351 Windsor Flywheel 157 tooth or 164 tooth - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 10-07-2004, 01:21 PM Thread Starter
I'm putting a 351 in my car with a Tremec TKO and a Cobra R bellhousing. Will a 164 tooth flywheel work or does it have to be 157 tooth? Thanks for any input.
2003 25.2 Redfire Cobra 481x Twin 91s Outlaw D/R
2003 Black Cobra 418W L/F 88 x275
2007 Silver Z06 Vortech SI Trim + Bolt Ons
2006 King Ranch F350 22.5's + Bolt Ons
5.0 Mustang Man is offline
post #2 of 4 Old 10-07-2004, 07:19 PM
Banned
my 351w got the 157 tooth i got tko also but with lakewood bell...i have 2 starter bolt patterens on it,,
post #3 of 4 Old 10-07-2004, 08:01 PM
Linc's 93 Splash's Avatar
The bellhousing will dictate what tooth flywheel to use.
In your case, it must be 157 - but also remember now, 351W is 28 Oz balance, not 50 oz like 5.0
'93 Splash 5.0 - needs more traction
1997 GT 5-speed with 97 Mark VIII engine swap
Linc's 93 Splash is offline
post #4 of 4 Old 10-08-2004, 11:00 AM
157 tooth, 28oz balance, you can keep starter from your 1991
1988 Hatch: 414w, AFR 225's, CompCams XFI 236hr cam, 42lb injectors, 95mm PMAS MAF, Reichard Racing Trick Flow TFS-R air gapped lower, TFS-R 90mm upper, Accufab 90mm tb, Kooks 1-7/8'' longtubes, Tremec 3550 TKO, 3.73's, Moates Quarterhorse, BE/EA
PoweredByAFR185 is offline
