DIY through floor subframes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 59 Old 10-16-2004, 04:23 AM Thread Starter
MAT88GT's Avatar
thought I'd share
Prelim stuff here
2x3x0.120" subframe connectors...52" long at this point
The backsides will conjoin the rear subframe rail to the back of the lower torque box. The front of the connector will actually lay inside the subframe rail
Seat braces will be 1.5x1.5x0.080" square stock laying in notches cut into the subs
There will be kickers spanning from the main hoop and front cage footings to the subs...again 2x3" stuff
The holes in the floor will be replaced with fresh mild steel
I finished cutting the floor...
MAT88GT is offline
post #2 of 59 Old 10-16-2004, 04:24 AM Thread Starter
MAT88GT's Avatar
"notched" the 2x3 so it would drop down into the front subframe, leaving about 3/16" exposed above the front floor. This also dropped the rear quite a bit. The cut measures 1" front and 1 3/8" rear, 18" long to match the subframe.
Test fit
Here is now she sits after the notching!
Dropped in the rear
Shot from under the rear section
Just behind the front subframe
Smoothed up the floor a bit...shows the notch in relation to the floor/sub
Test fit with the seat all the way forward
all the way back...plenty of room
dirty seats!
MAT88GT is offline
post #3 of 59 Old 10-16-2004, 04:25 AM Thread Starter
MAT88GT's Avatar
This cross brace will tie the subframe into the main hoop footing plate and main hoop bar once the cage is installed. This is a HUGE saftey enhancement over the typical setup with just a 6x6 plate for the main hoop, which can shoot through the floor if you DO actually roll the car.
Front will also have crossbraces for the front footings
Happy
Since I knew the seat as all squared away in terms of clearance, I could go forward today with the seat cross brace.
Seat cut for the 16x1.5x1.5x0.8something inch crossbrace
Crossbrace in possition
rear underside
Front underside, looking to the rear of the car...very minimal lost in ground clearance
Top view
MAT88GT is offline
post #4 of 59 Old 10-16-2004, 04:32 AM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
Nice! Now come do mine.
Saving to favorites.
Helmut
Originally Posted by MFE
HELMUT RONER is offline
post #5 of 59 Old 10-17-2004, 11:03 AM
88OrangeLX's Avatar
Me too, Ill give you $2.00 and buy you lunch!
New times coming soon.....
88OrangeLX is offline
post #6 of 59 Old 10-17-2004, 11:55 AM Thread Starter
MAT88GT's Avatar
MAT88GT is offline
post #7 of 59 Old 10-17-2004, 02:15 PM
Trader Feedback: (26)
great little write up and congrats they made it a sticky...
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, 408 super Vic intake, high port heads, pro system 1000cfm carb, inductions solutions sledge hammer nitrous system, glide. Full TeamZ suspension.
FordFreak300 is offline
post #8 of 59 Old 10-17-2004, 10:27 PM
Sweet! What are you gonna do for carpet?
89gt50 is offline
post #9 of 59 Old 10-18-2004, 12:31 PM Thread Starter
MAT88GT's Avatar
I'm going to modify the stock carpet to fit
MAT88GT is offline
post #10 of 59 Old 10-19-2004, 03:48 PM
drudis's Avatar
I did mine similar, yet a little less cutting...
Except, the rear part went THRU the torquebox (slipped inside the rear framerail).
Darius Rudis
Ford Motor Credit Company
drudis is offline
post #11 of 59 Old 10-21-2004, 10:14 PM
90PandE's Avatar
Should have came that way from the factory! Shweeeeet.....
1990 GT. 5 speed. F cam, GT-40 intake, GT-40 heads, 3.73, White with gray interior. No times or numbers.
90PandE is offline
post #12 of 59 Old 10-24-2004, 01:32 AM
jeremy mifflin's Avatar
thats how i am going to do a set in my 89 notch and my friends 81 t-top notch..........
jeremy mifflin is offline
post #13 of 59 Old 10-24-2004, 08:56 PM
Ray III's Avatar
Nice work. I want to do something just like that, except maybe drop the rear a bit more and stick some plywood in the rear footwells on either side, then you would never notice anything sticking up under the carpet. Also a crossmember for a torque arm and stronger transmission mounts anchored to the frame rails (those sheetmetal mounts will lose a battle with a tree stump lol)
this post property of RAYMOND
Ray III is offline
post #14 of 59 Old 10-25-2004, 06:16 PM
Good info! When you weld them up, what size MIG wire are you going to use?... or is Flux Core the better choice here?
helexia23 is offline
post #15 of 59 Old 10-27-2004, 09:24 AM
FastLane's Avatar
Nice writeup!
Just remember. If you install subs like that then you have modified the original floor
and the NHRA and IHRA mandate a rocker bar on the driver side when you install your cage.
2016 Magnetic GT 6M
2013 F350 4x4 Crew Cab
1990 LX 5.0 Convertable
88 Lx Coupe. Dart 363, Precision Turbo PT-88 and a Carb!
FastLane is offline
post #16 of 59 Old 11-02-2004, 01:20 AM
sporky's Avatar
What's this done for, rigidity and safety? Are you "replacing" a smaller stock piece there or adding something completely new?
(was) turbo crx
next car mustang?
sporky is offline
post #17 of 59 Old 11-10-2004, 01:48 AM
So what's better here, doing one's like in the Griggs Racing kit, that end at the bulkhead. Or one's that go through it and into the rear frame rail beside the LCA, like in that mustang performance handbook 2 or whatever it is.
For those that have done it, is it a real head ache to do the later? Or is it easier than it looks? Anyone else with anymore pics. I'm looking at starting mine right away so any info would be great.
StarvinMarcus is offline
post #18 of 59 Old 11-10-2004, 09:21 AM
drudis's Avatar
I actually did BOTH...
I did mine thru the framerail, so it is supported over a longer span. I also added a plate to the rear bulkhead, and welded that on there at the same time.
As for "Real headache to do later...". YEAH! I installed subframes (undercar), then installed my rollcage. Only THEN, I went back and cut out the subframes, and added thru-the-floor ones. That was a pain to work around the jungle-gym of rollcage...
Get a plan, and do it right the first time.
Darius Rudis
drudis is offline
post #19 of 59 Old 11-10-2004, 08:07 PM
Yeah I'm defintaly making sure I do it before I get the cage in. And I was thinking of adding a plate to the bulkhead too. So maybe thats what I'll do then.
post #20 of 59 Old 02-21-2005, 11:09 AM
born again
1986 stang with TF TW heads and a Street intake, 36 pound injectors and pro-m calibrated MAF, 89 computer, Borla exhaust, Stock TB and CAM, roller rockers 1.6 ratio, stock shortblock with studded mains, and a T-5, twin T-3 .60/.63 turbo's ITS heafers and downpipes, Huge 24X16X4 intercooler, Autometer gauges idles like a kitten with stock computer!!!!
ng8264723 is offline
post #21 of 59 Old 02-21-2005, 11:53 AM
PURESTREET5006's Avatar
Yea...I just had my chassis guy do mine and tie everything into the roll bar..The car is super stiff now.
" In trouble as always"
Need a Roll bar or custom Cage?
Darrin Carter...C&C Motorsports..chicago/michigan.
NMRA P/S 5006
With Help From:
FTI
HarlandSharp
Whites pit's stop.
CenterForce Clutches.
JPC Racing.
AXLES ETC..Lansing, Ill
Moving Solutions..Belmont Mi.
SuttonHP..Matteson,Ill
Liss CarStar collision Center..crown point Ind.
PakMan MotorSports Inc, LockPort, Ill
Pro-Systems Carburetors..Spring Lake, Mi
Denso Iridium spark plugs.
PURESTREET5006 is offline
post #22 of 59 Old 03-14-2005, 03:39 PM Thread Starter
MAT88GT's Avatar
Finally got my welder! I'll be finishing these up and adding more pictures as time allows.
Also, I'm installing fabricated lower torque boxes once the subframes are finished...I'll make a pictorial with blueprints for that as well
MAT88GT is offline
post #23 of 59 Old 03-29-2005, 05:33 PM Thread Starter
MAT88GT's Avatar
back at it!
starting on the drivers side now
I cut an access hole to locate the sides of the subframe and draw out the cut lines from there
Cut...note that on a 4 banger there is a reinforcement within the subframe for a bracket...this needs to be removed
this is how I've been measuring up the seat crossmember cuts...you can also use a square/straight edge combo, but I couldn't find mine lol
The floor under the seat crossmember needs to be cut using a 7" angle grinder with cutting wheel, or a sawzall
the areas with missing floor board have been cut out or rusted through...they'll be patched with sheet after the subs are welded
btw, this is the coupe
MAT88GT is offline
post #24 of 59 Old 03-29-2005, 06:40 PM
Terrible Juan's Avatar
Awesome. I wish I had the resources to do something like that. I'll probably end up with MM full lengths and a roll bar for looks.
2008 Subaru Impreza WRX
Terrible Juan is offline
post #25 of 59 Old 03-29-2005, 10:27 PM
I just wish I had that my space. I've done mine now to, it took about 3 weeks total. But I did it in a single car garage that has two cars in it. Plus it was between -20 and -30 degrees the whole time.
post #26 of 59 Old 03-30-2005, 12:38 AM
Matt,
Looks nice, have you thought about putting a piece into the rear subframe? We did that on my Futura. It goes in the rear sub about 6". Really ties everything in nice.
Here's a link to pictures of mine.
http://photos.yahoo.com/jbozzelle
Also, I don't think you'll need that sill bar for NHRA cert. Mine never had it and it was certed 2 twice over a 6 year period. I know of a few cars where this was ok without a sill bar.
John
87 Hatch, Backhalved, 514, Glide, etc...
78 Futura, minitubbed, 466, C4, etc...
jbozzelle is offline
post #27 of 59 Old 03-30-2005, 06:22 AM Thread Starter
MAT88GT's Avatar
Yeah I've thought about it, but don't know what I'm going to do yet back there since I have fabricated lower torque boxes to install as well....things might get tricky lol
MAT88GT is offline
post #28 of 59 Old 04-02-2005, 07:44 PM Thread Starter
MAT88GT's Avatar
tbox from subframe
ssm tbox laying over the stocker
Going to run a 2x2 section between the tbox and sfc
MAT88GT is offline
post #29 of 59 Old 08-16-2005, 01:02 AM
tarmon8r's Avatar
Any more pic and updates? very informative. Keep up the good work.
Good Lord, Im getting a reading of over 40 mega-FONZIES.
tarmon8r is offline
post #30 of 59 Old 08-16-2005, 03:56 AM
94greyghost's Avatar
Great job. As a former chassis builder, I have to compliment you on doing it correctly. I like to lay the 2x3 flat for less of a bulge inside the car, but other than that you did an excellent job, make sure you tie it into the cage, weld it to the floor(I have seen guys actually just weld the ends and use caulk along the floor???) and you will need a side sill plate bar on your cage since you modified the original floor. Great thread dude!!
Daily Driver:Very SLow Stock 94 GT VERT, C&L 73 mm , 3.27 gears,AODE w/Kit , MAC cat back. MAC Off Road H-pipe, 14 deg timing Race Car: 70 Nova, 377 SBC ,TH400, 10" tire car, cage, 10.54@132 (on motor)will spray soon (200hp kit) Sonic Blue 2003 Cobra Off Road X-Pipe,SLP exhaust, 2.80 pulley(15psi) , Predator tune, CAI, Accufab TB,8.8", Solid Rear,3.90 Traction Lock,315/35/17 Nitto DR's, Tokico's,alum driveshaft,traction control lockout,couple chissis mods.(Fast)
94greyghost is offline
post #31 of 59 Old 08-16-2005, 09:36 AM
Nice write up man. I know a guy that make some nice look throught floor conectors. Let us know how them work
1990 GT AOD. All white on the outside, all black on the inside.
MOD's 4.10 gears, BBK off road H-pipe, Flowmaster 2 chamber cat back, UDP's, Mac CAI,Flex a lite clutchless fan,Transgo shift kit,Eibach sportline springs, Clear conners, LX taillights, 5" Autometer tach, White 93 PONY rims, Full Kenwood sound system.
Beninthestang is offline
post #32 of 59 Old 12-08-2009, 07:16 PM
Niterider86's Avatar
Trader Feedback: (18)
man where is the rest of this thread??
Niterider86 is offline
post #33 of 59 Old 12-08-2009, 07:47 PM
Kevins89notch5.0's Avatar
HOLY OLD THREAD BATMAN!!!!
He sold it/scraped it and bought a running/driving 5.0 with basic bolt on mods.
Corral Elite Member #1
** 89 LX 5.0 ** blower whine, better brakes, and faded paint
Kevins89notch5.0 is offline
post #34 of 59 Old 01-27-2010, 02:08 AM
ttt!!!! i just cut the hack job cage out of my notch, want to run 8.80s 155+ traps. going with a 10 point cage but i want to do the threw floor connectors. any one have any more pics?
bad6as is offline
post #35 of 59 Old 01-27-2010, 09:22 AM
drudis's Avatar
Originally Posted by bad6as View Post
...any one have any more pics?
Whats wrong with the first 20 photos...
Darius Rudis
drudis is offline
