How much does a mustang weigh? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 12-21-2008, 02:04 AM Thread Starter
BlackSunshine02's Avatar
I have a 2002 mustang GT with 5 spd and leather inter. with bullets and mach 460. How much does it weigh stock?
I also looked for how much parts weigh and couldn't find it on the search here?
I wanna put car on diet!
Criminally Insane Racing
1990 Mustang GT Black 306 with stuff
2011 Mustang GT Silver/Black 6speed with3.73's and vortech - SOLD
2002 Mustang GT Blk/Blk 5speed with 3.90's and a 125shot- SOLD
FIRST COAST MODIFIED MUSTANGS
BlackSunshine02 is offline
post #2 of 29 Old 12-21-2008, 02:20 AM
badass03gt's Avatar
a stock mustang gt weighs 3379 from the factory. how much are u trying to lighten the car?
17 inch Deep dish mach ones, Powerslot rotors, Hawk pads, , 15% tint all around.Mods gone starting over sucks!!!!!
badass03gt is offline
post #3 of 29 Old 12-21-2008, 02:26 AM
ARCANGL's Avatar
Trader Feedback: (76)
i weighed my 04 a few weeks ago...
3180lbs
Mach 460, Leather, etc.
No ABS, no trac control
only weight reduction was no spare tire... only 1/8th tank of gas
alum DS, and LT's weigh less than iron manifolds
ARCANGL is offline
post #4 of 29 Old 12-21-2008, 03:03 AM Thread Starter
About 300lbs, Got my Azz spanked by that Blue GT at the racetrack. Also I'm going on a diet I weigh 212lbs and I'm dropping down to 190.lbs
post #5 of 29 Old 12-21-2008, 03:06 AM Thread Starter
Looking to get car down to 3,000# with 1/2 tank of Gas.
Will switch to fatties and skinnies ( weld Rod lites)
I have an ALUM drive shaft.
post #6 of 29 Old 12-21-2008, 11:02 AM Thread Starter
Just Keep in mind I am not installing a K-Member and this is my DD
Give me your ideas on how to lighten this pig up.
post #7 of 29 Old 12-21-2008, 11:10 AM
If you get control arms for the rear take off the quad shocks and the dogbone on the differential. You can look into a rear seat delete unless you have more than two passengers.
Although not weight reduction, you could move the battery to the trunk. That puts more weight over the rear tires while taking some off the nose. I would look into coil overs too.
2000 Mustang GT- Gears, X-pipe, catback, pullies, DRs.
13.21@103.55 1.85 60ft.
2kMustangGT500 is offline
post #8 of 29 Old 12-21-2008, 11:20 AM Thread Starter
Dogbone? do you mean that big weight on the differential?
Car has UPR uppers and lower CA.....Chromoly.
post #9 of 29 Old 12-21-2008, 11:40 AM
ARCANGL's Avatar
yes thats the dogbone...
and if you dont have them already, LT's and on o/r mid will save some weight over iron logs and stock catted H, not to mention gain a good bit of power.
it will be very hard to get down to 3000 without resorting to a tubular front end.
ARCANGL is offline
post #10 of 29 Old 12-21-2008, 11:49 AM Thread Starter
The car has full interior.
BBK shorty headers
BBK catted X pipe
Flowmaster CB
Full Length sub frames
UPR Contral arms
3.90 gears
125 shot of the good stuff
CAI
March crank pulley
SLP line lock
Stewaet evans Water pump
TB and plenium
Moser axles
Bullet wheels
any Ideas to lighten it up?
post #11 of 29 Old 12-21-2008, 12:26 PM
corbeau Forza's weigh only like 19lbs... ditch your stock front seats in favor of those or something similar and you're down an instant 100lbs.
Good judgement is gained from experience, experience is gained from bad judgement. Via Jack O'Conner
r3dn3ck is offline
post #12 of 29 Old 12-21-2008, 12:58 PM
badass03gt's Avatar
leather seats weight that much?
post #13 of 29 Old 12-21-2008, 01:06 PM
ARCANGL's Avatar
Official Weight Removal Thread
a good read... and most of it applies to 2 valves as well
ARCANGL is offline
post #14 of 29 Old 12-22-2008, 01:05 AM
the seats plus the brackets (with power driver seat) and the power seat crud weigh an astonishing amount. The pump and all the crud under the driver seat (connected to the bracket) weighs like 35lbs all by itself.
r3dn3ck is offline
post #15 of 29 Old 12-22-2008, 01:19 AM
Pull the rear seat, but don't install a seat delete as they weigh around 20-25lbs I believe...
When you go to the track pull the spare tire and jack.
2000 GT 5 speed... WOOT!
Almost stock.
burningtire is offline
post #16 of 29 Old 12-22-2008, 01:28 AM
badass03gt's Avatar
wow the rear spoiler weights 8 pounds. Thats something i wouldnt have guessed. That thread was really good arcangl
post #17 of 29 Old 12-22-2008, 04:47 AM
My 98 weighs 3145 w/o driver with:
Mach 460
All A/C and heating stuff
Power locks/windows
Spoiler
Almost empty on gas
No spare tire or jack
With passenger side leather seat
No ABS or cruise control
Off-road X-pipe, stock exhaust manifolds
Weight additions:
Tremec TKO w/ Lakewood scattershield (~25 lbs heavier than stock)
Full length subframe connectors (~30 lbs heavier than stock)
SVO intake (~15 lbs. heavier than stock)
Battle Boxes (~10 lbs heavier)
Weight Reduction:
Removed front swaybar (~20 lbs lighter)
Removed dogbone (~8 lbs)
Removed rear seat with custom delete kit (~30 lbs lighter)
HO fibertrends cowl hood (~20-25 lbs lighter than stock)
Aluminum driveshaft (~7 lbs. lighter than stock)
Prostar Bigs and Littles (~70 lbs. lighter than stock 275-40-17's on all 4's on stock GT wheels)
Aluminum LCA's (~8 lbs. lighter)
Sealed Lead Acid Battery (like Dynabatt)- (~25 lbs. lighter)
Bro, in order to hit 3000 lbs, you'll need to ditch A/C, spoiler, passenger seat, foglights, carpet, door trim, Mach 460 junk, and airbags. Plus my weight reduction and not do my "weight additions".
1998 Mustang GT
Stock NPI block/heads, PI cams, SVO intake, bolt-ons- N/A
13.01 @ 103 1.76 60'
Blue 98 GT is offline
post #18 of 29 Old 12-22-2008, 08:24 PM
this is probly the best example your gonna get
mine is a 2001 bullitt with 18x9 and 18x10dd bullitts, bassani catted x, slp lm2, full interior, spair tire and jack, 3/4 tank of gas, me not in the car
01 dhg bullitt --- bolt ons and some spray
92 lx --- bolt ons and spray- SOLD
90 gmc 2500 on 35s
2 raptor 660's with some mods
jeffs89gt is offline
post #19 of 29 Old 12-22-2008, 10:58 PM
badass03gt's Avatar
very nice. sharp car Jeff
post #20 of 29 Old 12-23-2008, 09:12 AM Thread Starter
That's what My car looks like Just install a cobra R hood and make the bullets chrome.
post #21 of 29 Old 12-23-2008, 09:36 AM Thread Starter
A/C compressor and lines = 36lbs
Both leather front seats = 83 lbs
Stock 4 cat h-pipe = 48 lbs
Back seat assy = 53 lbs
My own custom back seat delete = 12 lbs. Pics on me web site. Saved 31 lbs
Rookie MOMO coarse racing seats 11 lbs each. Saved 72 lbs
AC delete bracket 5 lbs. Saved 31 lbs
Off road h-pipe is 22 lbs. saved 26 lbs
Total I pulled 160 lbs from my Stang from these four mods...DA Snake Boy!!!
I just read this I will try it well maybe not the AC delete I do Live in Florida.
post #22 of 29 Old 12-23-2008, 10:29 AM
kevman's Avatar
Rip out hood insulation? Even seen guys pull off bumpers and lose the foam-looking impact stuff. They claimed it was like 20-30lbs.??
Kevin
kevman is offline
post #23 of 29 Old 12-23-2008, 10:52 AM
ARCANGL's Avatar
you'd have to pull the actual bumper supports to lose even close to 20-30 lbs
that foam weighs like nothing
ARCANGL is offline
post #24 of 29 Old 12-23-2008, 11:03 AM
BULLITT1992's Avatar
Agreed. In fact in the Mathis book it recommends that if you remove your bumper that you should fill any voids with expanding foam because it maintains the shape but weighs very little.
If you have the cash you can go to LT's and O/R midpipe. That would be good. Lightweight racing seats are a good savings over the stock leather. Do a rear seat delete and just use some matching carpet on the lower piece to make it look right. I'm not sure how much the LT's save versus the stock manifolds but you could be in the neighborhood of 150# total with the above.
2001 Mustang Bullitt #01992
BULLITT1992 is offline
post #25 of 29 Old 12-23-2008, 11:19 AM
hbk_136's Avatar
Trader Feedback: (62)
+1
96 Triple Black GT Vert Supercharged -- 401rwhp / 394rwtq
Vortech V1 S-Trim @ 10psi--2003 PI Engine--36# injectors--90mm L-MAF--AFM PowerPipe
Accufab Plenum + 70mm TB--BBK LT's--MAC O/R Prochamber--Magnapaks
F+R 13" Brakes--3.55's--255lph Pump & T-Rex--Snow Stage 2 Meth Kit
hbk_136 is offline
post #26 of 29 Old 12-23-2008, 12:26 PM
mogs01gt's Avatar
It depends on the options. A stripped GT can weigh 3200 while a fully loaded GT with the mach1000 system could be closer to 3400.
mogs01gt is offline
post #27 of 29 Old 12-23-2008, 01:15 PM
my drivers seat weighs 62lbs itself....
90 gmc 2500 on 35s
post #28 of 29 Old 12-23-2008, 01:19 PM
id rather keep my interior, seats, ac, ps and other stuff and just do another mod or 2... why srip down a car for 200lbs and loose the nice comfort and look of it... even if you do gain .2 of a sec in the 1/4 mile (.1 sec = to ruffly 100lbs) most people could gain more by a set of slicks and learning to drive better... if its a race car then gut it but if its a dd or a weekend car i wouldnt bother...
90 gmc 2500 on 35s
post #29 of 29 Old 12-23-2008, 02:04 PM
badass03gt's Avatar
yeah i agree with you jeff. all i want is consistent low 12's out of my daily driver gt. and i want to do it with a full interior.
