Need Help Stalling Issue!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-15-2017, 05:18 PM Thread Starter
Have an 88 mustang gt. Did a bunch of stuff at the same time so ill try and list some info. Did a maf conversion using a9l. Swapped from aod to t5. Rebuilt motor refreshed bottom end edelbrock 60379 heads. Tfs1 cam. 93 cobra intake 65 mm throttle body. New: tps,iac, nss, bbk maf with 24lb injectors and calibrated for the 24s. I switch wiring harness and all for the t5 so reverse lights nss all that works. So if i take a rides maybe 40-50 miles i press in the clutch maybe two times out of the whole ride and its lioe someone turns the ignition of rpms just fall out and it dies. Next day wont quit any next day 2-3 times. Its very random and i dont have a clue? Any help would be greatly appreciated. Also replaced the a9l i had with a reman autozone got me.
Elswick84 is offline
post #2 of 8 Old 06-15-2017, 05:19 PM Thread Starter
New o2 sensors also
post #3 of 8 Old 06-15-2017, 05:38 PM Thread Starter
Adding as i think of it. New vss too
post #4 of 8 Old 06-15-2017, 08:26 PM
indy2000's Avatar
scan engine off and on codes
indy2000 is offline
post #5 of 8 Old 06-16-2017, 08:47 AM Thread Starter
Will do. At work right now. Soon as i get home ill post what i find
post #6 of 8 Old 06-17-2017, 05:21 PM Thread Starter
Engine off codes are 67,96
post #7 of 8 Old 06-17-2017, 07:08 PM
indy2000's Avatar
engine running??
indy2000 is offline
post #8 of 8 Old 06-19-2017, 11:25 AM Thread Starter
Thanks for the help indy. Buddy came over friday and found one wire ripped out of neutral gear switch in trans. And upon removal the little metal ball was shoved back in there lodged. Replaced and has not stalled any since. Thanks
