how much tranny fluid will a t5 hold - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 07-04-2005, 01:12 PM Thread Starter
REDLINE RACING's Avatar
i drained my fluid out of my t5 to change it the tranny is still in the car how many quarts does this t5 hold its a 95 gt if that makes a difference
REDLINE RACING is offline
post #2 of 10 Old 07-04-2005, 02:29 PM
Rich92GT's Avatar
Trader Feedback: (22)
Fill it with 2 1/2 quarts.If you use more than that you'll blow the seals in the tranny from the extra pressure.
1992 Mustang GT...Finally finished
Staff Sergeant of Marines
C Co. 1st Bn 25th Marines
Rich92GT is offline
post #3 of 10 Old 07-04-2005, 09:15 PM
Mustang5L5's Avatar
Pressure??? There's no pressure inside a T-5. The fluid just sits at the bottom the gears slosh around in it.
The T-5 takes 2.8 quarts.
Mike
--1988 Mustang LX 5.0--
--2014 Ford Taurus Limited--
Mustang5L5 is offline
post #4 of 10 Old 07-04-2005, 11:26 PM
Chads93GT's Avatar
You can always unskrew the fill plug in the side of the trans and fill it until it spills out, which is the correct way to fill it up. there is a bottom drain plug and a top plug as well, stacked on top of each other. They are unskrewed with a 1/2 inch socket wrench,w ith no socket.
But what he said. its approximately 2.8 quarts.
I'd rather be on rope in a deep deep pit cave.
Chads93GT is offline
post #5 of 10 Old 07-05-2005, 06:34 AM
Trader Feedback: (35)
You very well could be correct, but my memory is telling me it is a 3/8" ratchet wrench square which fits.
HISSIN50 is offline
post #6 of 10 Old 07-05-2005, 09:21 AM
It's 3/8", not 1/2".
FoxChassis is offline
post #7 of 10 Old 07-05-2005, 02:35 PM
Rich92GT's Avatar
When I ordered my G-Force from Tony at Astro he said not to go over 2 1/2 quarts because the pressure from the added fluid would blow the seals...I figure he knows his stuff so that's what I was going by.
Not trying to give bum info...Just passing along what I was told.
Rich92GT is offline
post #8 of 10 Old 07-05-2005, 03:01 PM
hmmm I wonder what that pressure relief on top of the tranny does..
speeddemon40 is offline
post #9 of 10 Old 07-05-2005, 04:55 PM
Some manual trannies have vents (like your axle does), but it without a pump and a huge amount of air in the box, I dont see how one can get pressure.
If one fills the trans level too much, leakage out dynamic seals can be an issue, but that is about it.
HISSIN50 is offline
post #10 of 10 Old 07-05-2005, 06:03 PM
Rich92GT's Avatar
Maybe that's what he meant....He said something about pressure and if it is overfilled the seals will blow.
Thanks for the clarification.
-Rich
Rich92GT is offline
