Alternator spin direction? Does it really matter? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 10-09-2003, 01:29 PM Thread Starter
Question Alternator spin direction? Does it really matter?
An alternator produces AC voltage. So, AC voltage is produced by spinning in any direction right? Does it matter which direction the alternator spins? I am assuming it doesn't matter.
Pic of my cars:
exoticcarsgonewild is offline
post #2 of 8 Old 10-09-2003, 02:36 PM
Ray III's Avatar
I dunno about that but you also have to have cooling vanes spinning the right way for cooling...
this post property of RAYMOND
Ray III is offline
post #3 of 8 Old 10-09-2003, 03:18 PM Thread Starter
True, I didn't think about that Ray.
Pic of my cars:
post #4 of 8 Old 10-09-2003, 08:41 PM
Mustang5L5's Avatar
Re: Alternator spin direction? Does it really matter?
Cars are DC voltage not AC voltage.
And yeah you need to spin the alt in the direction of the cooling fins.
Mike
--1988 Mustang LX 5.0--
--2014 Ford Taurus Limited--
Mustang5L5 is offline
post #5 of 8 Old 10-09-2003, 08:48 PM
Ray III's Avatar
Re: Re: Alternator spin direction? Does it really matter?
yes but alternators produce AC current which is converted to DC. A few engines have DC generators but they aren't widely used because alternators are capable of greater efficiency.
still not sure if there is a "right" direction for electricity generation though. you can put a voltmeter on it and see if it produces the same polarity of current when spun either way by hand...
Ray III is offline
post #6 of 8 Old 10-09-2003, 09:17 PM
The twin diode bridge use to make DC will still make a positive DC if the AC source is reversed. This is full wave (180 degree) rectification. A negative voltage could not be produced unless the source winding was center tapped and used as a "zero " reference.
Hope this helps.
idwitheld is offline
post #7 of 8 Old 10-10-2003, 08:54 AM
tmoss's Avatar
Trader Feedback: (47)
It will work either direction, but cooling is designed for the stock rotation for best cooling. Won't cool very well in reverse rotation.
Tom Moss
tmoss is offline
post #8 of 8 Old 10-12-2003, 06:32 PM
Either way for AC.
Some aftermarket supercharger kits mount the alternator backwards. I wonder if they burn out quicker.
terryr is offline
