Is this common? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > General Mustang Tech
Old 08-07-2012, 06:28 PM   #1
max.b's Avatar
Is this common?
found the culprit to no speedo
is this common?
__________________
DSS block forged 306 roller, stud girdle, moroso7qt
Trick Flow TWs, Comp blowercam, Victor JR Intake, 750 Demon, MSD digital 6AL etc...BBK shortys, H pipe, Flows, 3.73s, Procharger P-1SC
max.b is offline
Old 08-07-2012, 06:38 PM   #2
Mine went on my Jeep - if your drive doesn't match the speedo gear then it will rip it. If it's not in properly it will too.
__________________
92 GT w/Stock Block 347 @ 10.2:1, Flat Top forged probes with forged eagle crank and H beam rods, Canfield 195's with Ed Curtis LS1 springs, Buddy Rawls custom hyd cam, Tmoss ported Victor 5.0, 42lb injectors, 75mm Edelbrock TB, 90mm SCT2400, QH
Reverb is offline
Old 08-07-2012, 06:42 PM   #3
Trader Feedback: (45)
yes
__________________
92 Hatch On3 Turbo, T56
92 Vert 349 Lunati Stroker T5
87 Gt Eddy HCI T5
87 Notch in progress
fmyth is offline
Old 08-07-2012, 07:07 PM   #4
White color is a 23 tooth speedo gear. These are known to have a short service life in Mustang applications.
The highest tooth count made by Ford is a 21 tooth. I think the 23 tooth is intended for Chrysler applications, but happens to fit Mustangs also.
The 23-tooth is used in Mustang applications when the gears are changed and the standard (up to 21 tooth) driven gears no longer work with the drive gear used in the transmission. If it is an automatic, I think you are stuck with the drive gear, as it is part of the shaft, but the T-5 can have the plastic drive gear removed from the output shaft to allow the use of a 21 or less tooth driven gear.
This page has a table showing the drive/driven gear combos possible.
Ascaris is offline
Old 08-07-2012, 07:15 PM   #5
max.b's Avatar
car is an 85 so it came with a 7tooth drive. i swapped in a 21 tooth to correct for the 3.73s so hopefully im good. its a t5 even though the drive gear is changeable its not as easy as swapping the driven haha
__________________
max.b is offline
Old 08-07-2012, 07:46 PM   #6
SlowBox's Avatar
That's some good information. What's the difference between the T5 tailshaft and C4/C5? I have 3.55 gears and the speedo reads around 10mph high.
__________________
Originally Posted by TucK7 View Post
Go back to working on your cars in the back yard.
SlowBox is offline
Old 08-07-2012, 08:39 PM   #7
max.b's Avatar
the t5 tailshaft has a plastic changeable grive gear. the autos have it machined into the shaft.
__________________
max.b is offline
Old 08-07-2012, 09:17 PM   #8
Michael Yount's Avatar
If you can pair up the 21 or 23 tooth driven gear with a 7 or better yet, an 8 tooth drive gear, they'll generally hold up ok. But if it's with a 6 tooth drive gear, they generally get chewed up pretty quickly. When I was originally setting up my car I had a 21 tooth on a 6 tooth drive gear - lasted 17.8 miles. Went with an 18 tooth and recalibrated the speedo. The 18 tooth/6 tooth combo lasted for 10 years/35k miles. Changed from the stock Dana rearend to a Ford 8.8, went with 3.55's and a bit of a taller tire - and dropped down to a 16 tooth.
Moral of the story - if you have to use a high tooth count driven gear, pair it with a high tooth count drive gear in order to make it live. Changing the drive gear requires pulling the tailshaft housing off.
__________________
Michael Yount - Charlotte, NC - 82 Volvo 242 - 5.0L, T5Z, 8.8" rear; 2008 Mini Clubman; 2000 Honda Accord
Michael Yount is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
