1993 cobra horn, radio, and turn signal not working - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 09-11-2012, 05:41 PM Thread Starter
Drove my car this morning and got to my first turn, turned my blinker on and it didn't work. Turned around and got home and found out my radio and horn didn't work either. The hazards work just no blinkers. Anybody have any trouble shooting I can go through to figure out what it could be?
Thanks Neil.
1993 teal cobra
331 dart, m2 ported heads, turbo setup.
Neil J is offline
post #2 of 12 Old 09-11-2012, 06:31 PM Thread Starter
Forgot to mention I did check all the fuses and they were all good.
1993 teal cobra
Neil J is offline
post #3 of 12 Old 09-11-2012, 07:27 PM
Typical symptoms of a failing ignition switch.
Replace a 1979-1993 Ignition Switch Assembly
Saleen0679 is offline
post #4 of 12 Old 09-11-2012, 09:04 PM Thread Starter
Thank you Saleen0679. I'll try that.
1993 teal cobra
Neil J is offline
post #5 of 12 Old 09-11-2012, 10:58 PM
fox88's Avatar
Your reverse lights are prob. out as well. You can simply tie a big zip tie around the switch to hold it back together, or just buy another one from the parts store. They're only about $20 or so. There's little plastic tabs on the ends that snap off and it just hangs there, causing problems.
fox88 is offline
post #6 of 12 Old 09-12-2012, 03:14 PM Thread Starter
Well; after some more under dash looking, I found that one clip for the radio worked loose. After reconnecting it the radio now works. But no horn or turn signals. I also replaced the ignition switch and no change.
1993 teal cobra
Neil J is offline
post #7 of 12 Old 09-12-2012, 04:39 PM
Looks like you may have all separate problems. You might have to break out the multimeter. The horn is powered off of fuse 16 and feeds the horn relay which feeds the horns. It could also be the contacts in the steering wheel.
post #8 of 12 Old 09-12-2012, 10:41 PM
Jesse H's Avatar
After you took it to the track it realized it's a race car. You're screwed!
'91 coupe & '93 cobra. One's quick and the other has 12k miles.
N/A 363. Hydraulic roller cam, Twisted Wedge heads, Box-R intake. 10.24@133.7. 1.61 60'... More to come.
Jesse H is offline
post #9 of 12 Old 09-13-2012, 07:35 PM
Wheres the relay for the horn located? Mine works with the ignition off but not on, but I can hear it clicking.
1970 Mach 1 Mustang with SoT bilsteins and mid-eye 4 1/2 leafs 620lb drop springs in the front. *393 4V cleveland with Buddy Rawls custom solid cam Astro A5*
Reverb is offline
post #10 of 12 Old 09-13-2012, 08:22 PM Thread Starter
And more scrutinizing found a nice cylindrical fuse in my glove box. Found the plug for it and you guessed it, the blinkers work. Now I just need to find the horn relay. Thanks everyone for all the suggestions.
@ Jesse-just fixing the blinkers will pick me up a tenth of a second.
1993 teal cobra
Neil J is offline
post #11 of 12 Old 09-13-2012, 08:56 PM
Horn relay is located to the left of the radio. It's mounted on a bracket with the warning chime and another relay. The horn relay is usually brown in color.
post #12 of 12 Old 09-15-2012, 01:10 PM Thread Starter
Thanks for all advice! I found my horn relay. It was where Saleen0679 said it was. It is brown in color. The relay itself was missing. Ordered a new one and works now. Thank you Corral!!
1993 teal cobra
Neil J is offline
