P0155, P1151 trouble codes - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Modular Tech Forums > GT & SOHC
Old 07-13-2009, 08:51 PM   #1
Red2002gt's Avatar
Hey guys, i have these codes, happened shortly after CAI, TB, and Plenum install
P0155.... says o2 heater circuit, bank 2, sensor 1
P1151.... says lack of Ho2s21 switches...sensor indicates lean
do i just need a tune or is it is a o2 sensor
thanx in advance
__________________
Originally Posted by dba-murder View Post
If you even dream of messing with Texas you better wake up and apologize.
Red2002gt is offline
Old 07-13-2009, 10:45 PM   #2
Red2002gt's Avatar
anyone, please help a poor noob
__________________
Old 07-13-2009, 11:50 PM   #3
Chrm97PI's Avatar
probably a sensor, but make sure its plugged in first
Chrm97PI is offline
Old 07-14-2009, 08:11 AM   #4
iflyjets's Avatar
Check the pins on any plug that you unplugged.
It may be just a bent pin.
__________________
2001 GT 5.4 DOHC
1998 Cobra with a Procharger
iflyjets is offline
Old 07-14-2009, 09:38 AM   #5
Zinc01's Avatar
Trader Feedback: (18)
The second code indicates that the o2 sensor is not working. As mentioned above check for a disconnected harness or bent pin. The next step would be replacing the oxygen sensor.
FYI, I had the same code. Visually checked everything and then replaced the oxygen sensor. Still had the same damn code. I pulled the transmission/o2 harness, but couldn't find the short. Every time I checked the wires, they showed continuity. I ended up buying an o2/transmission harness on ebay for $20. No more problems after that. Just something to keep in mind, if all else fails.
__________________
Forged Teksid 2v, Patriot Stage 3 heads/stock cams, KB 2.8H, 1 3/4" Kooks longtubes, 3" x-pipe, 3" 1 chambers dumped. 3.73 gears,PA Manual VB 4R70W w/ brake, Circle D's converter, Lowered 1.5" on 17x8 & 17x10.5 Bullitts. Kaenen 4.5" cowl hood, much more
Zinc01 is offline
Old 07-27-2009, 09:10 PM   #6
Red2002gt's Avatar
thanks guys, will replace o2 sensor
__________________
Old 07-28-2009, 06:41 AM   #7
I had that problem one time and it was the 02 heater fuse in the box under the hood.
__________________
R Lovejoy
01 GT Daily Driven N/A With Automatic.
SCT PRO RACER TUNNING< the best move I ever made
11.96 @ 112.89
rlovejoy is offline
Old 07-28-2009, 08:17 AM   #8
huesmann's Avatar
Why would an O2 sensor go bad after a CAI, TB, plenum install?
huesmann is offline
Old 07-28-2009, 08:42 AM   #9
2k2GT's Avatar
Because it says MUSTANG and/or FORD on the vehicle.
2k2GT is online now
Old 07-28-2009, 01:07 PM   #10
i am gettin the p1151 also but mine comes and goes for some reason anyone got any ideas for that? i was thinkin that it could be one of the pins bent like ya'll said but wasn't sure, any input before i check?
1sxyfox is offline
Old 07-29-2009, 08:29 AM   #11
huesmann's Avatar
LOL Tony.
huesmann is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
