Clutch Friction Disc Visual Inspection?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-26-2012, 09:26 AM Thread Starter
Seasoned User
Trader Feedback: (95)
Looking to buy a used centerforce this weekend locally but not sure what to look for in a used clutch. How do I tell if the friction disc is low on material is it just how close its getting to the rivets? Anything else I should look for? Thanks guys
Animal is online now
post #2 of 4 Old 04-23-2012, 08:26 AM Thread Starter
Seasoned User
Anyone.
post #3 of 4 Old 04-25-2012, 10:45 AM
Ok, I've got a disc in my garage that I replaced after doing a trans swap and when I pulled it it mic'd the same thickness as the new spec unit I installed, it had very low milage.. So I went out and measured it and it is .300" thick. If you have a 0-1" mic or a dial caliper use that number to compare as new.
If you don't have a mic or caliper, you can use a scale(finely graduated ruler) with a good eye..
5/16= .312
9/32=.281
1/4=.250
Personally, I wouldn't buy a used disc unless it was practically new. I don't know what the minimum usable thickness is, but hope this helps...
93lxreef is offline
post #4 of 4 Old 05-01-2012, 08:48 AM Thread Starter
Seasoned User
Thanks for the specs.
