Anyone have issues with Prothane trans mount being taller? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-31-2008, 12:29 AM Thread Starter
BadAss88GT's Avatar
I put a Prothane transmission mount in my car and now the shifter boot bezel wont snap in to place, the trans seems to be sitting a bit higher. Anyone else run into this? Thanks-Dan
BadAss88GT is offline
post #2 of 7 Old 07-31-2008, 08:59 PM
Cougar5.O's Avatar
Stock tranny?
Was the old mount colapsed?
'87 20th Anniversary Cougar 5L, 2L KB, AFR165's, XE270HR-12 cam, 42lb. inj, 85mm Accufab, 97mm MAF, TKO-500, Eaton Trutrac + 31 spl. Moser axles. DIY H2O/Meth inj, tuned w/TwEECer & LM-1 WB. 11.9 @ 118 MPH
2012 GT500
Cougar5.O is online now
post #3 of 7 Old 07-31-2008, 09:18 PM
avbcon12's Avatar
Trader Feedback: (26)
I do believe they make different heights because you need a taller one when swapping in a tremec (3550/tko).
90 GT black, V2 SI-Trim, Blow-Thru A/A Intercooler
stage 3 "Y" heads/ Bennett Racing intake, TFS#1, long tubes, 3"Pro-Dumps/H-pipe, TKO500, 3.55's, Home made TA and PHB, cobra brakes, 22 gallon Fuel Safe Cell, PMS tuned etc.. built for twisties
avbcon12 is offline
post #4 of 7 Old 07-31-2008, 09:36 PM Thread Starter
BadAss88GT's Avatar
Stock trans. I wonder if I was sent the wrong one, I didnt know there were different heights. Great, now I'm stuck with this thing.
post #5 of 7 Old 07-31-2008, 11:42 PM
Im alittle confused. The shifter brezel should not be affected by the tranny being a little higher. It snap into place on your center plastic consol.
I run prothane tranny mount dont seem to have a problem. They dont make different hieghts, they only sell one for the foxbody stang. I have run the same mount on my t5 before switching to the TKO500.
I have however run in to a height difference on the prothane motor mounts they do make the motor sit about a half to a inch higher.
88lx Conv. 200K mile stock longblock. Trickflow intake, 42lb inj, Pmas protube,TKO500, 3:27, pypes muffs, Pa Racing tubluar K-member, DIY single turbo setup. Summit aluminum rad, Crane Hi-fire ign, subfames, 17" sc saleen's, Saleen ground effects, SCT tune by Dynosport. 380HP 435ftbs.
71swing is offline
post #6 of 7 Old 08-01-2008, 12:22 AM
avbcon12's Avatar
FYI, the tremec tailshaft center line is about 1/2"-5/8" higher than the t-5. usually when people switch to a tremec the trans needs to be shimmed up at the mount to maintain stock geometry.
avbcon12 is offline
post #7 of 7 Old 08-01-2008, 03:02 AM
Yes, I uderstand that, infact I have My TKO shimed as well, but that does not relate to the fact that there is only one tranny mount option for the mustang.
71swing is offline
