#1 |
Reviving a gel cell battery?
Hello,
I let my optima red-top sit for about 2 months and yesterday it was down to about 4.0 volts. I tried my trickle at 2A and after about 1 hour, the charger had a fault message. I then tried the de-sulfidation setting with no luck and then tried the charger at 6A and got the fault message again. I put it on the battery reconditioning setting overnight and it is now at 5.1 volts but still doesn't seem to want to charge. Is there another way to do this? I might try to jump it off of my explorer and see if the alternator can charge it. Any tips or tricks? The battery is still under warranty but the nearest dealer is 70 miles away.
__________________
2009 Candy-Apple Red Glass-Roof GT |
| Sponsored Links | |
Advertisement |
#2 |
The problem with gel batteries is when you let them completely drain there is no recharging them. You have to replace it.
__________________
Stock Short Block,AFR 165 Heads, 1.7 Rockers,Double Valve Springs,TFS 1 cam, BBK Equal Length Headers, Full Exhaust, TF Street Heat, 70mm BBk TB, 24lbs Injectors, C&L 80mm Mass,Custom SCT Tune, Built C4 Tranny, 4k Stall, 4.10 Gears, Full 5 Lug and a 125 shot of Nitrous |
#3 |
you can recharge a gel cell battery like a optima. you have to use a deep cycle marine charger. been doing it for years now. My optima is 5 years old an still works like it did when it was brand new.
__________________
96 GT- Complete 4v swap, 4.10's 93 GT- Traded 97 F150-PI swapped. |
#4 |
It is starting to show some promise, the charger faulted out again but the voltage is up to 6.2 volts. I've got it running at 6A now and the voltage with a voltmeter and the charger is at 14.5 volts. I'll leave it for an hour or so and test again.
__________________
#5 |
Try the desulfation setting for a few days.I have a battery minder/desulfator and sometimes it takes a couple of days to get the battery recharged so that the desulfator can start.My charger won't desulfate a battery until the charge gets over 13 volts.
Here's a link to the battery minder website that tells how to "save" an optima type battery. http://www.vdcelectronics.com/optima/Optima-type_NL.pdf
__________________
04 GT,94 HD Sportster(heavily modified) 1942 Flathead chopper (74ci) 1960 Cessna 172. BUY AMERICAN!!! http://www.batteryminders.com/batterycharger/home.php Oil Questions.http://www.bobistheoilguy.com/ |
#6 |
Here's a link to the battery minder website that tells how to "save" an optima type battery. http://www.vdcelectronics.com/optima/Optima-type_NL.pdf It takes a couple seconds to come up but it will come up.
__________________
04 GT,94 HD Sportster(heavily modified) 1942 Flathead chopper (74ci) 1960 Cessna 172. BUY AMERICAN!!! http://www.batteryminders.com/batterycharger/home.php Oil Questions.http://www.bobistheoilguy.com/ Last edited by chopper1; 03-02-2008 at 06:38 PM. |
#8 | |
#9 | |
#10 |
Battery is back to life. It took a couple days on the desulfate setting. I had to jump it off of my explorer for 10 minutes then ran the trickle charger over night. It is now holding a steady 12.4 volts.
Thanks guys!
__________________
#14 | |
By the way, it's never a good idea to charge a dead battery with the alternator. It will work. But, it'll shorten the life of the alternator.
__________________
'85 GT T-top World Products block, Eagle 4340 crank, Scat H-beam rods, JE pistons 331 cid, Trick Flow 170 heads, cam & intake, P1SC 15lbs Frame up restoration |
#15 |
I use a 750ma battery tender. It takes like two weeks from DEAD but it will bring it back if it will come back. My daughter is bad about leaving lights on at school so I do this all the time. Have two spares to rotate out it's so bad.
Sent from my DROID RAZR using Tapatalk 2
__________________
92 LX 351 T5--89 GT 347 T5--91 LX 5.0 AOD 88 LX 302 T5--93 LX 2.3 A4LD |
#16 |
If more people like 85gtFoureyedFox and racerxmdd posted good information about batteries, I'd probably spend my days pinning new photos on our Pinterest boards. These guys are both absolutely correct in what they've posted (we actually have an updated parallel charging video) Tech Tips 3: How do I recover a deeply-discharged battery? - YouTube
Whenever any battery is discharged below 12.4 volts and left sitting in that state, sulfation begins to form in the battery, which diminishes both capacity and lifespan. That makes a quality battery maintenance device an excellent investment for any vehicle that doesn't see regular use. When any battery (Optima or any other brand) is deeply-discharged below about 10.5 volts, many traditional analog chargers will not recognize or charge the battery, while others will begin charging but shut off if the battery doesn't reach a minimum voltage level within the first few minutes. Whenever any battery is discharged to the point that it needs to be jump-started, it should be fully-charged with a battery charger as soon as possible. Most alternators are designed to maintain batteries, not recharge deeply-discharged batteries. Asking that task of an alternator can lead to a cycle of dead batteries and jump-starts, until either the battery or alternator fails. If anyone has any questions about our products, I'll do my best to answer them. Jim McIlvaine eCare Manager, OPTIMA Batteries, Inc. OPTIMAŽ Batteries (optimabatteries) on Pinterest |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
