1993 Cobra differences vs 1993 GT/LX? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 03-31-2002, 11:46 PM Thread Starter
What separates a 93 Cobra from it's GT/LX 5.0 brethren? What else besides the exterior, GT 40 heads, and Cobra Intake?
Purchasing a 93 Cobra tomorrow morning and just wanted some more info. Thanks!
AFJsvt is offline
post #2 of 17 Old 03-31-2002, 11:51 PM
Price Tag!
Typical bowtie eater!
lpmorgan is offline
post #3 of 17 Old 03-31-2002, 11:52 PM
HAWK327's Avatar
roller rockers,24# injectors....
90'lx hatch, 2950# w/me, Girdled/studded 347,Scat 9000 crank,4340 scat I beams,SRP pistons, SFI 28 oz dampner,11.1cr, Vic jr heads, probe shaft rockers,BIG custom solid Roller,Comp hi-tec roller lifters,Vic jr intake,830cfm holley HP carb, edelbrock gear drive, 1 3/4-1 7/8 kooks LT's w 3"X pipe, CSI electric WP, Pro shifted G-force 5 speed,auburn pro w/31 spline mosers,4.30 gears..and so on.
HAWK327 is offline
post #4 of 17 Old 03-31-2002, 11:56 PM
The computer is specific for a cobra and everyone on here says to stay away from it when changing computers, why I don't know.
lpmorgan is offline
post #5 of 17 Old 04-01-2002, 12:01 AM
Stang_On_Spray's Avatar
Trader Feedback: (-1)
The computer is different also
Stang_On_Spray is offline
post #6 of 17 Old 04-01-2002, 12:12 AM
Trader Feedback: (18)
specific part numbers
This is the different parts on a cobra. I know it is a long list but I put it together and it was too easy to cut and paste it. The obvious cobra differences are, it has rear discs, different fascias (side and rear), an opening in the grille with running horse, 7 fin turnstlye wheels and no cruise. it also has a D in the vin engine code position instead of an E. the list below is all the different parts that are not on a GT or LX 5.0 only on the cobra.
1993 Cobra Specific Parts
Part Number Description
Exterior Parts
F3ZZ-1007-A Right wheel (standard cobra model)
F3ZZ-1007-B Left wheel (standard cobra model)
F3ZZ-1130-A Center cap
F3PZ-8190-A Front bumper cover
F3ZZ-17D996-A Insulator, bumper reinforcement, front
F3ZZ-16A162-A Extension, fender, front, right
F3ZZ-16A163-A Extension, fender, front, left
F3ZZ-16228-A Cobra fender emblem
F3ZZ-8200-A Panel, grille insert
F3ZZ-8200-B Panel, grille insert, red
F3ZZ-8200-C Panel, grille insert, teal
F3ZZ-8200-D Panel, grille insert, ebony
F3ZZ-8201-A Retainer, grille
F3ZZ-8213-A Ornament, grille, running horse
F3ZZ-8A224-A Medallion grille
F3ZZ-17K835-A Rear bumper cover
F3ZZ-17D942-A Reinforcement, bumper cover, rear right
F3ZZ-17D943-A Reinforcement, bumper cover, rear left
F3ZZ-6110176-A Molding, fender, front right
F3ZZ-6110177-A Molding, fender, front left
F3ZZ-6129426-A Molding, rocker panel, right
F3ZZ-6129427-A Molding, rocker panel, left
F3ZZ-6110182-A Retainer, molding, rocker panel, upper
F3ZZ-6110184-A Retainer, molding, rocker panel, lower
F3ZZ-6110214-A Retainer, molding, rocker panel, middle
E9ZZ-6120938-CIA Molding, door, right, ebony
F3ZZ-6120938-BAE Molding, door, right, red
F3ZZ-6120938-BAR Molding, door, right, teal
E9ZZ-6120939-CIA Molding, door, left, ebony
F3ZZ-6120939-BAE Molding, door, left, red
F3ZZ-6120939-BAR Molding, door, left, teal
F3ZZ-6340110-A Door, luggage compartment
F3ZZ-6144210-A Spoiler assembly, rear
378-4445 Hardware, rear spoiler mounting
45335-536 Hardware, rear spoiler mounting
F3ZZ-6142528-A Nameplate, Cobra, liftgate
E8FZ-5842528-C Emblem, Ford oval, liftgate
F3ZZ-13404-H Right tail lamp assembly
F3ZZ-13405-H Left tail lamp assembly
E5ZZ-13450-B Right tail lamp lens
E5ZZ-13451-B Left tail lamp lens
Accessory Drive Parts
F3ZZ-8509-A Cobra Water pump pulley
F3ZZ-6A312-A Crankshaft pulley
F3ZZ-8620-A Accessory drive belt
Exhaust System Parts
F3ZZ-5230-A Muffler and Tailpipe, right
F3ZZ-5230-B Muffler and Tailpipe, left
Cylinder Head Related Parts
E6AZ-6582-B Rocker cover, left
F1SZ-6582-A Rocker cover, right
F3ZZ-6049-A Cylinder heads, bare up to 4/13/93 (1)
F4ZZ-6049-A Cylinder heads, bare after 4/13/93
F3ZZ-6049-B Cylinder heads, w/valves up to 4/13/93(1)
F4ZZ-6049-B Cylinder heads, w/valves after 4/13/93
F3ZZ-6026-A Plug, core sand cleanout
F3ZZ-6507-A Valve, intake
F3ZZ-6505-B Valve, exhaust
F3ZZ-6513-A Spring, intake valve
F3ZZ-6513-B Spring, exhaust valve
F3ZZ-6A536-A Retainer, valve spring
F3ZZ-6079-D Gasket set, valve grinding
F3ZZ-6564-A Rocker arm
F3ZZ-6A585-A Fulcrum, rocker arm pedestal
F3ZZ-6A527-A Bolt, rocker arm attaching
1. includes date specified
EFI System Parts
F3ZZ-12A650- CA Computer
F1SZ-12B579-A Sensor, Mass Airflow
F3ZZ-9E926-B Throttle Body
F3ZZ-9E433-A Gasket, throttle body to EGR plate
F1TZ-9F593-C Fuel injector
Intake System Parts
F3ZZ-9424-C Upper intake manifold
F3ZZ-9424-D Lower intake manifold
F3ZZ-9E434-A Upper manifold nameplate
F2TZ-9H486-B Gasket, upper manifold
F3TZ-9439-D Gasket, lower manifold
F3ZZ-6A664-A PCV hose
F3ZZ-6759-A PCV tube
E2SC-9C491-BB Vacuum tree
T-5 Transmission/Clutch Parts
F3ZZ-8620-A Shaft, input
F3ZZ-7025-A Bearing, input shaft
F3ZZ-7030-A Snap ring
F3ZZ-7061-A Shaft, output
F3ZZ-7563-A Clutch Pressure plate
F3ZZ-7550-A Clutch Disc
Suspension Parts
Front
E5ZZ-5310-J Coil spring, front
D2FZ-6445592-A Spacer, spring
F3ZZ-18124-A Strut, front
F3ZZ-5482-A Bar, stabilizer, front
Rear
D9BZ-5560-M Coil spring, rear
F3ZZ-18125-A Shock, rear
Brake Parts
Front
F3ZZ-2140-A Master cylinder
F3ZZ-1102-A Front rotor
F3ZZ-2001-A Front pad set
Front calipers
E4LY-2B120-A Front caliper, right **
E4LY-2B121-A Front caliper, left **
**Dealerships do not show a different part number for the front calipers on the 93 cobra. I have talked to Ford Technicians and they say there is a mistake in the databasing. I personally have worked on the front brakes of the cobra and the calipers are the 73mm Lincoln version that came on the 1984-1986 SVO 4 cylinder turbo. The part numbers listed are specifically for the SVO, but will bolt right up to any 87-93 V8 mustang and are factory replacements for the 1993 cobra.
Rear
F3ZZ-2C026-A Rear rotor
F3ZZ-2200-A Rear pad set
E25Y-2C028-A Rear dust shield
F3ZZ-2552-A Rear caliper, right
F3ZZ-2553-A Rear caliper, left
F3ZZ-2C276-A Support, rotor adapter bracket, right
F3ZZ-2C278-A Support, rotor adapter bracket, left
F3ZZ-2C100-A Rotor adapter, right
F3ZZ-2C101-A Rotor adapter, left
N602 726-5190 Bolt, splash shield
N805 163-5190 Bolt, caliper attaching
383 6089-5Z Hardware package
F3ZZ-2A635-A Cable, parking brake right
F3ZZ-2A635-B Cable, parking brake left
E7ZZ-2A603-A Cable, parking brake w/equalizer assembly
F3ZZ-2530-A Bracket, parking brake cable, right
D9ZZ-2860-A Clip, parking brake
Interior Parts
F3ZZ-14588-A Radio wiring harness
F29Z-11572-D Ignition switch
F3ZZ-6113076-AAG Gray floor mat
F3ZZ-6113086-AAH Black floor mat
Goodson is offline
post #7 of 17 Old 04-01-2002, 12:25 AM
Chads93GT's Avatar
Cobras had 4 cyl springs in the back
4cyl struts
smaller rear sway bar
and everything else listed above
Chad
I'd rather be on rope in a deep deep pit cave.
Chads93GT is offline
post #8 of 17 Old 04-01-2002, 12:39 AM
SVO LOU's Avatar
Nice list Goodson.
Thanks for posting.
Lou.
4 wheels move the body, 2 wheels move the soul...
SVO LOU is offline
post #9 of 17 Old 04-01-2002, 12:47 AM
Originally posted by SVO LOU
Nice list Goodson.
Thanks for posting.
Lou.
Thanks.. I noticed that I don't have the front brake part numbers for the 73 mm calipers. I will "edit" after I leave work tonight and get home. Actually I was wrong, some of the door side molding pieces are the same as 93 GT's and the taillight "housings" (the lenses are obviously different than the GT's and similar to the SVO's on the cobra). The door moldings are the same only in the colors Ebony and Red.
Goodson is offline
post #10 of 17 Old 04-01-2002, 05:30 AM
M1fast87's Avatar
The computor has a less agresive timing curve than the A9L computor found in 5 speed 89 up Mustangs
M1fast87 is offline
post #11 of 17 Old 04-01-2002, 09:19 AM
Goodson,
The 93 Cobra R's had rear discs, not the regular 93 Cobras.
[list]
White 91 GT
[size=1]TFS TW Heads w/ TFS 1.7rr, E-303, Cobra Intake, MSD Distributor, MSD-6AL & MSD Coil, 65mm Throttle body, Pro-M 75mm Mass Air, pullies, JBA ceramic coated 1 5/8" Unequal shorties, off-road h-pipe, 2 chamber Flows, Centerforce DF, 3.55s, JMS Chip, Nitto 555Rs, etc...291rwhp, 311 ft/lbs
fast_wht91gt is offline
post #12 of 17 Old 04-01-2002, 09:49 AM
SVO LOU's Avatar
Goodson,
Don't worry about the 73mm calipers, they're not stock. Up front
The 93 Cobra calipers are the same size as a GT/LX, 65mm I think?
fast_wht91gt,
Also, all Cobras had rear disc brakes. 93 Cobra R's had the 94-brakes(5-lug, rear disc, front 13" PBR calipers).
SVO LOU is offline
post #13 of 17 Old 04-01-2002, 12:53 PM
Originally posted by fast_wht91gt
Goodson,
The regular cobras did have rear disc brakes as SVO LOU said, and they were the same rear as the 4 lug T-bird turbo coupe rear but, without the exciter rings for ABS, and the cobra having mustang quad shock mounting. they are .75" wider on each side. That is why the 93 cobra has different front rotors to put the wheels in line. The hat part of the rotor is approximately .75" taller than a regular GT or LX. I know because I put them on my car.
Goodson,
I thought the same until I worked on one, and MM&FF stated them having the 73mm calipers. They are 73 mm with phenolic pistons. The pistons are shaped to accept the same front brake pads as the GT and LX. Even the guys at Ford were like... "Something ain't right here!" Stock GT and LX are 66 mm on 87-93's.
www.almost4.com
Goodson is offline
post #14 of 17 Old 04-01-2002, 02:57 PM
jrgoffin's Avatar
I think you also missed the F3ZE-6250-A cam, unless I went through the list too fast. The list is cool - same stuff in Al Kirshenbaums book, just on the one page!
2003 Silver Metallic Cobra:
Custom Ford thermostats:
www.termi-stat.com
jrgoffin is offline
post #15 of 17 Old 04-01-2002, 03:03 PM
dont foget the T5Z trans
1989 LX 5.0 Hatch
1991 Toyota MR2 NA (daily driver, autox, trackday car)
Texas89LX is offline
post #16 of 17 Old 04-01-2002, 03:11 PM
yep!! I sure did.... thanks I am adding stuff to the list as a go along. I got most of the part numbers from Al Kirschenbaum's book, but there were some things that he did not list.
Goodson is offline
post #17 of 17 Old 05-31-2014, 07:26 PM
Trader Feedback: (200)
I can't believe I found this about 93 Cobras and the last post is in 2002.
Well, it's 12 years later and I have a question.
Is there a Part Number on the 3rd Brake Light Lens? OR
Is the 3rd Brake Light Lens the same as those on the Mustang GT with the "Free Air" Spoiler?
Please PM me the answer if anyone has it.
Thank You!
Jon
89 Vert. 5.0 5Sp. Burgandy, Black Top, Black Interior. SOLD
92 GT Vert. 5.0 AOD White, Black Top, Black Interior.
92 Coupe. 4 Banger 5 Speed. White, Black Interior.
93 Coupe. DECIDING Calypso Green, Black Interior.
94 GT Convertible 5.0 5 Sp. Red Black/Gray Interior.
95 GT Coupe 5.0 5 Sp. Red, Black Interior.
Jon Evenoff is online now
