3.08 to 3.73 gear ET average improvement - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 09-14-2006, 03:10 PM Thread Starter
Satan Jamez's Avatar
Trader Feedback: (23)
Question 3.08 to 3.73 gear ET average improvement
On avearge how much has this gear swap improved 1/4 mile times on a stock 5-speed car?
Cervini 2.5" cowl, Pro 5.0/Hurst shifter, exhaust goodies, 3.73, full length subs, Eibach drag launch kit w/air bags, 31-spline diff, MT ET streets, stage III ported windsor jr's, stealth intake, Jay allen custom cam, 670 street avenger, 297rwhp/293rwtq
BobBarry.net
Satan Jamez is offline
post #2 of 18 Old 09-15-2006, 07:49 AM
I don’t know the answer to your question but I do know this, you will defiantly notice a difference, a kick in the ass for sure, when I went from 2.73 to 3.73 I could not believe the improvement, the only thing I would have done different was going with 4.10 instead of the 3.73
92LX 4 cyl conversion
86 302,svo gt40 heads with 1.6 rockers,e cam,mac long tubes and cat back, B&M blower,670 holley, elec pump, mallory BTM dizzy and msd coil, 3.73 gears, up&lower arms with drag springs & bag, drive loop, pro 5.0 shifter, elec fan, 195 stat, bfg radials
surfsup is offline
post #3 of 18 Old 09-16-2006, 02:50 PM
ajbwmn's Avatar
WHat is the benifit of 4.10 over 3.73???
ajbwmn is offline
post #4 of 18 Old 09-16-2006, 07:19 PM
you have to add traction too, dragradials and 410,s or 373 ,you can expect to drop around 1 second off
89llx is offline
post #5 of 18 Old 09-16-2006, 07:49 PM Thread Starter
Question
What about on street tires though? maybe .3.... or so?
BobBarry.net
post #6 of 18 Old 09-16-2006, 08:13 PM
How do you have 3.08's on a stock 5-speed? I thought only Auto's came with the 3.08 gear and the 5-speeds came with 2.73's.
1992 Mustang GT
Stock 302 Short block, AFR 165cc heads w/ 55cc chambers, Ed Curtis cam .566 Lift ; 218*/ 224*, RPM II Intake, 1.6 Scorpion roller rockers, BBK 70mm TB, Anderson N/A powerpipe, 24lb injectors, 80mm PMAS MAFS, BBK Long tubes, O/R X-pipe, 2-chamber flowmasters, 3.73 gears, and a custom tune by DynoTuneMotorsports in Columbus, Ohio
310.7 RWHP
316.9 RWTQ
Jormungand is offline
post #7 of 18 Old 09-17-2006, 12:55 AM
rdub79's Avatar
Trader Feedback: (80)
My 88 lx coupe has 3.27's in it from the factory and a friend of mine has a 92 lx coupe 5.0 5 speed with 3.08's.
88' Coupe
rdub79 is offline
post #8 of 18 Old 09-18-2006, 12:13 AM
I own a 93 LX 5.0 5 speed ex Florida Highway Patrol car that came with 3.08s. I
changed to 3.73s and rebuilt the posi traction unit just last week. My only regret is that I didn't do this sooner. This is the biggest difference I've noticed with a single mod. The acceleration is just insane now.
jprichard is offline
post #9 of 18 Old 09-18-2006, 08:56 AM Thread Starter
Thumbs up
That's what I want to hear!!
BobBarry.net
post #10 of 18 Old 09-18-2006, 08:48 PM
MurPHy4570's Avatar
2.73s were the standard gear for all V8 8.8" Mustangs 86-95 or so.
3.08s were optional for T-5s.
3.27s were optional for AODs.
If you use stock size street tires (225/60R15), you will have absolutely NO traction in the first couple gears if you really hammer it.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
post #11 of 18 Old 09-19-2006, 12:14 AM
Murphy is on the money with the tire thing. My car is quickly digesting my BFG Sports with the 3.73s. I guess this is a good excuse for bigger better tires.
post #12 of 18 Old 09-19-2006, 03:16 PM
I went from 2.73's to 3.73's, 31 spline axles, cobra FRP posi, net: absolutely no traction unless I left the line at idle. Great swap but gears only won't get it. Plan on upper and lower control arms and sticky tires when you do your budget, get all that done then hang on tight because you are ready for flight.
fox_bodies_forever is offline
post #13 of 18 Old 09-19-2006, 08:43 PM
ej95cobra's Avatar
I dropped 0.4 after going from the stock 3:08's to 3:73's. That was one of the first mods I did when motor was still basically stock.
95 Rio Red Cobra. #2647 of 4005. 331; KB supercharged; meth injected
"Under my cap and trade policies, energy costs will necessarily skyrocket." Barack Obama, January 8, 2008.
ej95cobra is offline
post #14 of 18 Old 09-21-2006, 02:37 PM Thread Starter
I did the swap to 3.73. I see why this is usually a first on the things to do list. Very nice!
BobBarry.net
post #15 of 18 Old 09-21-2006, 03:41 PM
flavadave4's Avatar
I picked up .4 going to 3.73's on street tires.....I could definatly gain more if i could hook up. I am still cutting 2.2 60's so i could see with slicks and some practice you could get close to 1 second.
flavadave4 is offline
post #16 of 18 Old 01-29-2007, 05:01 PM
quartermilerocket's Avatar
ttt.............On my particular application I was thinking about 3-4 tenths too, but my question would be as of right now I'm cutting consistent mid-high 1.80 60ft times.
I'm pretty sure I would gain 1 tenth or so in 60ft by going with the 3.73's, does that sound about right?.
And also would that gain of 3-4 tenths be included with the anticipated 1 tenth drop in 60ft times, or would I gain even more than the 3-4 tenths overall?
Peace
James
90' ssp coupe, stock CI unported E7's, full mac exhaust, water pump/crank pullies, synthetic fluids, 14* of timing, 65 mm t/b, power pipe, 80mm maf, 4.10 gear, welds, skinnies plus suspension **best of 12.41@106.58 on 26/8.5/15 M/T et drags with a best 60' of 1.59 with 260 rwhp and 320 rwtq.
quartermilerocket is offline
post #17 of 18 Old 01-30-2007, 09:34 AM
brian15's Avatar
i went from 3.08's to 3.73's and gained 4 tenths , the car didnt 60ft any differently ..... but thats because it just worked good wiuth the 3.08's .
i think my best 60ft with 3.08's was a 1.80 and with 3.73's was a 1.78 or so .
brian15 is offline
post #18 of 18 Old 01-30-2007, 10:00 AM
Right now I'm on M/T et street radials and on an excellent track I can launch at 5,500 and it won't spin (although I haven't tried launching off of the limiter yet), and on a bad track I have to lower it to between 3500-4500.
My question is, on your application did you use your same launch rpm's when you went to 3.73's or did you have to drastically lower your launch rpm?, and also what tires were you using when you had 3.08's and 3.73's?.
