Bent up flexplate...ok to bend back - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 01-03-2005, 11:26 PM Thread Starter
Well if you guys have been reading my posts..u will know i have been chaning my clutch. I got the trans and bellhousing down, but in the process bent up the bottom of the flex plate a lil. Can i fix it or do i have to get a new one?
3.55 gears, 65mm Tbody, BBK cold air induction kit, BBK unequal length headers, Hi Flow Catted Hpipe, 2 chamber flowmasters, Koni yellow struts and shocks,Mega Bite Jr. upper and lower control arms, Alum drive shaft, FMS B springs, MSD blaster coil and 6al, march underdrive pulleys, pro 5.0 shifter, adjustable clutch cable and firewall adjuster and quadrant
Petro is offline
post #2 of 6 Old 01-03-2005, 11:42 PM
5SpeedGT's Avatar
If you mean the plate that sits between the block and the flywheel, yes you can bend it back. Try to get it as flat as possible.
5SpeedGT is offline
post #3 of 6 Old 01-04-2005, 12:10 AM
DarkMesa8's Avatar
Yeah, the correct term is dust plate... I would've thought it pretty hard to bend a flex plate, even closer to impossible to accidently bend a flywheel.
Bend it back, and if you can get it to sit on the dowels and cranshaft, the bellhousing should finish flattening it for you. Just make sure it doesn't move as you're tightening.
1991 Grey Mustang LX Hatch
1995 Jeep Grand Cherokee Limited V8 4x4
1994 Suzuki GSX750F Katana
DarkMesa8 is offline
post #4 of 6 Old 01-04-2005, 12:16 AM Thread Starter
uhhhh..who bent a flywheel?? I am just talking about the metal shim/plate between the bellhousing and engine. It was pretty easy to bend since i had to pry the bellhousing off with a screwdriver
Petro is offline
post #5 of 6 Old 01-04-2005, 01:49 AM
DarkMesa8's Avatar
Nobody bent a flywheel.
You said flexplate in the title, which is the AODE equivilent to a flywheel (position wise in the drivetrain). I was just clarifying.
post #6 of 6 Old 01-04-2005, 09:50 AM
We had to read into this one to figure out that you are not familiar with the automatic vs manual terminology. Yep, just straighten out the sheet metal.
Flywheel goes with manual
Flexplate goes with automatic
Racerock is offline
