Stumbling during acceleration/ bucking at low rpm - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > General Mustang Tech
Old 06-11-2004, 12:10 AM   #1
xsvstang's Avatar
Recently I noticed that my fuel pressure (under the hood gauge) was at 40 psi without vacuum. My cars does a little idle surging so I reduced the pressure to 38 PSI.
It seemed to help the idle. A day later I noticed alot more bucking then normal when attempting to cruise at around 1800 rpm. I need to keep rpms at around or above 2500 rpm or experience bucking.
I checked the fuel pressure and saw that it was now 34psi without vacuum. I turned it up to 38 psi, but with the same problems.
At light accelleration/ light load I feel a small amount of bucking/hesitation. When trying to cruise at 1800 rpm I experience the same thing. When accelerating hard I do not have the hesitation/ bucking.
I have a 190 lph pump with 3000-4000 miles on it and a T-rex with 1000 miles on it.
I also noticed that when I turn the key on I immediately have 32 psi with vacuum. When I turn the engine off the pressure drops to about 24 psi and seems to hold there. Should there be a pressure drop and how much of one should there be??
Any suggestions for my "new" problem?
btw....prior to this I would only have bucking at less then 1400 rpm when I would lug it down the driveway trying not to wake up my neighbors.
__________________
1989 LX Coupe 408W (4cyl conv)
AFR 185's, Weiand Stealth Intake, 770 Street Avenger, BBK 1 3/4 Longtubes, Dynomax Super Turbos, 3.55's, MK VIII elec. fan w/DC Controller, Magnum 280H cam, Mech. FP, 3550, and 2001 Bullit Susp. (401 RWHP/ 457 ft/lbs Torque)
1990 LX HCI/Vortech V2SQS
xsvstang is offline
Old 06-11-2004, 02:05 AM   #2
BLiND's Avatar
vacume leak?
what is your vacume at idle?
__________________
1989 Notchback LX 5.0/T5/5 lug/Etc - ex 2.3L/A4LD
1997 GT DOHC 4.6L/T45/IRS
2002 F150 Harley-Davidson 5.4L/4R100 - Stiegemier Stage 4
2008 GT Premium Convertible 4.6L/5R55s
BLiND is offline
Old 06-11-2004, 02:38 AM   #3
xsvstang's Avatar
Originally posted by BLiND
vacume leak?
Vacuum at idle is 10. Which is where it has been ever since I installed the gauge, probably 1000 miles.
During the stumbling problem it is 15-18 psi.
Under a hard acceleration, 0 psi or when building boost it is not an issue.
__________________
xsvstang is offline
Old 06-11-2004, 10:53 AM   #4
Authorized corral.net Advertiser - Kocky Products
93Cobra#2771's Avatar
Location: Helping Paul/Bob/Michael/Jeff spend Brian's money
Have you made any changes at all to your car recently? Changed anything on your tune at all?
Almost sounds like your maf transfer curve got fouled up or something. Are you using 1.3 alpha with your tweecer?
You might want to throw this question up on the tweecer bbs as well...
__________________
For Sale: Reproduction Window Stickers, 87+ Mustangs, Cobras, Lightnings, and HD F150!
Richard White
H/C/I 93 Cobra
11' Hyundai Sonata 2.0T Limited
11' F150 SCrew 4x4 Ecoboost
96 Escort Wagon 1.9/5spd
96 Geo Metro 1.0 (small block)/5spd
93Cobra#2771 is offline
Old 06-11-2004, 11:32 AM   #5
AnthonyDalrymple's Avatar
Have you checked\spread out the male pins in the "10 pin connectors" also known as the "salt & pepper shakers"? I just went through this & the symptoms sure do match what my car was doing......
__________________
'89 LX 'vert. 331 stroker, TKO600, 11.52@118.93mph; new motor in & looking forward to better times!
P.O.S '88 GT 'vert; barely saved from the junkyard
AnthonyDalrymple is offline
Old 06-11-2004, 11:33 AM   #6
whoops..how did this happen? Double post-sorry.
__________________
Old 06-11-2004, 01:20 PM   #7
xsvstang's Avatar
Absolutely no changes have been made to my tune.
I still have the old version.
I have not had a laptop for several months so there hasn't been any tweaks that may have occured by accident!
Last night I was driving home and the same thing was occuring. I took off the vacuum line to the AFPR and the problem ceased.
I can still hear the whine of the T-rex, but nonetheless it appears that I have sometype of fuel delivery problem.
__________________
xsvstang is offline
Old 06-11-2004, 01:21 PM   #8
xsvstang's Avatar
I took off the jumper harness last year and played with the 10 pin harness then. I will re-check it.
__________________
xsvstang is offline
Old 06-11-2004, 02:19 PM   #9
Sounds like your afpr may be going out. Or, you may have a fuel pump letting go on you/clogged fuel filter. Your fuel pressure should be the same from time to time with vacuum off, although I have heard that you should take the fuel pressure down to whatever pressure you want, as opposed to raising it to the pressure you want. Something about the afpr wanted to loosen up past it's set point, from what I recall.
__________________
Richard White
H/C/I 93 Cobra
Old 06-11-2004, 02:30 PM   #10
xsvstang's Avatar
I went out this morning and the AFPR is reading what I last set it at 38-39psi. I re-connected vacuum and it dropped down to 32. With light throttle I can get the gauge to drop back to 30 psi.
A hard acceleration and it goes back to 38-39 like it should.
The AFPR *seems* to be working. I will go increase the pressure and then drop it down to 39, clear my computer and see how the drive to work is.
Like I said it didn't start until I decreased pressure from 40. After raising it up the problem continues. So maybe your suggestion will work.
I would think that the low mileage parts would be fine, but who knows
__________________
xsvstang is offline
Old 06-11-2004, 04:05 PM   #11
Terrible Juan's Avatar
I had a stumbling/stuttering problem at 1500rpm after I did some stuff to my intake and it turns out I had two of the little vacuum lines switched. Check to make sure that the four vacuum lines on th passenger side fenderwell are going to the right places.
__________________
www.terriblejuan.com
2008 Subaru Impreza WRX
Terrible Juan is offline
Old 06-11-2004, 06:53 PM   #12
I have the same problem with my speed density 87 aod. Check your cooling system!!!! Does it do this when the car is warmed up? Or does it do it when you first start out? Please be more specific. I thought it was my ignition, fuel system, or vacuum leaks. Replaced every damn thing and still have the same problem.
__________________
Car: 1987 LX Coupe with 5.0 option
Engine mods: Banshee Ram Jet shaker hood system with AFM PowerPipe, BBK equal length 1 5/8 shorties, 2.5" catted h-pipe, 2.5' Super 40 Flowmasters, Be Cool dual electric fan, March Power and Amp underdrives, Powermaster 140 amp alternator, 180 thermostat, 12 degrees of timing, battery in the trunk, Aeromotive adjustable fuel pressure regulator, BBK 190 lph fuel pump. MSD 6AL box, MSD 8.5 Super Conducter wires, MSD Blaster coil.
Transmission: Stock AOD, Transgo shift kit, B&M tranny cooler, B&M 7 quart tranny pan.
Suspension: Steeda aluminium upper and lower control arms, KB subframe connecters and k-frame brace, Steeda drag race bar.
Wheels and Tires: 17x8 Mavromont Chrome Pony R's, Bridgestone Pontenza S03 Pole Position 245/45z/17 tires
Rear end: FMS 4.10's
ramjet lx is offline
Old 06-11-2004, 11:20 PM   #13
xsvstang's Avatar
Cooling system is a 3 row with electric fan and water pump with 2000 miles.
My car it runs a bit rough until it is 160+ degrees. So for a few minutes.
My problem was after the car was warmed up. It normally operates between 180 and 188*.
I upped my FP to 44 psi and then backed it down to 40 psi without vacuum.
This seems to have fixed my hesitation/ stumbling problem.
Unfortunately, my idle surge is back and will have to be tuned out via a different route then fuel pressure.
__________________
xsvstang is offline
Old 06-11-2004, 11:31 PM   #14
harvester of sorrow's Avatar
Trader Feedback: (23)
bad o2 sensors cause this exact problem. make sure the car has a good tune up on it before replacing the o2 sensors. i had this exact problem & cleaned & replaced every sensor under the hood. my car is a converted 4 cyl car & we couldnt get codes out of it so it was all trial & error! after removing the upper intake & checking all the vacum lines & i replaced all the upper intake gaskets & T.B. / egr gaskets. i replaced the egr, act & tried another MAF unit. gave it two full tune ups, ignition module & added a full MSD ignition & bbk 190 lph fuel pump. no change in performance-still stuttering & bucking at a stead cruise. finally i broke down & replaced the o2 sensors & reset the comp. for 20 min. after that the car has been perfect since-2 years now- & the performance & throttle response were very noticable. gas mileage went up too! all drivability problems were GONE!
i highly recommend new o2 sensors for anyone w/ an older fox. i almost lost my mind over this! it was the best 100.00 i ever spent on my car.
__________________
88 Saleen rebody/tribute
-built from a 4 cyl chassis
RIP #573!
harvester of sorrow is offline
Old 06-12-2004, 12:58 AM   #15
UNAUTHORIZED ADVERTISER
NITROSTANGRACING's Avatar
You might also have a bad MAF sensor. The MAF only sends a signal at idle and low RPM readings. If it is not functioning properly it can cause a poor idle quality. It will stumble and possibly backfire until the ECM senses a specific RPM Range.
__________________
My Mom says that if I keep violating the forum's rules about signatures and advertising, I'll just be banned altogether.
NITROSTANGRACING is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
