aod wont shift on 88 mustang - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 01-11-2011, 05:47 PM Thread Starter
Trader Feedback: (26)
My dad bought an 88 mustang Gt Convertable. It has the aod in it and it will not shift out of 1st gear. The car is going to be towed to my house where I can check it out. What all can I check before pulling the tranny to see why it isn't shifting. I have never messed with an aod (I am a 5 speed kind of guy) so even the stupidest things to check will be helpful. Thank you for your help.
Mark
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, 408 super Vic intake, high port heads, pro system 1000cfm carb, inductions solutions sledge hammer nitrous system, glide. Full TeamZ suspension.
FordFreak300 is offline
post #2 of 6 Old 01-11-2011, 09:25 PM
THELAW1's Avatar
Checked the color of the fluid...if it's brown or dark....it's toast....check the shift cable on the throttle body to see if it came a loose...but mostly likely...if it just rev up without moving...time for another trans
89 Reggatta blue,Trickflow Intake,
1in spacer.65mmTB,GT-40 aluminum heads(X303),3000 Dynamic Converter, Motorcraft plugs 32c's ,E-cam,24lbs Injectors,Pro-M 76mm Mass air , AOD,shift-kit, modified valve body, 410 gear, Eaton
THELAW1 is offline
post #3 of 6 Old 01-11-2011, 10:19 PM Thread Starter
I have not driven the car or seen the car yet. But from what I understand it goes great in 1sr gear with no slipping.
post #4 of 6 Old 01-11-2011, 10:44 PM
THELAW1's Avatar
If it don't go into 2nd and 3rd and Overdrive, (Overdrive being the weakest gear which to go first)...then it's toast
THELAW1 is offline
post #5 of 6 Old 01-11-2011, 10:44 PM
I would check the TV cable first and foremost. Its the cable on the throttle body that's closest to the passenger fender. If its not adjusted properly it can reek havoc on the transmission shift points. Also get a new grommet for the cable to sit in on the TB, usually they are worn out or missing. Also check fluid level.
90SilverNotch is offline
post #6 of 6 Old 01-12-2011, 04:23 PM Thread Starter
thank you for the replies. it turns out the TV cable was not connected at the throttle body. The clip that holds it was broke. Thank you for all your help.
