Are E3 Plugs really worth it?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 05-16-2009, 07:55 PM Thread Starter
Bmeagher's Avatar
Did anyone try these out yets with any results?
Or is it too good to be true?
2003' Mach 1
Fastest N/A Time 12.2@112.34mph, with bigs and littles 332rwhp/312tq
Bmeagher is offline
post #2 of 20 Old 10-11-2009, 10:18 AM
I installed a set in my wifes Mazda 6 and her mpg went from between 22.5-23.5 to 25-26 on every tank since then. She had the factory platinums that still looked good, so were happy with them. Wish they'd make them for the 05 up cars.
grey06 is offline
post #3 of 20 Old 10-11-2009, 01:39 PM
but not for a ford.
just as a 40 mpg or even the so called 11mpg mustang..
it is all a pile of lies.....
I have gone down the road that you are only now about to travel.
tires are the great equalizer
a degree wheel, EIGHT INCH dial caliper & adjustable pushrods should be just as normal as a 1/2" wrench in your toolbox
there aint no shortcuts to doing it RIGHT....
Kato Engineering is offline
post #4 of 20 Old 11-01-2009, 09:16 PM
Really like the post...love it....
jerseymike68 is offline
post #5 of 20 Old 11-15-2009, 05:29 PM
icemetalstang's Avatar
I have a stock 95 gt 5.0. I put the e3 plugs in. The car missed fired and even through an engine check light on. Car was running fine before. Not worth the money. I will not ever use these plugs or recommend them. They may work on an older carb setup like there web video.
icemetalstang is offline
post #6 of 20 Old 11-15-2009, 07:44 PM
john98's Avatar
wow thats not good. ive never had any experience with e3 plugs, but i can say the bosch platinum 2 are nice. i just put them in a few weeks ago to replace some fouled motorcrafts and ive been pleased. BTW the stig is the man!
89 GT
john98 is offline
post #7 of 20 Old 11-18-2009, 12:14 AM
Put them in my 02 Silverado z-71 and went from 16.5-17.5 to 15-15.5 mpg. They are coming back out this weekend.
abrrymnvette is offline
post #8 of 20 Old 11-18-2009, 01:51 AM
El_Diablo's Avatar
meh, side gapped denso iridiums in the camaro, autolites in the jeep and side gapped autolites will be in the mustang when its done
as most, bosche plugs are complete ####, depends somewhat on what you put them in but generally ####... wondering if some of the e3 issues are due to old wires being used?
El_Diablo is offline
post #9 of 20 Old 11-29-2009, 02:56 PM
Jax Rhapsody's Avatar
Could be, theya rent like regular spark plugs, they arent like Bosch 4's either. I'd say picking from E3's or Bosch 2-4's I'd pick the upper. Those Bosch don't discarge from every prong, just one out of the 2-4. I wouldn't run them on a low reving engine, judging by the responses, they are obviously a real hot plug. although they have them for just about every car, they are probably a tad hotter than OEM and other replacements. High reving engines should like them.
It's da Jax!
en.wikipedia.org/wiki/Ford_Fox_platform
Jax Rhapsody is offline
post #10 of 20 Old 04-20-2011, 04:24 AM
AshleesMach1's Avatar
I have them in my 92 GT and I love them
1969 Mach1 360.3/411@ flywheel
1992 GT 230.15/292.12@Rear Wheels SOLD gone BYBY
2003 GT Sold Gone BY BY
2010 GT AUTO ???
AshleesMach1 is offline
post #11 of 20 Old 04-20-2011, 12:52 PM
gonemad's Avatar
NGK V-power...nuff said....e-3 = smoke and mirrors......you cant reinvent the wheel any platinum for performance is not optimal, the iridiums are sweet but $6-$15 a plug ...
88 stock bottom end coupe. On3 70mm trick flow 170s home ported explorer intake with c4 on 14lbs 10.02@134.
04 CO lots of bolt ons 11.97@114 n/a, 10.89@125 with 150 shot.
gonemad is offline
post #12 of 20 Old 04-20-2011, 03:43 PM
Apocolipse's Avatar
I run the v-power as well. Copper spark FTW. Sure it does not last as long but at $2 a plug who cares. Plus boosted apps hate hot sparks.
Apocolipse is offline
post #13 of 20 Old 05-28-2011, 11:29 AM
john98's Avatar
to update and correct my previous post. That boschs are turds, they were fine for a few months but then started running like hell when I pulled them one of the straps on everyone was trashed, went the some motorcraft platinums and haven't had a problem since. I wouldn't recommend anything with more than one prong for the 2V motors
89 GT
john98 is offline
post #14 of 20 Old 06-02-2011, 10:00 PM
87ttop_stang's Avatar
Hey guys!
I joined this forums years ago but i've never posted anything, I figure it's time to break my silence.
I'm running the E3 plugs in my 87 GT and love them. The throttle is a bit more responsive, and the mileage improved about 1-2 mpg.
I'm actually on my second set. My car developed a real bad stutter/hesitation about a month or so ago. It turned out the MAP sensor kicked the bucket. At the same time, I replaced my first set of E3s. After one year and about 15,000+, the gap had not changed and the electrode was not noticeably worn. I could have cleaned them and put them right back in, but I opted to put new E3's in.
They work great for me.
87ttop_stang is offline
post #15 of 20 Old 06-05-2011, 06:08 AM
NarleyCarley's Avatar
Originally Posted by 87ttop_stang View Post
Hey guys!
What's your actual MPG? what mods have you done to car? what's your timing set at?
2017 Jeep Wrangler JKU
2006 Chevy Silverado Z71
1992 LX Coupe
NarleyCarley is offline
post #16 of 20 Old 06-05-2011, 07:56 AM
I do about 70-80% Highway driving daily (with tons of stop & go) and average between 20-23 mpg.
During a road trip to Minnesota last summer, I got upwards of 26 mpg, and that was while doing 65-80mph on a moderately hilly route with the tops out and loaded with a week's worth of luggage.
My timing is bumped to *14 and I run premium.
Mods:
- MAC fenderwell CAI
- Professional Products 70MM Throttle body & EGR Spacer
- MSD Digital 6 Ignition and Blaster TFI Coil
- Dyna-module distributor module
- 9MM Ford Racing Wires and E3.42 plugs
- BBK shorties, Bassani catted-X, Delta 40s w/tails
- Flex-a-lite Black Magic radiator fan
- March Pulleys
- Ford racing 3.73
- MM Full length sfc, K-member & Strut tower braces
- Nitrogen in the tires* (Made a big difference)
Alex
87 GT, Tons of bolt-ons but she is still slow
post #17 of 20 Old 08-02-2011, 07:43 PM
ive never tried the e3's in my car, but great for mowers, and bosch is what i run in the 90 stang platinums, tryed the 4's once for about a week and put the singles back in. ive never had a problem with them!!
harodavid is offline
post #18 of 20 Old 08-26-2011, 04:20 PM
Trader Feedback: (21)
My brother tried one in his YZ125. At about 8000 rpm about 3.5 miles back in the woods from the cabin, the ground strap came off and wreaked havoc on the piston. He was more pissed about pushing the bike 3.5 miles, through the woods, than the $75 it cost for a new piston and ring.
droopie is offline
post #19 of 20 Old 09-09-2011, 03:54 PM
TomV's Avatar
Thumbs up
I've recently put E3.40's in my boat. It's got a 1986 carb'd 4.3L V6 Mercuiser and has never idled or rev'd so smoothly.
Girlfriends old 1999 Honda Prelude also ran like a champ with the E3's, but I didn't notice any difference in my lawn mower
I may try them in my Stang after my current NGK-FR5's need changing, but I'll have to find out which of the two in their cross reference would be best for my TW heads (E3.48 or E3.64) first.
1989 Mustang GT
TomV is offline
post #20 of 20 Old 11-10-2011, 02:48 PM
I have E3.70's in my 06 truck. only reason is because they were the cheapest single piece plug available ($100 for 8 vs $200 for 8). I broke 6 of 8 of the original 2 piece plugs taking them out and vowed never to deal with that again so one piece it was.
had them in for 5k miles now and same mileage as before. I'm fine with them.
stackz88 is offline
