Adjustable clutch cable nut - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-20-2012, 12:05 PM Thread Starter
I have an adjustable clutch cable and I seem to have lost the nut that threads against the clutch fork. Is there any where that sells that kind of nut with the rounded end or do I have to purchase a new kit?
1987 LX T-Top. Stock 302 w/ windage tray, aluminum flywheel, Thumper E7, Tmoss lower, FTI cam, 65mm tb, 80mm maf, 1.7rr, longtubes, S trim 2.95/6.87, upr boost pipe, 42#, 90/10, 50/50, 4 cyl springs, 4.30 gears ETC. Tweecer r/t tuned.
FOXRACER5_0 is offline
post #2 of 7 Old 02-20-2012, 12:15 PM
SlowBox's Avatar
It's just a regular self-locking nut with a nylon insert. Take your thread pitch and go to Lowes.
1989 Mustang GT original oxford white 5.0 5 speed. Stock with GT-40 intake and throttle body, & Motorsport B303. Tuned by yours truly with a Moates QH and TunerPro RT. Daily driven!
SlowBox is offline
post #3 of 7 Old 02-20-2012, 12:16 PM
Wicked03GT's Avatar
Trader Feedback: (49)
Ditch the entire clutch cable before it snaps on you and leaves you stranded, all adjustable aftermarket cables are junk and snap without warning. Usually within a year of install...
The standard Ford cable from Auto Zone that is like $30 is the best cable you can get and will last for near the life of the car...Or you can be a MM fan boy and buy a Ford cable from them for $70
Wicked03GT is offline
post #4 of 7 Old 02-20-2012, 12:29 PM Thread Starter
The regular ford cable from autozone is not threaded. I need one that is threaded so I can adjust it.
As for it being a self locking nut the one that originally comes with it is rounded so that it fits in the groove and turns agains the clutch fork.
post #5 of 7 Old 02-20-2012, 12:53 PM
Wicked03GT's Avatar
Adjust it with a firewall adjuster...Im telling you, you will be REALLY sorry your ran that aftermarket adjustable cable.
post #6 of 7 Old 02-20-2012, 01:34 PM
TwoToneHatch's Avatar
Like SlowBox said just go to a hardware store and get a self locking nut . And as for the adjustable cable hate , I've ran a BBK adjustable cable for 2 years and now it's on a buddy's car and it's still standing up to the abuse .
-Brandon '89 Mustang GT
TwoToneHatch is offline
post #7 of 7 Old 02-20-2012, 02:47 PM
GT347SC's Avatar
I've got an adjustable cable that's been in service for 7 years so yes they last. As for the nut I know the piece your looking for but don't know where to find one. May look for a tapped collar and use two nuts to make the jamb nut.
Sent from my DROID RAZR using Tapatalk
92 LX 351 T5--89 GT 347 T5--91 LX 5.0 AOD
88 LX 302 T5--93 LX 2.3 A4LD
GT347SC is offline
