+1000000000 have autozone or someone pull the code, its free.
99 mustang gt: 5.4l 4v. 405rwhp/385ftlbs 93 pump gas.
ceracer33 is offline
post #11 of 14 Old 11-14-2009, 07:04 PM Thread Starter
Code "P0172 System too rich (bank 1)" came up when I tested the car twice. Key on engine off & engine running. Is this most likely oxygen sensors? Which would be bank 1?
post #12 of 14 Old 06-03-2010, 02:28 PM
2002 GT with same issue
My autozone analysis was "bank 1 and 2 too lean. Store clerk said probably Mass Air Sensor. Car runs fine and no performance loss. Plan to clean MAS or replace.
mustangdoug is offline
post #13 of 14 Old 06-09-2010, 04:15 PM
Found the problem, hose running to valve cover vent had a cut on the underside causing vacuum leak. Bought $1.50 piece of hose and fixed it. Removed the battery cable which reset the light to off. Check all vacuum lines.
post #14 of 14 Old 06-09-2010, 10:11 PM
A vacuum hose will not cause a rich condition. It would cause a lean one. Without seeing the fuel trims I would guess you have an O2 sensor issue.
BTW a DPFE is a Differential Pressure Feedback for Egr. Basically it measure how much EGR gas is entering the engine.
Flrob76 is offline
