TANK FUEL LEVEL SENDING UNIT (was "Fuel Gauge wont work..... Anyone got an answer") - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 58 Old 04-25-2002, 11:15 AM Thread Starter
Fuel gauge problems!!
The fuel gauge in my '89 coupe just doesnt fuction right. The needle stays tacked to the top showing I have a full tank even though I may only have a 1/4 tank. It used to fall back down showing the correct fuel level once the amount was at or below a 1/8 of a tank but it didnt do that today and I ended up running out of gas on the interstate because of it. Once again the gauge was showing a full tank of gas when I ran out.
From what I have heard there can only be three possibilities that could cause this. The fuel level sender in the fuel tank. The gauge itself or the slosh module located behind the gauge. Does anyone have any experience with this?
thanks
Moderator Edit: Replies 1 through 10 are an older thread merged to the current one.
Horspwr is offline
post #2 of 58 Old 04-25-2002, 12:07 PM
cmichael00's Avatar
mine does something very simular, it sits at the top till it is about a half left, then goes down to show a quarter is missing, then goes back up, sometimes when i get in after it has set off for a while it will show the correct but then moves back up. the stock gauges are off a little bit any way so that might be what you were thinking about. chances are its your sending unit, i am positive that is what mine is, and it drives me nuts, i do not have the extra $ to spend on one right now, so i am having to watch my milage and hope that i get close to the same everytime. if you get one when you drop your tank, you will be able to find out if it is the float also or not.
89 LX 332
07 2.5i Impreza
cmichael00 is offline
post #3 of 58 Old 04-25-2002, 12:19 PM
BaD Karma's Avatar
i have the exact same problem... bought a new sending unit... havnt installed it yet though. i hope it solves the problem.
~BaD Karma
88LX 5.0
BaD Karma is offline
post #4 of 58 Old 04-25-2002, 12:37 PM
oneqwk5ltr's Avatar
I have the same problem. Please post your fix if you find one. Thanks!
1993 Mustang GT Convertible - 41000 miles
100% stock
1987 Mustang GT - 59000 miles.
Cobra Upper/Lower Intake
65mm TB
Underdrive pullies
1 5/8 inch unequal length headers
Off Road H-Pipe
2 Chamber Flowmasters
3.73 gears
Bumped timing
Removed air silencer
FMS 9mm wires
16" Chrome pony rims
oneqwk5ltr is offline
post #5 of 58 Old 04-25-2002, 12:41 PM
I have the same problem with mine and everyone I asked says its the sending unit. Bad Karma, how much was yours and where did you buy it from?
mudtang89 is offline
post #6 of 58 Old 04-25-2002, 12:56 PM
cmichael00's Avatar
I belive it is a ford only product and it is pretty expencive... usualy are with ford only products
89 LX 332
07 2.5i Impreza
post #7 of 58 Old 04-25-2002, 12:57 PM
Sounds like either your sending unit is bad, or the float is stuck in your tank... Good lick on the fix..
Brian-Mc is offline
post #8 of 58 Old 04-25-2002, 01:08 PM
SPORT89LX's Avatar
Re: Fuel gauge problems!!
thanks
If it was the slosh module the gauge would behave erratically. Typically not the gauge since they're more robust than a fuel level sender. I've replaced quite a few fuel level sending units that did the same as you described. They loose their linearity and don't come back down until about 1/8 tank.
1989 Mustang LX 5.0l
SPORT89LX is offline
post #9 of 58 Old 04-25-2002, 02:14 PM
does anyone know what other ford/mercury models might have the same sending unit as the mustang???
post #10 of 58 Old 04-25-2002, 05:00 PM
SLVRLX5.0's Avatar
A buddy of mine had the same problem in his "88. replaced the sending unit and it was fixed. I had the opposite problem, mine stayed on empty. I replaced the sending unit 1st but that wasn't it. It was the little "amplifier" behind the gage. You can buy a new sending unit for about $67.00 on fordpartsonline.com. The part # for my 1991 (I think they are all the same 87-93) was E7ZZ-9275-A
"Second place is just the first loser"
Last edited by HELMUT RONER; 11-15-2005 at 12:58 AM. Reason: edited out sale offer
SLVRLX5.0 is offline
post #11 of 58 Old 07-01-2002, 10:36 PM
Question TANK FUEL LEVEL SENDING UNIT (was "Fuel Gauge wont work..... Anyone got an answer")
I have a 90 lx coupe and I can’t get the gas gauge too work. I tried a new gage in the cluster and checked the sending unit in the tank with no luck. What do I need to do now? Or can I buy a after market gauge or what
Darryl
Moderator edit: Link to other thread telling how to check ohms in the sending unit.
http://www.corral.net/forums/showthread.php?t=256004
Wild Thing is offline
post #12 of 58 Old 07-05-2002, 03:35 PM
MYLITTLEHO's Avatar
How did you check the sending unit in the tank??? 9 times out of 10 it is the sending unit... I took mine apart and all there is is about 12 very very thin strips of metal on a plastic computer board... as the float goes up and down it rakes accross these tiny wires triggering the gauge to go up and down.... these tiny wires were all worn off when I took it out to replace it. I wish you could just buy that tiny little circuit board.. thats the only thing that usually goes out on the sending unit unless your float has a hole in it.....
Best E.T to date 14.02 @ 98.7
MYLITTLEHO is offline
post #13 of 58 Old 07-05-2002, 03:48 PM
Member
Putz's Avatar
My guess is the sending unit.
I have one that im *pretty sure i one be using...
(_(BIGSTIK(_(
87GT, T-tops, 72K, 302cu, GT-40P heads, EH'd Cobra upper, Fox-lake Stage 3 lower, 24#rs, 70mm PRO-M MAF, 65mm TB, Scorpion 1.6" RR, F-303 cam, GT-40P headers, Dr. Gas X, Spintech sportsmans, Tremec 3550, Spec 1 clutch, 3.90 gears, MAF/A9L, 16x8 ROH Snyper
HP-266.5 TQ-286
Originally Posted by Pottus
All hail Tiresmoke.....
Putz is offline
post #14 of 58 Old 07-05-2002, 03:49 PM
When the fuel guage stopped working on my Ranger it turned out to be the lil float thingy in the fuel tank. It had gotten a hole in it and filled up with fuel causing it not to work. I was told it was a pretty common problem for cars/trucks after they get some age on them . My Ranger is a 90 model also.
gear jammer is offline
post #15 of 58 Old 07-05-2002, 03:58 PM
Where did you end up picking a sending unit, because I have the same problem in my 87 GT.
1987 Mustang GT.
Mods
King Cobra Clutch
140 Amp Alternator
Mods Coming...
Edelbrock RPM ll, Twisted Wedge Heads, Cam?, Pistons?, Rods?, Eagle Crank,Rockers?, MAF Conversion,Pro-Flow MAF, BBK Cold Air, Throttle Body...
Metallion420 is offline
post #16 of 58 Old 07-05-2002, 05:09 PM
MYLITTLEHO's Avatar
I got mine from Ford for like $95 I think... It came with both the sending unit and float assembly... Just undo the ring that holds the unit in place. replace the unit and replace the fuel tank O-ring thats included and just plug it in... it is truly a swap out, swap in thing... the hardest part is dropping the tank...
post #17 of 58 Old 10-27-2005, 08:24 PM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
Resurrecting this old thread. Since I have my tank down and out. My fuel level gauge was always stuck up until the fuel was down to about 2 or 3 gallons. When I removed the fuel level sender from the tank it was a bit stiff to move. I moved the float up and down a few times lightly and it would stick a lot. Now that it's out it's not sticking anymore. I took mine apart and those strips you described in your post are worn away. I have to replace it no matter what. Sites like www.partsamerica.com and www.autozone.com no longer list them. I think the replacements ARE in their parts look-up, but not correctly listed by car so I can't crossreference any aftermarket part numbers. I found a new old stock Ford one online and have to wait for it to get here.
Couldn't figure out the lighting with my 3.2MP Sony so these two are the best pics I could come up with.
Helmut
Originally Posted by MFE
Last edited by HELMUT RONER; 02-09-2011 at 10:41 PM. Reason: updated links to images
HELMUT RONER is offline
post #18 of 58 Old 10-28-2005, 01:01 AM
slowhatch's Avatar
I went through this on my old 90'. For me it turned out to be the replaceble printed circuit board that slides into the back of the instrument cluster. I believe it is a voltage regulator for the guages. I ended up replacing my sending unit first unfortunatly. I bought both parts from the local Ford parts house. Good luck, Dave.
347, AFR 185, FTI cam, Systemax, shorties, 2.5'' exhaust, stock airbox, 70mm tb, 75mm MAF, 24lb
387rwhp, 397rwtq, 12.35@114.6 first passes, more track times soon
slowhatch is offline
post #19 of 58 Old 10-28-2005, 01:44 AM
Super Moderator
What you are referring to is called an anti-slosh module
Helmut
post #20 of 58 Old 10-29-2005, 11:29 PM
I also have a 90 notch and the guage isnt working?? The needle is always buried like its out of fuel, so does the fuel pump assembly have to come out to replace the sending unit???? Or is there another assembly on the top of the tank that has to come out??
Satin03Cobra is offline
post #21 of 58 Old 10-29-2005, 11:38 PM
if its buried it sounds like the float is filled up, if its over full its the sending unit
p91587 is offline
post #22 of 58 Old 10-29-2005, 11:50 PM
Super Moderator
The hole in the center is where the fuel level sending unit goes. The hole on the right is where the fuel pump goes.
Helmut
post #23 of 58 Old 11-03-2005, 12:59 AM
Super Moderator
Helmut
post #24 of 58 Old 11-03-2005, 04:19 AM
LS1KLR's Avatar
Trader Feedback: (-1)
ouch.....i need a new sending unit for for 95 bucks ill just continue waiting for those last 2-3 gallons for it to drop down
LS1KLR is offline
post #25 of 58 Old 11-03-2005, 09:34 AM
Finally!
This thread has come-up again and has some great info. I replaced my sending unit 2 years ago w/ an Advance auto unit and it still didn't work, didn't want to drop the tank again. Pulled the anti-slosh module and cleaned it - didn't look fried. How do you remove that red guage-thing Helmut? Where do you get one? Can you spray some electrical lube on it? Yours looks fried! My needle is stuck on the near-empty position all the time. Guess Ford parts will be required on this one. Any wiring to check near the tank. Sick of watching the trip meter all the time!
Buddylu is offline
post #26 of 58 Old 11-03-2005, 12:56 PM
Super Moderator
That red gauge thing is the fuel level sending unit after taking it apart. In this picture you see a single tab to the right side of the middle section. You push that clip to open the housing. One the left those two tabs just unhook after you've released the clip to expose the board pictured above. I never took the board out of my old one. Now that the new one is in the tank I haven't messed with the old one anymore.
I'm inclined to believe that the fuel would wash the electrical grease off of the board since this is in the tank. I wouldn't do it.
Do you recall their part number? Don't know when they stopped doing so, but doing the parts search for this on their website by make, model, and year doesn't bring it up anymore.
Helmut
post #27 of 58 Old 11-03-2005, 01:24 PM
No part number
it was 2 years ago. Ok, I see where it is. Is a new o-ring included with the unit? Thanks for the visual aids!!!
Buddylu is offline
post #28 of 58 Old 11-03-2005, 01:29 PM
Super Moderator
No. At least not with mine.
Helmut
post #29 of 58 Old 11-03-2005, 01:49 PM
OEMfordparts.com
I entered this number into their website, but nothing appeared. Guess I'll have to get it thru the "our parts are gold" Ford dealership.
Buddylu is offline
post #30 of 58 Old 11-03-2005, 01:55 PM
Thats exactly what I am doing now before and after having installed a brand New fuel sending unit.I think my problem may be the Anti-slash Module.Maybe it just needs to be cleaned??Who knows?? Im not even sure where it is or what it loooks like??I assume its under the dash somewhere's.Sure wish I could finally fix this problem that I have had for over 6 years freakin years now.
5ltrStallon is offline
post #31 of 58 Old 11-03-2005, 02:19 PM
Anti-slosh
is behind the RH side of the back of the instrument panel. You have to take the umpteen screws out the panel, pull it back and the thing has flat pins that hold it in. Everytime I pull a dash, some brittle plastic item cracks I took mine out, cleaned the pins, but no dice. Guess it's the sending unit. I've ruled-out the guage and someone posted that the guages are not avail. anymore. Dropping the tank is the easiest part. Don't forget to use some motor oil on the filler neck when reinstalling into the tank.
Buddylu is offline
post #32 of 58 Old 11-03-2005, 02:29 PM
Doesn't seem like fun,I may have to take my front seat to fit under there. I hope in your case its just the fuel sending unit but in my case its the Gauge or the Anti-Slosh Module.
post #33 of 58 Old 11-03-2005, 02:56 PM
No, don't remove seat
You just remove the instrument panels screws and pull it back - don't remove the dash panel itself. Mine doesn't have a tilt steering wheel, so I was having fun. You pull it back (can't go far unless you undo speedo cable and reach you hand back there. It really isn't bad - you can see it if you pull the inst. panel out and go outside of the car and look thru the windshield. Sorry for saying "dash", been a long day here after spending a week in a Ford truck plant for 11 hours a day. I need to pull my tank and install Hawk pads, but could care less about working on the car this week!
Buddylu is offline
post #34 of 58 Old 11-03-2005, 11:17 PM
2stangs8689's Avatar
Trader Feedback: (26)
www.cjponyparts.com part # FSU12 $79.95 This is where I got mine from, just make sure you check the float arm adjustment before you put the tank back in your car, mine was hitting on the tank causing a false level, you may have to bend it a little to get the full arm swing.
http://www.parts123.com/PartFrame.as...=CJ_Pony_Parts
86 GT stock SOLD
83 T-Top GT.a.k.a 1UGLYFOX 9.42 @ 150 MPH SOLD
New Car...90 LX Turbo Car
http://www.youtube.com/watch?v=RLAiQkqcr2w
2stangs8689 is offline
post #35 of 58 Old 11-04-2005, 02:56 AM
JDub's Avatar
Helmut, thanks for the pics. Very helpful stuff since I've never dropped a tank before. My gauge stays at full until there's about 1/8 left.
1988 GT, scarlet red, one owner
2002 VW GTi 1.8t
2004 Buell XB12R
2008 Buell XB12R
JDub is offline
