DIY 8.8 rear narrowing - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 02-28-2009, 03:48 PM Thread Starter
I've got a pretty good handle on how to make a jig, get everything setup and execute this. What precautions should I take?
Its a build 8.8 with stock ends, c clips.
take the axles, c clips out set the jig up, cut at end of flanges (end of axles), reweld using jig.
I plan on using TIG with the weld.
'85 LX Sedan
Na 317
8.35/86 2.0 60'
358 Cleveland in the works. 4v
jb1kanob is offline
post #2 of 18 Old 02-28-2009, 08:42 PM
saleen9973's Avatar
sub
saleen9973 is offline
post #3 of 18 Old 02-28-2009, 09:02 PM
bottlefedgt's Avatar
what jig are you talking about? you need an alignment bar and spacers. need to keep the housing ends square and true with the carrier bearing bores. andmost likely the housing is already fairly unstraight
PM me for BILLET SHIFT FORKS! Currently made for T45,3650(all of them) ,and now the T56
bottlefedgt is offline
post #4 of 18 Old 02-28-2009, 11:17 PM
460capri's Avatar
Trader Feedback: (48)
Take the rear housing to a shop and have them weld on 9" ends I paid my shop 200.00 to narrow the rear 2.25" each side and weld the axle tube to the center section and weld on a rear support brackets . Go here http://www.cardomain.com/id/capri460 to see more of my car and the work I did on the rear . Good luck .
460capri is offline
post #5 of 18 Old 03-01-2009, 09:03 AM
feetfirst's Avatar
Absolutely.........I ordered the spacers from these guys, and got the bar from my local metal fab shop....... http://www.mittlerbros.com/rear_end_...ccessories.htm
Pump gas 501 BB Ford......
28 x 10.5's - stock suspension
feetfirst is offline
post #6 of 18 Old 03-01-2009, 10:04 AM
that is EXACTLY what i ended up with when i made mine a few years ago
post #7 of 18 Old 03-01-2009, 10:11 AM Thread Starter
Those look nice.
With respect to the 9 inch ends, i already have the rearend built and together with the axles and c clips. I would rather just stay with what I have since the axles are 35 spline, gundrilled and star flanged. I thought you have to order new axles with the 9 inch ends?
With the jig, I would make it myself.
I already have a 1 inch round tube brace welded on underneath from each coil over bracket (rear coil overs....its mini tubbed) that goes underneath the center.
Can i still do this?
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #8 of 18 Old 03-01-2009, 10:12 AM Thread Starter
Was that $200 total? Seems like a good deal.
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #9 of 18 Old 03-01-2009, 10:29 AM
Rich G's Avatar
Trader Feedback: (35)
Will a tig be able to weld the rear? The chassis shop that did mine said it takes ALOT of welder to weld the thick cast iron of the rear end housing
Rich G.
Rich G is offline
post #10 of 18 Old 03-01-2009, 10:44 AM Thread Starter
Hopefully i wont have to weld the center of the rear housing just the tube ends
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #11 of 18 Old 03-01-2009, 11:02 AM
Originally Posted by jb1kanob View Post
Those look nice.
yes but youll have to reuse the ends off your housing. unless somebody is makng them now. they werent years ago when i did mine and had to reuse what i had. and if youre not using a jig like from above id like to see it cause it needs to locate off the bearing housing
post #12 of 18 Old 03-01-2009, 11:07 AM
if you have something that needs 35 spline axles, you better be doin that BEFORE you do the shortening.and it better be braced too
post #13 of 18 Old 03-01-2009, 11:39 AM
460capri's Avatar
Yes just the labor cost cutting the rear down , welding on the 9" ends , welding the housing and installing the axle brace .
460capri is offline
post #14 of 18 Old 03-01-2009, 12:06 PM Thread Starter
Ill have look ask around
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #15 of 18 Old 03-01-2009, 12:07 PM Thread Starter
The tubes are already welded to the center and the whole thing is braced.
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #16 of 18 Old 03-01-2009, 12:08 PM Thread Starter
Ok, great. Now need to figure out if i can weld 9 inch ends on and still use these axles.
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
post #17 of 18 Old 03-01-2009, 01:11 PM
Rich G's Avatar
sure you can, you just have to get the proper bearings, seals, and wedding rings..
Call up strange and they will hook u up
Rich G.
Rich G is offline
post #18 of 18 Old 03-01-2009, 02:03 PM Thread Starter
Good to know. Thank you
Anyway, back to the original, given that i can weld and setup a jig are there any other precautions I need to take to pull this off? Im thinking it wont be that difficult.
'85 LX Sedan
Na 317
8.35/86 2.0 60'
jb1kanob is offline
