1995 SpeedoMETER not working - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-17-2010, 08:03 PM Thread Starter
maxoctane's Avatar
I'm working on a 95 Mustang 3.8/auto. The speedo and odometer stopped working. Other gauges work fine.
Is this the cluster?
Or is there a sensor in/on the trans that sends the speedo/odo signal?
Thanks for all replies
98 GT
91 LX vert
66 Plymouth Fury
Sometimes they run
maxoctane is offline
post #2 of 8 Old 06-21-2010, 03:22 PM Thread Starter
maxoctane's Avatar
Anyone??
98 GT
91 LX vert
66 Plymouth Fury
Sometimes they run
post #3 of 8 Old 06-21-2010, 05:40 PM
StarrMan's Avatar
there is a VSS sensor on the drivers side of the tranny that runs the speedo
pic taken from another post
StarrMan is offline
post #4 of 8 Old 06-23-2010, 07:56 PM Thread Starter
maxoctane's Avatar
Thanks Starr. So I replaced the VSS and still have same problem. Any ideas?
98 GT
91 LX vert
66 Plymouth Fury
Sometimes they run
post #5 of 8 Old 06-23-2010, 11:24 PM
StarrMan's Avatar
was there a plastic gear on the end of the VSS that goes into the tranny? Did the gear look ok and not chewed up?
StarrMan is offline
post #6 of 8 Old 06-24-2010, 12:37 AM Thread Starter
maxoctane's Avatar
Yea the gear was fine
98 GT
91 LX vert
66 Plymouth Fury
Sometimes they run
post #7 of 8 Old 06-24-2010, 01:08 AM
Davis3's Avatar
Trader Feedback: (25)
i had that problem once.
peel back the loom at the VSS connector.if the wires are melted together,seperate them and tape them up.
this may have killed the speedo/rpm gauge.
it will need to be replaced
Davis3 is offline
post #8 of 8 Old 12-14-2014, 03:01 PM
speedo stoped working 95 mustang new vss new cluster all other gages work fine
Tom OBrien is offline
