Vacuum line hookup on Typhoon intake - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > General Mustang Tech
Old 08-07-2005, 10:51 PM   #1
I am installing a Typhoon intake ( almost identical to Edlebrock) on a 1990 5.0 Mustang. Vacuum line hookup is completely different from stock intake. I also run a ZEX dry nitrous kit which uses vacuum lines hooked onto the fuel pressure regulator and the stock " T" connector which is located under the upper plenum. I just wanted to know if anyone knows of the proper vacuum line hookup and proper hookup for the lines used by the nitrous kit.
Gmoney5.0Mustang is offline
Old 08-08-2005, 03:24 PM   #2
erikz451's Avatar
theres no one way to do it...
as long as everything is hooked back into the intake youll be fine..
the one underneath the upper for the pcv, then the ones close to throttle body for everything else, a couple of T's, the the tree, to the fpr, etc...
erikz451 is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
