Heater Control won't switch off of Defrost??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 07-16-2006, 10:06 PM Thread Starter
I have a 94 mustang and the blower is stuck on the defrost setting. You can turn the knob to vent and it stays on the defroster. It gets cold with the air on but won't blow out the vents. Has anyone ever had this problem? How do I go about fixing it?
TPhillips is offline
post #2 of 9 Old 07-16-2006, 10:44 PM
PaulMan's Avatar
vacuum line along fire wall in engine compartment could be shot. Do a search on this one - you can fix this one easily - good luck
'90 LX 5.0 - HPDE Car
24 Hrs. of Lemons/Chump Car Series - Grim Reaper Racing '94 Mustang V6
PaulMan is offline
post #3 of 9 Old 07-16-2006, 10:47 PM Thread Starter
What do you think the best words to use in a search are, I tried doing a couple searches with no luck.
post #4 of 9 Old 07-17-2006, 09:05 AM Thread Starter
I found a post about the vaccum tree under the hood around the firewall and heater core possibly being broke or a cracked line. Any other places to look?
post #5 of 9 Old 07-17-2006, 09:41 AM
Puter's Avatar
I don't know about those SN94 models, but here is the Fox. I did a search on "defrost". Took all of 17 seconds to come up with this post.
http://corral.net/forums/showthread....hlight=defrost
84 GT and 85 GT convertible - http://community.webshots.com/user/puter_pics
carbedMustang Mailing List Owner - http://autos.groups.yahoo.com/group/carbedMustang/
Puter is offline
post #6 of 9 Old 07-17-2006, 01:04 PM
PaulMan's Avatar
That's the one I was thinking of too. DEFROST would be the keyword to use
PaulMan is offline
post #7 of 9 Old 07-17-2006, 02:12 PM
u can also make sure your vacuum canister is not busted check on the underhood id plate (where your engine&year is found) for a vacuum schematic
bonz is offline
post #8 of 9 Old 07-17-2006, 05:05 PM
gfthomas's Avatar
hey man, I JUST had this same exact problem... Paul is exactly right, it's the vaccuum hose right along the firewall... it probably broke. It's a pretty thin hose, you should see it connect to a box on the driver's side... look for where it broke, and i used electrical tape. Works fine!!
gfthomas is offline
post #9 of 9 Old 07-19-2006, 06:40 PM
Heh, Great thread , Mine broke today i guess, i was like, why wont it turn off defrost damit..
Thanks, Gt Thomas, what kinda car you got? im from CC also . i drive a yellow 95 gt
LaNgStA is offline
