aod/aode help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-12-2003, 11:14 AM Thread Starter
aod/aode help
Ok i posted once about getting a c-4 for my car or a built auto b/c my t-5 taking a poo on me.... this is my daily driver keep in mind. If i go with a aod/aode i want soemthing thats has all the goodies transbrake,valve body, pro stick, converter, shift kit, and i want a 1-2-3 manual shifts but then go in to odrive. Does anyone have a aod/aode thats similiar to what i want? and also would i lose e/t by not going with a 5spd tremec?
and would i need to get a lower gear than my 3.55's?
2006 F-150 King Ranch, Supercrew- Stock for the time being
1991 Gt Alot of Team Z stuff, Strange stuff, Big round Percision thingy.
Sidewayzisbest is offline
post #2 of 5 Old 08-12-2003, 01:20 PM Thread Starter
post #3 of 5 Old 08-12-2003, 07:08 PM
MustangGTAOD91's Avatar
Some people may disagree but a lot of people will tell you the best of the best come from www.lentechautomatics.com. Seems to be the Rolls Royce of AOD's.
I don't know about the exact shift pattern you want, but they do have valve bodies that can be shifted manually and automatically. Usually what you'll have is control over 1-2-3 with your shifter and then you'll have a switch to turn OD on and off.
ET is questionable. With a stall converter matched to your cam it is not out of the relm of possibility for you to gain ET with the AOD. If anything, it will make driving the car easier and a lot more consistant. The AOD is heavier and you will suffer a more significant drivetrain loss, so you might lose a tenth or so. For what it's worth though, people clain the heavier internals of a Tremec cost you ET over a T5, so sometimes you have to shave ET for a reliable, solid tranny.
Best of luck...
'00 Firebird Formula, A4/3.23's, SLP lid, AMW catch can, Nitto 555R's
Audio: Kenwood KDC-MP828 deck, Alpine SPS-171A components, SPR-17LP coaxials, Alpine MRV-340 55x4 amp, 3 MTX "Blue Thunder" 10" subs, Hifonics BX1500D mono amp.
'91 Mustang LX, beefed up AOD, 3.73's, aluminum driveshaft, subframes, off road H, Flowmasters, Intrax springs, STB, underdrive crank pulley, '93 Cobra overdrive water pump pulley, 155# fuel pump, Nittos, Cervinis 1 1/2" cowl
MustangGTAOD91 is offline
post #4 of 5 Old 08-13-2003, 12:31 PM Thread Starter
thanks
NEWLY BUILT AOD WITH LENTECH STRIP TERMINATOR VALVE BODIE,FIXED LINE PRESSURE,TRANSBRAKE AND SHIFTS AUTOMATICALLY,AND ELECTRONIC OVERDRIVE LOCKOUT DELETE)...FUL THROTTLE OVERDRIVE, WIDE RATIO GEARSET,LEVEL 10 SOLID BILLET STEEL INPUT SHAFT 10" NON LOCKUP TORQUE CONVERTER,PRECISION RACING FILTER AND ART CAR DEEP SUMP ALUMINUM PAN,RATED FOR OVER 1000 HP..BUILT FOR MY 900 HP TWIN TURBO STANG ,NEVER USED SOLD CAR
does this sound good or should i stay away?
post #5 of 5 Old 08-13-2003, 01:49 PM Thread Starter
also is there anyway to keep my longtubes on right now i have a t-5? and teh bellhousing ?
