Fuel pressure gauge install - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-24-2005, 03:39 PM Thread Starter
Carguy929's Avatar
How and where do I install my fuel pressure gauge? I have the Aeromotive pressure regulator mounted right by the fuel rail on the passenger side. Do I have to put it on te fuel rail? I am not sure and I have no instructions. I know this is probally a stupid question, but I am new at this and I don't want to ^&$ it up. Thanks
89 Sonic Blue Notch all caged up! DSS 306 N/A with the usual goodies
Griggs&MM susp. 5-lug conv.
Under construction looking for a little psi
Carguy929 is offline
post #2 of 9 Old 08-24-2005, 03:50 PM
buddha's Avatar
I think that Aeromotive has a port for a FP gauge, but you would have to run a braided line to use it because there isnt' anywhere to go with it. Just buy a gauge with the correct fitting for the shrader valve in the fuel line. It's a simple process removing the needle in the line and screwing in the fitting for the gauge.
Red 93' Cobra with a cogged NOVI 2k, R331
Black 93' Cobra with a Flowzilla 2.2 Kenne Bell
buddha is offline
post #3 of 9 Old 08-24-2005, 03:57 PM Thread Starter
Carguy929's Avatar
I just went out to my garage and looked at it. There seems to be a port at the bottom of the f/p/r. I believe I can tap into it like strkd347 has his in the post the pic of ur engine thread. I have a 45 and a straight fitting that I think will work. Take a look and let me know what you think. Thanks for the input.
post #4 of 9 Old 08-24-2005, 03:59 PM
i used a liquid filled gage and pipe fittings on my aeromotive fpr. its a lot easier to see than down on the fuel rail.
91 GT
carbed 351
importsmokinGT is offline
post #5 of 9 Old 08-24-2005, 04:03 PM
buddha's Avatar
If you can make it work, by all means do it. Just put in a place were you can easily read it. To make the shrader valve setup work, you'll need a 90 to make it work...otherwise it's tilted down making it hard to read.
buddha is offline
post #6 of 9 Old 08-24-2005, 10:42 PM
polter83's Avatar
Yea, just wear some goggles or something when you do this.
polter83 is offline
post #7 of 9 Old 09-03-2005, 08:51 PM Thread Starter
Carguy929's Avatar
I am looking to install my f/p/g tonight, but I have a couple questions. #1 if I install it off the S/V do I pull the pin out of it? If I do and after the pressure is relieved will it stop leaking or will I have to put a catch can below it? #2 Is it strong enough to support the gauge or do I need to make a bracket to support it? #3 my Aeromotive f/p/r has a port under the vaccum, is that a port for a f/p/g or is it for something else? I got the car after it was installed so I do not have the book for it. #4 If nobody knows about the port, should I plug in the gauge and see if it works? Whats the worst thing that could happen???? Thanks for the help as usual guys!
post #8 of 9 Old 09-04-2005, 11:02 AM
buddha's Avatar
If you install it on the fuel line, yes you will have to pull the needle out. It comes out just like a valve stem needle. You won't need anything special to hold it on, besides the fitting that screws in. Once the pressure bleeds down you won't have gas pouring out all over the place.
Again, you can use the port for the gauge, it's just a matter of getting the right fittings for it.
buddha is offline
post #9 of 9 Old 09-05-2005, 04:50 PM Thread Starter
Carguy929's Avatar
Thanks a lot! Very easy, kind of a pita place to put it but it works!
