If you have Team Z metal matrix K, stock rack, and long tubes please help. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 02-06-2013, 07:36 PM Thread Starter
No Rice Nate's Avatar
Unhappy If you have Team Z metal matrix K, stock rack, and long tubes please help.
Am I the only one having clearance issues with these parts? I have a Flaming River steering shaft and there is no way the universal joint that goes to the rack is going to clear my Mac LT's. I have moved the offset rack bushings all over and that didn't help anything. I really don't want to beat and bend these headers to make it work. You got any ideas?
No Rice Nate is offline
post #2 of 10 Old 02-06-2013, 08:37 PM
Duvall's Avatar
I have all the above you have listed with the stock steering shaft and didn't have an issue.
Does the u-joint sit between the tubes?
Duvall is offline
post #3 of 10 Old 02-06-2013, 08:42 PM Thread Starter
No the lower U joint will not got on the rack because the primary from #7 is right in the way. I should have taken some pics.
What motor mounts do you have? I have new prothane ones.
post #4 of 10 Old 02-06-2013, 08:46 PM Thread Starter
I think if I get these parts https://www.jegs.com/webapp/wcs/stor...rderItemUpdate
I can extend the splined shaft from the rack up and make it work....
post #5 of 10 Old 02-06-2013, 08:48 PM
Duvall's Avatar
I am using the Team Z solid mounts.
Duvall is offline
post #6 of 10 Old 02-06-2013, 08:49 PM
Duvall's Avatar
That links me to an empty shopping cart.
Duvall is offline
post #7 of 10 Old 02-06-2013, 08:52 PM Thread Starter
post #8 of 10 Old 02-06-2013, 09:00 PM
Duvall's Avatar
Its hard for me to say what a good solution would be without seeing exactly what the issue is.
Duvall is offline
post #9 of 10 Old 02-06-2013, 09:05 PM Thread Starter
Bassically when I try to slide the lower U joint on the shaft coming out of the rack the U joint hits the header by 3/8". If the shaft coming out of the rack was extended another 4" it would everything would be fine. Hard to explain and understang without pics.
post #10 of 10 Old 02-07-2013, 09:59 AM
USAF retired
superirish's Avatar
Trader Feedback: (39)
Location: Foht Walt'n Beach Floriduh aka The Redneck Riviera
You can loosen the steering column and get some side to side movement, I think you can also push the shaft into the column a little to get a different angle to the steering rack.
1985 LTD LX, small truck motor, various mustang stuff.
1990 LX stock porno block, '86 flattops, ported GT40s, Vic Jr 4-hole throttle body, DB1 speed density processor, B-cam
, 1.7s, 4.30s, stock T5 living on borrowed time.
superirish is offline
