87-88 Thunderbird turbo coupe 4 lug to 5 lug conversion - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 03-23-2007, 09:05 AM Thread Starter
BlownSkillet's Avatar
Anybdy know what axles will fit in an 87-88 Turbo Coupe rear to convert it to 5 lugs?
88 Saleen Conv. #368
78 Fairmont Wagon
02 ZX3 Turbo Focus
93 GT
BlownSkillet is offline
post #2 of 7 Old 03-23-2007, 09:07 AM
SN-95 stang or ranger should fit. Just make sure it's the right legnth for the rear. Is this going into the T/c or a stang?
84 Fila is offline
post #3 of 7 Old 03-23-2007, 09:24 AM Thread Starter
The rear is actually in a Fairmont. I know the ranger axles will work in the 83-86 DRUM brake rears but not sure about the length for the DISC brake rears.
78 Fairmont Wagon
02 ZX3 Turbo Focus
93 GT
post #4 of 7 Old 03-23-2007, 09:35 AM
I'll have to check for you, but I'm assuming that SN-95 stang with disk should work. The Tbird axal is of speical lengith, 3/4" "wider" then a stang, and 3/4" shorter then a Mark 7 rear.
84 Fila is offline
post #5 of 7 Old 03-23-2007, 09:35 AM
The TC axles are the same length as the 94-98 SN95 axles. Ranger axles will not work with the stock TC disc brackets mounted in the stock locations. You can redrill the rotors for the 5 lugs. I do recall seeing a thread on this where someone mentioned that there is a 5 lug rotor that might fit, but I don't recall exactly the specs.
Thomas
87 LX 5.0 bought 3/31/87, 306,000+ miles original stock motor former daily driver. Now waiting on a new motor
GT spoiler, Mark VII disc w/Ranger axles & working ebrake, 3.73 Turbocoupe rear, 95 spindles, Cobra brakes & Bullitt wheels. Black interior with 2002 front & rear seats.
trbkrb is offline
post #6 of 7 Old 03-23-2007, 09:38 AM
Not quite right. The Mark VII axle is 1.25" longer than a Fox axle, meaning it is 1/2" longer than a TC and 94-98 SN95 axle.
Thomas
trbkrb is offline
post #7 of 7 Old 03-23-2007, 10:43 AM
Ahh, sorry. I'm used to having Tbird info. I can swap 5lug into a bird and get it to line up but not sure about a farmont.
84 Fila is offline
