horn not working - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > General Mustang Tech
Old 06-26-2006, 05:36 PM   #1
arnold22's Avatar
horn not working
I'm having a problem finding out why my horn isn't working. I've check/changed the 20A fuse and listen for the clicking of the horn relay under the dash but still no horn. I went and got a new horn and tried changing each horn and replaced it with the new one and still no progress. I even tried it on it's own. Do you need to have two horn in order for it to work? Also does the bracket which holds the stock horn acts as a ground?
thanks,
Kristopher
__________________
1989 Mustang hatchback GT
2 line and 100 characters for your signature! What can i write with that?
arnold22 is offline
Old 06-27-2006, 12:41 AM   #2
arnold22's Avatar
The fuse seems to blow if i push the horn button to many times one after another but is ok is i only push it one? What could be the cause if this?
thanks,
Kris
__________________
arnold22 is offline
Old 06-27-2006, 01:41 AM   #3
Trader Feedback: (34)
At the relay, what do you read while pressing the horn button? You should have three 12 volt terminals and one ground, it seems to me.
Good luck.
HISSIN50 is offline
Old 06-28-2006, 04:18 PM   #4
arnold22's Avatar
At the relay it reads 12 volts when I press the button so that works fine. I fix the problem with the fuses blowing when pushing the horn button to many one after each other. The problem was the cigarette light which I just disconnected since i don't use it.
I still don't have to horns working and I got a second new horn. The stock horn much be working since I don't get anything honking with the two new once. Anyone have any other ideas?
I don't know if cruise control would affect the horn in any way.
thanks,
Kristopher
__________________
arnold22 is offline
Old 06-28-2006, 04:36 PM   #5
arnold22's Avatar
update:
The wire which goes from the relay to the horn seems to be fine. I get current from one end to the other. I'm starting to think the realy itself may not be working properly any longer. Could that be the problem?
thanks,
Kristopher
__________________
arnold22 is offline
Old 06-28-2006, 04:38 PM   #6
Where on the relay do you have 12v? The LB/W wire is always hot. You need 12v on the DB wire when you push the button for the horns to work. If you have 12v on the DB wire then the problem is the in the wiring from the relay to the horns or the horns themselves.
Saleen0679 is offline
Old 06-28-2006, 05:25 PM   #7
Saleen is a whiz with this stuff and can get you fixed.
As an aside, check inside the cig lighter receptacle for change (not a new perspective in life, but coins). That will cause a short.
Good luck.
HISSIN50 is offline
Old 06-28-2006, 05:26 PM   #8
arnold22's Avatar
i tested every option with the relay when pushing the horn button and here is what i got:
LB/W & DB = 12v
LB/ & Y/LG = 12v
Y/LG & DB = 0v
I disconnected the cigarette light so now it doesn't work and won't affect the fuse/circut and I got two new horn yesterday. Do you need to have two horn in order for it to work?
thanks,
Kristopher
__________________
arnold22 is offline
Old 06-28-2006, 05:32 PM   #9
You must be using a meter between the wires. You need to take the readings while referencing a ground not between the different wires.
Old 06-28-2006, 06:33 PM   #10
arnold22's Avatar
what's a good spot to use as ground inside the car near the horn relay?
thanks,
Kristopher
__________________
arnold22 is offline
Old 06-28-2006, 07:22 PM   #11
Since your readings aren't that critical you should be able to grab just about anything metal. Try one of the braces under the dash area.
Old 07-01-2006, 12:55 PM   #12
arnold22's Avatar
I figured out the problem with the horn issue. The wire from the relay to the horns had a short in it, i forgot the ground one of the horns and one of the two horn wasn't working.
thanks for all the help Saleen0679
Kristopher
__________________
arnold22 is offline
Old 07-01-2006, 07:29 PM   #13
Quite welcome. Glad you got it all figured out.
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
