Coolant Refilled, now Upper Radiator hose hard? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-02-2006, 12:08 AM Thread Starter
Quick question about my upper radiator hose.... I drained my coolant to install a new intake, TB, etc etc, and refilled my coolant. I turned the car on and let it run without the radiator cap on, and turned the heater on and let it warm up to temp before topping it off one more time, burping the hose, and the topping off the overflow bottle when it got to temperature.
I took it out for a spin tonight and when i got back, i popped the hood to check on things. the upper radiator hose is hard, to the point where i cant squeeze the hose to feel if water is rushing past the hose. Also, the overflow bottle is below the "COLD" line.
BTW i have a new thermostat (180 deg) new water pump, fan clutch, and 2 core aluminum radiator. Also the car is not overheating and the laser thermoter says its at the correct temp. The thermostat is installed correctly too.
What could be causing the upper hose to be hard, and the overflow bottle to not be filling up to the FULL HOT line??? Could i have a giant air pocket in the systtem still? anything malfunctioning? Should i remove the radiator cap and reburp the system?
Thanks!
BlueCobraClone is offline
post #2 of 7 Old 07-02-2006, 12:16 AM
Trader Feedback: (30)
Cooling system pressure, thats why the hose is hard. If the hose was hotter then hell, it's working fine.
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #3 of 7 Old 07-02-2006, 12:26 AM
Bart99GT's Avatar
Its perfectly normal to have to add a little more water after driving the car around for a bit. Air manages to get trapped in places that only bumps or shakes will dislodge. One thing you can do to help minimize air pockets forming is to jack up the front end of the car a little. Putting the car at an angle gets the radiator filler neck just so slightly higher than the block and helps the air escape. I do this with my vehicles and find I have to add very little water after driving the car around.
1986 1D SVO - SOLD
2007 Mazda3 Hatchback 2.3L beater
1999 Jeep Wrangler 4.0L Sport
SVOCA #528
Bart99GT is offline
post #4 of 7 Old 07-02-2006, 05:04 AM
Visable-assassin's Avatar
I had a 180* stat in my 91GT once you run the car the upper hose should be hard and hot...you are fine. also if your bottle is at the "cold" mark after getting the system good and "hot" add coolant (i did) and i was fine.
New ride
2003 Azure Blue Terminated Mach 1
1991 Mustang GT - totaled due to some jerks negligence 6-18-06
2004 Lightning - Totaled due to a jerk running a red light 10-2-13
Visable-assassin is offline
post #5 of 7 Old 07-02-2006, 11:26 PM Thread Starter
Should i be worried that before i was able to squeeze and compress the upper hose while the car was running, but now i'm not? Also, should i take the radiator cap off when i jack the car up, as mentioned below?
I'll top off the coolant to the FULL HOT mark after the car is up to temp as mentioned below, and hope it all goes well.
Thanks for the help!
1992 Mustang Cobra Clone
Trick Flow Track Heat Intake, 70 mm TB, 24 lb injectors with matching MAF, UD pulleys, BBK Cold Air kit, 3.55 rear, Baer 5 lug conversion, Shorty headers, Flowmaster Cat back, MSD ignition box
post #6 of 7 Old 07-03-2006, 08:32 AM
Bart99GT's Avatar
Yes, remove the radiator cap when you jack up the front end. I fill my radiator that way.
Bart99GT is offline
post #7 of 7 Old 07-03-2006, 11:30 AM Thread Starter
Thanks for the replies everyone! I just had another thought of why the coolant might not be recirculating, you guys can tell me if i'm completely wrong or not...
When i swapped intakes, i disconnected both lines from the heater core to give me more room to move the heater tube. If they were reconnected backwards, would it cause the system to do this? It seems almost like the radiator upper hose is full of coolant, but the pump isnt moving it out of the radiator to the engine (i.e. something is blocking the flow).
Thanks again!
