Removing autometer gauge bezel? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 12-29-2008, 11:40 AM Thread Starter
Has anyone done this? I have water/condensation in my gauges and can't get the black bezel ring off. Can this be done without destroying the gauge?
DJ96GT is offline
post #2 of 4 Old 12-29-2008, 01:08 PM
Markus's Avatar
You can remove the bezel. But back no way.
Put the gauge upside down on a heater and remove the bulbs on the back side.
I remove the bezels to fit the autometer in my cluster. Please donĀ“t copy this
Anatomy of a autometer gauge.(no more warranty)
67 fastback, 331stroker EFI,AFR185, Ed Curtis custom cam,Tremec TKO,3.55:1,MSD Atomic,borgeson.
68 coupe,306,edelbrock e-street heads,fti cam and springs,borgeson,c4.
Markus is offline
post #3 of 4 Old 12-29-2008, 04:33 PM
jcal's Avatar
I dont have photos but i bought a boost gauge off ebay and when i got it instead of 0 it was reading 2#,,,I ended up cutting the gauge all the way around on the white round part with a die grinder, I got it on zero and epoxied it back together...it worked out good,,but i would try what Markus suggested with the heater first
89 LX 5spd, TFS,heads,cam
jcal is offline
post #4 of 4 Old 12-29-2008, 05:29 PM
GT347SC's Avatar
I have opened up several and put them back together with no trouble. I used a very small flat head screwdriver from the backside where the ring is crimped against the plastic housing. Got it started under the ring and SLOWLY worked aroung the guafe many times and at one point even got a little larger screwdriver and worked it around untill the ring is opened up ehough to get it apart. Then used the but of the screwdriver to roll the edge back down. It wont look as good at origional but i left that since it was on the back i did not care. The key is to go slow. For your moisture i would try the heater first though.
GT347SC is offline
