Manual Trunk Release - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-19-2013, 08:57 PM Thread Starter
I just bought a 89 GT and can't get into the trunk! the glove box release doesn't work and the key has been changed (swapped ignitions) so it no longer works for the hatch. I can get all the way to the back and look at the two clamps over the pin but don't know how to release them?
I've tried leveraging the black bracket that sits atop the power release mechanism but no luck - maybe a dose of WD40 to loosen things up.
Any help is appreciated.
50GT is offline
post #2 of 11 Old 04-19-2013, 09:55 PM
My old car had an emergency pull release under the carpet and somewhat behind the plastic near the tail lights.
95slobra is offline
post #3 of 11 Old 04-19-2013, 11:44 PM
OneQwikGT's Avatar
The ignition and door/trunk key are different, two separate keys unless it's an SSP which it's not cause it's a GT. there is a retainer clip on the bottom of the hatch that holds the lock cylinder in. Drill out the rivet remove the clip, remove the cylinder, stick a flat head screwdriver in the latch and open it up.
That was for the fuel door release.
Daniel, Previous car's: Grey 85 GT, Black 93 5.0 LX Hatch, White 85 GT w/T-tops. Current car: Cabernet Red and Titanium 88 GT Convertible.
OneQwikGT is offline
post #4 of 11 Old 04-20-2013, 08:54 AM Thread Starter
Will see what I can do - still have the plastic cowling around the outside so don't have full frontal access to the mechanism. Might have to break the plastic and worry about that later.
Probably the only way in so needs to be done. Thanks!
50GT is offline
post #5 of 11 Old 04-20-2013, 11:07 AM
Haha yup. Retard moment there sorry.
95slobra is offline
post #6 of 11 Old 04-20-2013, 12:32 PM
OneQwikGT's Avatar
The clip is accesible from the outside, right between the license plate lights.
Sent from my SPH-M820-BST using Tapatalk 2
post #7 of 11 Old 04-22-2013, 01:25 PM Thread Starter
Do you drill through the clip? Had a look yesterday and it doesn't look "screwdriver" friendly with the rivet in the middle. Don't want to take the power tools to it without having a good understanding of what's involved.
50GT is offline
post #8 of 11 Old 04-22-2013, 10:11 PM
OneQwikGT's Avatar
Use a bit about half way between the size of the hole and the outer diameter of the rivet and just drill through the head of the rivet. Go slow so you don't go too far, you most likely won't damage the clip. Once you have done that the clip will just pull out of the hatch. GL.
post #9 of 11 Old 04-22-2013, 10:59 PM
Slo86GT's Avatar
This is scary, but get an old pocket knife. Wedge it into the trunk tip first just above the license plate, between the hatch and the weatherstripping, just right of center, like 1/2". Wiggle it flat, up and down while you push slightly, it;ll slip past a small ride, and wedge into place. Now, wiggle the tip back and forth. *click* Enjoy the oldest FOX thief "how to" in the book. Just did it in 20 seconds after not having thought about that trick for 10 years.
Now to fix it, run a bead of weld or Epoxy (JB Weld) over the edge of the plate metal where the latch is bolted to the hatch on the ends only. The slit there is what we just took advantage of to pop the hatch.
I can get under the hood of any FOX without being in the car, and without breaking anything, either in jest a few second. Just takes a familiar touch to know what to look for.
:shrug: There was a reason these cars were #1 stolen for a long long time. Funny I never broke into one, only legitimate helping hand situations when friends locked themselves out of cars, hood cables broke, etc.
FYI:
- Jody -
1986 Mustang GT MT - Toy
2003 Mustang GT Auto - Wife's DD
2013 Focus SE 5Door MT - Babymobile
Slo86GT is offline
post #10 of 11 Old 04-24-2013, 06:30 AM
OneQwikGT's Avatar
FYI:
Wow, can't believe I have never heard of this. I know how to open the hood but never knew about the hatch trick. Nice Gerber EZ Out btw, I used to have one years ago. I switched to Spyderco since,
post #11 of 11 Old 04-24-2013, 09:46 AM Thread Starter
I can confirm it works... thank you for the tip. Now to figure out how I can set it up so that I can always get in without a knife...
50GT is offline
