Contour Electric Fan Install. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 40 Old 05-22-2012, 04:57 PM Thread Starter
Nolan592's Avatar
I just got done installing my contour dual electric fans on my 91GT. I spent ALOT of time on here and searching the internet to gather all the info I needed to get the project started so I figured I would share how I did it.
The reference I followed to get it done was this article here:
http://www.musclemustangfastfords.co...ade/index.html
The only thing I ran into was the fan shroud was a little wider than my Be Cool radiator but I just used some foam strips to seal the gaps.
First I got the fans mounted on my Be Cool Radiator using the push through ties.
Then I got all the wiring done on the fans.
I mounted the Flex a Lite 31147 fan controller on the passenger side fender where the factory air box used to be.
I mounted the 40a relay by the battery.
Once I got the wires ran from the fan controller to the relay I put the radiator and fans in place.
Then i went on and got all the wired tied together and hooked up and got the temp probe installed through the radiator.
Even with the over sized radiator I still have plenty of room between the fans and the crank pulley ( about an inch or so )
It took a few hours to get it all done but it wasn't difficult at all. This is a project that anyone can tackle.
I know there are other threads about this install but I figured I would share my experience and hopefully help out anyone else that is in the same situation I was in.
Let me know what you guys think.
92 GT, Green/Grey, MM Control Arms, FMS B Springs, Bilstein HD Shocks & Struts, OEM 03/04 Cobra Brakes and Wheels
Nolan592 is offline
post #2 of 40 Old 05-22-2012, 05:25 PM
Michael Yount's Avatar
If you don't have the proper plug for the relay, it's always a good idea to fully insulate the female plugs. You've got hot terminals there that are exposed -- easy for 'accidents' to happen.
Other than that - looks like you've got a solution that works for you.
Michael Yount is offline
post #3 of 40 Old 05-22-2012, 05:28 PM Thread Starter
Nolan592's Avatar
That is a very good point, I never even thought about that. Im definitely gonna get that changed to the ones with a cover. Thanks man
Nolan592 is offline
post #4 of 40 Old 05-24-2012, 06:49 PM Thread Starter
Nolan592's Avatar
Much better now.
Nolan592 is offline
post #5 of 40 Old 05-26-2012, 05:40 PM
awsome! i think i might just how to try this. Did you end up reusing the stock overflow tank?
FoxBoxGT is offline
post #6 of 40 Old 05-26-2012, 06:05 PM Thread Starter
Nolan592's Avatar
No, I don't have an overflow on it yet. I'm not sure if the stock one will fit, it might but I think I'm gonna run an aftermarket one somewhere else. I haven't quite figured out where yet.
Nolan592 is offline
post #7 of 40 Old 05-26-2012, 09:56 PM
Does anybody have a wiring diagram to use these fans, just curious...?
Jrock1109 is offline
post #8 of 40 Old 05-26-2012, 10:03 PM Thread Starter
Nolan592's Avatar
Are you wanting to wire it up with the relay and fan controller?
Nolan592 is offline
post #9 of 40 Old 05-26-2012, 10:15 PM
Yes sir.... Relay and fan controller just like you used bro! Now I bought a bosch relay that had a wiring harness socket that plugs into the relay, but the wiring gauge is only 16-14awg at best, I probably need to use 10awg everywhere right and fuse the constant 12volt source to at least 40 amps right...?
post #10 of 40 Old 05-26-2012, 10:43 PM Thread Starter
Nolan592's Avatar
For wiring, we used a T-tap connector to pick up the key-on positive signal from the coolant overflow sensor harness and connected that to the key-on source on the temperature control unit. From there, we ran a wire to the 40-amp relay and its switch terminal (86 pin). The relay was then grounded on the 85 pin and a 12-volt constant power source was fitted to the 30 pin. The positive 12-volt output (87 pin) was then connected to the electric fan positive leads.
This is exactly how I wired mine up. I just followed the article.
Yea you don't want to use to small of wire. I would use the 10g wire.
Nolan592 is offline
post #11 of 40 Old 06-07-2012, 02:27 AM
Did you fuse that 30pin wire on that relay...?
post #12 of 40 Old 06-07-2012, 05:51 AM
boostdcoupe's Avatar
Trader Feedback: (30)
good work! good pics!
replaced the 93'ish coupe with a 64 falcon hardtop, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, C4.
boostdcoupe is offline
post #13 of 40 Old 06-07-2012, 08:56 PM
That coolant overflow sensor key on source keeps blowing the 20 amp inside TE car, but with a 25 amp it will buy not right away and with a 30amp fuse it won't blow, just curious if I used the right key on source, but the mustang article mentioned using it so just wondering.....
post #14 of 40 Old 06-07-2012, 09:04 PM Thread Starter
Nolan592's Avatar
No not yet. I forgot to do it when I did the install. There will be one on there though.
Nolan592 is offline
post #15 of 40 Old 06-07-2012, 09:05 PM Thread Starter
Nolan592's Avatar
Thanks man
Nolan592 is offline
post #16 of 40 Old 06-07-2012, 09:06 PM Thread Starter
Nolan592's Avatar
That's where I hooked mine up to. I haven't had a chance to turn them on yet. My car isn't all the way back together yet. Once I try it out I'll let you know how it goes.
Nolan592 is offline
post #17 of 40 Old 06-07-2012, 10:12 PM
How big of a fuse do I need to use you think on that 30 pin wire, you think a 40amp fuse would be to big?
post #18 of 40 Old 06-07-2012, 10:14 PM Thread Starter
Nolan592's Avatar
Im pretty sure that's the one you wanna run. A buddy of mine is running pretty much the same setup and I think that's what he is using.
Nolan592 is offline
post #19 of 40 Old 06-07-2012, 10:53 PM
Ask him about that key on issue I'm having would you, I really not liking overamping the coolant overflow circuit....
post #20 of 40 Old 06-07-2012, 11:31 PM Thread Starter
Nolan592's Avatar
I'll ask him tomorrow and let you know. You could always run it to the fuse that runs the cigarette lighter or tie into the the 12v for the stereo. They are both key on sources and might handle a little more juice. Just a thought.
Nolan592 is offline
post #21 of 40 Old 06-08-2012, 09:48 AM
Thanks again bro, definitely get back with me please.....
post #22 of 40 Old 06-08-2012, 11:55 AM Thread Starter
Nolan592's Avatar
He said he is using a 40amp fuse and either ran the wire to the opposite side of the solenoid or to the fuse panel. He said he can't remember. Hope this helps.
Nolan592 is offline
post #23 of 40 Old 06-11-2012, 09:05 AM
toddyfiveo's Avatar
Does the alternator need upgraded for these fans like with the Mark VIII fans?
toddyfiveo is offline
post #24 of 40 Old 06-11-2012, 09:28 AM Thread Starter
Nolan592's Avatar
Yea it will need upgraded. I used a powermaster 140a or you could do the 3G upgrade.
Nolan592 is offline
post #25 of 40 Old 06-11-2012, 10:30 AM
Seems to me your key-on source should just be used to 'trigger' the relay -- it will take virtually no current at all for that. Your power "in" to the relay can then use an inline fuse (whatever size you need) and be run straight from the positive terminal of the battery or the output bolt on the alternator. If you're blowing 20A and 25A fuses, you're pulling the power for the fan through the coolant circuit. Makes no sense at all to me.
post #26 of 40 Old 06-11-2012, 05:17 PM
skeletonpsycho's Avatar
70 amp relay should be used,no t-taps as there are better ways to do it,ron francis makes a really nice affordable relay kit
skeletonpsycho is offline
post #27 of 40 Old 06-11-2012, 05:20 PM
post #28 of 40 Old 06-11-2012, 05:23 PM
heres a pic of the ron francis unit,comes with a maxi fuse
post #29 of 40 Old 06-12-2012, 08:17 AM
My question is this what is generally the trigger pin on the relay, 86?
post #30 of 40 Old 06-18-2012, 08:36 PM
Contour Fan
I am about to tackle this mod, but wanted to know if the dual fans from a Contour had to come out of a V6 model? I found only four cylinder models in the junkyard this weekend, and two of them had dual fan setups.
Will the dual fans out of the four cylinder cars work too?
snakedoc257 is offline
post #31 of 40 Old 06-18-2012, 09:08 PM
DuffManRHA's Avatar
Trader Feedback: (21)
Sub'd for possible use in the near future.
Install looks really good BTW!
94-04 Mustang Cobra Tech and DIY projects - dbdragster.com
'99 Cobra - #256 of 4055
'88 LX 5.0 - Deceased
DuffManRHA is offline
post #32 of 40 Old 06-18-2012, 09:36 PM Thread Starter
Nolan592's Avatar
I do believe you want the one out of a V6... Correct me if I'm wrong
I bought mine from summit though.
Nolan592 is offline
post #33 of 40 Old 06-18-2012, 09:37 PM Thread Starter
Nolan592's Avatar
Thanks man
Nolan592 is offline
post #34 of 40 Old 06-18-2012, 09:51 PM
DuffManRHA's Avatar
How does this unit compare to the Taurus 3.8 fan? I've found those in my research as an alternative to the Mk8, just like the Contour fan is also, but how do the Contour and Taurus fan compare to each other? Or are they the exact same fan?
post #35 of 40 Old 06-19-2012, 02:48 PM
Nitrous SSC's Avatar
Keep an extra relay handy in the car. I don't know if those fans will cook it or not. After my experiences with electric fans 75amp minimum is what I use for the relays if I'm not using a fan controller.
Bonneville 130 club member. (139.993) 11.48@123 in the 1/4.
Nitrous SSC is offline
