Foxbody LED Tail Lights - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By Daves8950LX
post #1 of 16 Old 03-19-2017, 06:46 PM Thread Starter
sporty4680's Avatar
Anyone ever buy a set of these or see them in person? How do they look?
For 87-93 Ford Mustang LED Red Smoked Tail Lights Lamp Pair New Left+Right | eBay
sporty4680 is offline
post #2 of 16 Old 03-20-2017, 10:48 AM
Mustang5L5's Avatar
Asthetics aside, my main concern is the components used, as I've seen some complain of them failing within a year of purchase. I'd assume with any china-made product that cheap components are used in the LED boards, which can lead to premature failure.
Personally, I prefer the OEM lights, but I don't hate those
Mike
--1988 Mustang LX 5.0--
--2014 Ford Taurus Limited--
Mustang5L5 is offline
post #3 of 16 Old 03-20-2017, 12:35 PM Thread Starter
sporty4680's Avatar
Guess thats where I am. I actually kind of like the clean smooth look of them. Will they last is the question. I think I am gonna pull the trigger and find out. My car sits in the garage most of its life anyway.
post #4 of 16 Old 03-20-2017, 06:34 PM
TaraFirma's Avatar
Let's see them after install.
To fly is Heavenly, to hover is divine.
Don't let your mouth write a check your a$$ can't cash.
TaraFirma is online now
post #5 of 16 Old 03-20-2017, 08:05 PM Thread Starter
sporty4680's Avatar
Definitely will be posting pictures and details about the lights. I haven't been able to find much in detail on them so I would like to help. More to come!!
post #6 of 16 Old 03-20-2017, 10:41 PM
vlzstallion's Avatar
i've had these same ebay ones but with the black housing and clear lens. had them for the past 3-4 years and absolutely no problems, leaks, etc. pretty surprised but i'm sure they're hit and miss.
vlzstallion is offline
post #7 of 16 Old 03-21-2017, 07:30 PM Thread Starter
sporty4680's Avatar
I like it
post #8 of 16 Old Yesterday, 08:25 AM
I used the factory housing, and just threw a LED bulb inside there. Plenty bright, and remains stock looking.
jmardlin likes this.
Daves8950LX is offline
post #9 of 16 Old Yesterday, 10:56 AM
That's what I did to my '95 F150.
'87, 105,000 mile stk short, SN89 Paxton 6 or 7 LBS, X303 Hds, E303, Cobra Int, 70 mm TB, 30# injrs, 1 5/8 full leng, no cats, 2 1/2 full exh, Astro A5, 3.73, MT Drg Rdls, Frnt Drag Eibach sprngs, Steeda upr HPM lwr cntrl arms, stk rear sprngs 1 coil cut, adj. struts shocks, 3150 w/drv. 11.87 121.
SpeedThrills is offline
post #10 of 16 Old Yesterday, 01:17 PM
Gixxer2k4's Avatar
Do load resistors need to be used with led bulbs?
Gixxer2k4 is offline
post #11 of 16 Old Yesterday, 10:46 PM
Yeah. I used superbriteleds.com, they sell the resistors for the turn signal/hazards.
-Gixxer2k4 is referring to the fact that the turn signals will "hyper flash" because the led's don't "load" the flasher like an incandescent bulb does.
post #12 of 16 Old Today, 08:01 AM
Most yes, some no because they have a built in resistor. You can clip on load resistors, or use a digital flasher module for $10.
post #13 of 16 Old Today, 11:12 AM
Enjoy_the_Ride's Avatar
My cruise control stopped working with LED bulbs. There is a path through the bulb that the cruise module needs. The load resistors I used didn't work and I never got around to finding a value that did work.
Enjoy_the_Ride is offline
post #14 of 16 Old Today, 05:49 PM
jmardlin's Avatar
I would just a digital multi meter and measure the resistance or the brake light side of the bulb and use resisitors that are as close to the same value as the bulbs are. The problem may be that it takes so little current to run them that it thinks the brake is being pushed. I would think that it would turn on just fine but wouldn't shut back off when you hit the brakes. If it isn't working at all then it might be something like the switch on the clutch isn't adjusted correctly or failed.
83 Capri RS T-Top 302, Afr 195 Renegade,11.2 compression, e303 cam, TFS-R, X3Z w/Tweecer RT, T56 Magnum, 2 1/2" Pypes X pipe w/2 chamber Flowmaster mufflers.
jmardlin is offline
post #15 of 16 Old Today, 06:21 PM Thread Starter
sporty4680's Avatar
I got my LED Tail Lights. I was very impressed. They were packaged well and they seem to be built well. The way they made them to connect to the original light socket was a nice surprise. The only issue so far is the turn signals. The LED's are not enough load for the blinker module but I will get straight.
post #16 of 16 Old Today, 06:34 PM
steel1's Avatar
Trader Feedback: (59)
Gotta say I'm still partial to my cheese graters but those do look pretty slick. Keep us posted on your install and any issues.
steel1 is offline
