Can you resurface a clutch pressure plate? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > General Mustang Tech
Old 10-01-2005, 12:10 AM   #1
sukkoi18's Avatar
Trader Feedback: (22)
Like it says, is this possible. My clutch has very few miles on it, but Ive definitly put some heat to it and am curious if it is possible to resurface the pressure plate. Thanks.
__________________
~Performance White 2013 GT M6
sukkoi18 is offline
Old 10-01-2005, 01:51 AM   #2
machine head's Avatar
Not that I know of. You can do the Flywheel.
__________________
2012 MUSTANG GT LAVA RED PREMIUM
12.52@114 BONE STOCK in 5th gear on 245/45/19 stock tires
www.SPEED-NEEDS.com MOTORCYCLE LOWERING STRAPS
machine head is offline
Old 10-01-2005, 02:26 PM   #3
radimm's Avatar
If you turn or grind material from pressure plate surface the clamping force on the clutch disc would be affected so answer to your question is NO.
__________________
B&G , 6037s&5.0 intake, BA 2400, M2300K, Strange 3.73, Gforce T5
radimm is offline
Old 10-01-2005, 03:38 PM   #4
svoman2300's Avatar
I had a similar problem recently. I took a nylon pad that you put on a drill or air grinder and just took the glaze off. I don't know if it hurt it or did any good, but my clutch is working just fine.
svoman2300 is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
