93 Clock Spring Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-20-2017, 10:43 AM Thread Starter
So I need a clockspring - nothing works on the steering wheel and airbag light is present.
This is a 93 mustang - from what I understand it is not interchangeable with any other year.
First I'll ask - is anybody making these yet?
My main question since I will have to find a used one: How can I be sure that the unit is rotationally centered when I install it? If I rotate it slowly, will I feel some resistance at each "end". Can I do this without breaking it?
93GT - NOVI2000, Twisted Wedge Heads, E303, Bolt-on Car
93 Coupe - Project Car - 100% gutted - 9.99 Goal
Wolfe framework & 10pt moly cage, TeamZ & Strange Suspension, Minitubs
EFI 438w n/a, E-85, solid roller, C4, 4.10's
EAR2EAR is offline
post #2 of 4 Old 03-20-2017, 07:52 PM
the part # is f3zc-14a664-ab for a 93 mustang, you have to buy used, look on ebay, theres a sticker on the clockspring it tells you how to center it
sjd3021 is offline
post #3 of 4 Old 03-21-2017, 06:37 AM
«1992 Mustang Service Manual Table of Contents»
«Group 11: STEERING SYSTEM»
«Section 11-04: Steering Column»
«REMOVAL AND INSTALLATION»
Contact Assembly
Removal
1. Make sure vehicle front wheels are in the straight ahead position and steering column shaft alignment mark is at the 12 o'clock position.
2. Disconnect battery ground cable and air bag backup power supply.
3. Remove steering wheel as outlined.
4. Remove instrument panel lower trim panel and column shrouds.
5. Disconnect contact assembly harness connector.
6. Apply two strips of tape across contact assembly stator and rotor to prevent rotation.
7. Remove contact ring retaining screws and contact ring assembly.
Installation
2. Align contact assembly to column shaft and install.
3. Install three retaining screws and tighten to 2-3N-m (18-26 lb-in).
4. Route contact assembly wiring down column assembly and connect harness connector. Remove tape strips.
5. If installing a new contact assembly, remove locking mechanism.
6. Install column shrouds and lower instrument panel trim panel.
7. Install steering wheel as outlined.
8. Connect air bag backup power supply and battery ground cable.
John
'92 SSP (ex-FHP 797) stock - SOLD
jmbaltz is offline
post #4 of 4 Old 03-21-2017, 08:41 AM Thread Starter
Thanks guys.
Well, no dice at the junkyard last night. The only '93 had a crappy aftermarket steering wheel with no clock spring.
Does anyone know about modifying a new Dorman clock spring to work on a 1993?
EAR2EAR is offline
