Tremec TKO vs. T-56 Transmission - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-05-2005, 02:08 PM Thread Starter
TKO vs. T56
What are the pros and cons of each transmission? Both seem to be rated at 600 ft. lbs., so why buy the T56 over the TKO? Are there any other transmissions out there to look at?
TKO - "Tremec claims that prototypes have been successfully drag tested at 600 lb-ft engine torque."
T56 - "650 lb-ft Torque Capacity"
TomballGuy05 is offline
post #2 of 8 Old 02-05-2005, 02:19 PM
well if im correct isnt the T56 a 6 speed transmission otherwise they are both pretty good transmissions just depending on what gear ratios you want between the TKO 500 and 600 i believe they have different gear ratios to choose when buying..
adrenaline is offline
post #3 of 8 Old 02-05-2005, 02:55 PM
jnfsu's Avatar
Yes, the T-56 is a 6-speed transmission. The Viper T-56 has a .50 overdrive 6th gear, so you can run a 4.11 (4.10 in my 9" differential) drag racing gear (or higher) if you'd like and still be able to cruise on the highway at low rpms.
Here's a handy calculator that, by default, uses the Viper gears: http://www.geocities.com/z_design_st...ion_z28_6.html
1983 GT;410 Windsor;AFR225;Comp Cams HR "Cheater" cam (.546,236/240,109);Vic Jr intake;Holley 750HP vac sec;MSD ign./dist;Holley black fp;AJE K-mem;Kooks 1-7/8" stainless headers;Dr Gas 3.5"-2.5" x-pipe;Magnaflow 2.5" muffs/pipes;Spec 10.5" alum flywheel/Stage 3 clutch;Tremec T56 Viper 6-spd; alum driveshaft; 9" rear;4:11 gears;Auburn Pro diff;H&R Super Sport springs;Koni red struts/shocks;Steeda dbl adj upper/lower arms. 466 rwhp@5750 rpm,464rwtq@4750 rpm on a Mustang dyno,over 400 rwtq from 2400-6100 rpms.
jnfsu is offline
post #4 of 8 Old 02-05-2005, 03:40 PM
BlackDrop50's Avatar
If you have money, go with the T-56
I hardly ever use the 5th gear in my TKO, but I don't drive on the freeway much. Do you want/need the 6th gear?
'88 Triple Black LX 5.0 Vert - daily driver
'90 Black LX Hatch - all forged 347 Stroker, AFR 185s, RPM II intake, Custom HiTechMotorsports Cam, BBK 1 3/4 LTs with a TKO 5 spd
BlackDrop50 is offline
post #5 of 8 Old 02-05-2005, 06:46 PM Thread Starter
So a TKO is a pretty good transmission if you're looking for a 5-speed to hold a lot of power?
post #6 of 8 Old 02-05-2005, 07:48 PM
The TKO is basically the best 5 speed you can get. They have a newer even better version out now, the TKO 500 and 600.
post #7 of 8 Old 02-05-2005, 08:01 PM
marius's Avatar
the t-56 swap is quite a bit more expensive than the tko swap, for a fox. but if you have the money go for it. the cost outweighs the advantages of the t-56 imo.
86 gt many mods
07 R1 a few mods
02 Z71 tahoe no mods
marius is offline
post #8 of 8 Old 02-05-2005, 10:20 PM
The OASIS Guy
brian97cobra's Avatar
Trader Feedback: (60)
i have a t-56 and love it but the t-56 weighs a lot more so if your all into racing and weight then go tko 500. both are great and u do not have to change that much. custom cross member $189 from HPM. move speed o cable and lengthin the neutral safety switch wires. also the drive shaft needs to be shortened like 1 1/4 inches
Originally Posted by MVD View Post
If it's cheap and reliable it isn't fast
If it's cheap and fast it isn't reliable
If it's fast and reliable it isn't cheap
brian97cobra is offline
