INERTIA SWITCH - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-06-2009, 05:07 PM Thread Starter
INERTIA SWITCH
i have the same inertia switch in my mustang, how to reset the inertia switch ?
i found the red button switch was pressed and was hard to reset it?
BAHRAINI_STANG is offline
post #2 of 9 Old 08-06-2009, 05:59 PM
Banned
Trader Feedback: (-1)
when the button is pressed down. the system should be working normally. you should have no reason to "reset" the inertia switch, unless you have jumped the car in the air, been in an accident, or hit the switch with a hammer.
how about you start off by telling us what is wrong with your car. what makes you think that your inertia switch is bad?
post #3 of 9 Old 08-06-2009, 07:10 PM
chuckb's Avatar
they do go bad. mine did.
Inertia switch-causing prob? disconnect?
1993 Black & Grey 5.0L 5sp - Nothing but notch!
Edelbrock Perf 2.02/1.6s & Crane Gold 1.6RRs. RPMII & 3722 cam.
Bilsteins & MM stuff. 3.73s & Alum DS. BBK LTs/H pipe/Flows etc.
Dyno tuned/stock 19lb injectors 305rwhp/306tq.
chuckb is offline
post #4 of 9 Old 08-06-2009, 11:37 PM
RAP66's Avatar
+1 mine went south too... bypassed it
1991 Mustang GT: FordStrokers 347, Jay Allen cam, 42#, TFS Heads, GT40, BBK 75mm TB/EGR spacer, 90mm LMAF, T-56, Full MM suspension, SVO brakes, NRC Disc conv., Vortech V3, Kurgan Tune & Meth: 492.4 rwhp/483.1 rwtq @ 12psi
, Phantom II gauges in MC Machine Dash.
RAP66 is offline
post #5 of 9 Old 08-06-2009, 11:47 PM
Banned
Originally Posted by chuckb View Post
pretty sure I didnt say that "dont go bad" but he shouldnt have to reset it unless he did something really stupid.
anyone else replying to this thread is taking up pointless space and wasting their time... Until the OP posts what his problem is... this thread is utterly pointless
post #6 of 9 Old 08-07-2009, 12:50 PM
Well, it could go bad. You need to check continuity, and check for voltage at the switch.
I tripped the inertia switch on my Lincoln Mark VII (virtually the same vehicle mechanically as 86-93 Mustang) when I repaired my rear cowl. The repair involved a whole lot of hammering right over the switch. When I was done, no start. Hotwired the fuel pump relay, started right up. Checked the inertia switch, sure enough it was tripped.
At Menards a guy had the trunk of his Gran Marquis stuffed to the gills with stuff like plywood and 2x4s. When I came out he was spraying starting fluid into the air cleaner and it was firing. I walked over, pushed the switch, it started right up.
___________
"Sugartastic E Shizzle"
Fast Eddie D is offline
post #7 of 9 Old 08-07-2009, 01:12 PM
chuckb's Avatar
It might check out fine when the car is sitting still. The problem is when you're driving & they get shook up a little. They get over senitive sometimes when they're old/bad. That's how mine was.
chuckb is offline
post #8 of 9 Old 08-07-2009, 02:29 PM Thread Starter
thanks guys for your reply...
iam checking the list for no start condition
post #9 of 9 Old 08-07-2009, 02:35 PM
Fuel pump running? If not, hotwire it. If it starts, work backwards from relay.
___________
