93' Cobra EFI swap - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 05-10-2017, 06:56 AM Thread Starter
93' 5.0 EFI swap
93 Cobra upper
Explorer GT-40/FRPP lower intake
Factory Ford 24 lb injectors with factory fuel rail and regulator
70mm BBK throttle body
BBK cold air intake
X3Z EEC computer
Complete engine wiring harness that includes all factory sensors and vacuum lines.
Factory distributor with Ford Racing plug wires/MSD Cap
Not pictured but also included is all the bolting for intake, front cover for EFI (no fuel pump boss)
This all ran great on a stick bottom end with an E303 cam
This is a complete swap kit for a SBF the only thing you'll need is a fuel pump,lines, and wire it up.
Asking $800 obo.
The only trade considered would be a complete carb swap setup for a 302, including intake (4 barrel ,dual plane ,aluminum Edelbrock),front cover, MSD Distributor, carb
(Holley or Quick Fuel 650 mechanical secondary/double pumper),fuel log, and mechanical pump.
Will consider shipping but will be pricey and extra cost!
Located in Morrison,IL 61270
Call or text Jesse
825-499-2204
Last edited by tpndrcn1; 05-19-2017 at 03:07 PM. Reason: Change the lower intake to more accurate description
tpndrcn1 is offline
post #2 of 16 Old 05-10-2017, 10:33 AM
Would you consider selling the harness separately?
lotzatoys is offline
post #3 of 16 Old 05-11-2017, 10:23 AM Thread Starter
lotzatoys not at the moment but i will keep you in mind. Thank you
Jesse
70 1/2 Falcon 5.0 FI swap!
tpndrcn1 is offline
post #4 of 16 Old 05-11-2017, 09:09 PM
Trader Feedback: (204)
All of the componets appear to be "aftermarket". Are they?
How about adding some Part Numbers? I'm a buyer if the Upper & Lower are Original 1993 Cobra Parts!
Jon
89 Vert. 5.0 5Sp. Burgandy, Black Top, Black Interior. SOLD
92 GT Vert. 5.0 AOD White, Black Top, Black Interior.
92 Coupe. 4 Banger 5 Speed. White, Black Interior.
93 Coupe. DECIDING Calypso Green, Black Interior.
94 GT Convertible 5.0 5 Sp. Red Black/Gray Interior.
95 GT Coupe 5.0 5 Sp. Red, Black Interior.
Jon Evenoff is offline
post #5 of 16 Old 05-12-2017, 08:55 PM Thread Starter
Jon Evenoff the only aftermarket parts are the throttle body and the Cold air intake. Here are the part numbers:
Upper-RF-F3ZE-9425-CB
Lower-RF-F87E-9K461-BA
Injectors-F1TE-D5A
Harness-F2ZB-12A581-AB/P260H
MAF-F1SF-12B579-AA/AFH70-02
EEC-F3ZF-12A650-CA
tpndrcn1 is offline
post #6 of 16 Old 05-12-2017, 09:05 PM Thread Starter
Upper,lower,injectors
tpndrcn1 is offline
post #7 of 16 Old 05-12-2017, 09:07 PM Thread Starter
MAF,EEC,Harness
tpndrcn1 is offline
post #8 of 16 Old 05-12-2017, 09:10 PM Thread Starter
Bump! Price update to $900 obo for all!
tpndrcn1 is offline
post #9 of 16 Old 05-14-2017, 10:02 AM Thread Starter
Bump! Lowered price again, must sell!$800 obo
tpndrcn1 is offline
post #10 of 16 Old 05-16-2017, 07:52 AM Thread Starter
Bump!
Jesse
tpndrcn1 is offline
post #11 of 16 Old 05-16-2017, 04:04 PM
I'm interested in your ecu. Let me know if you part out
Stang_banger1 is offline
post #12 of 16 Old 05-16-2017, 06:49 PM Thread Starter
Stang_banger1 I'll let you know if I part it out
tpndrcn1 is offline
post #13 of 16 Old 05-18-2017, 10:04 PM
I'd buy it all in a heartbeat if it were truely all "Original 1993 COBRA" Parts (with the exceptions as noted) but, the Part Numbers provided do not match those of an "actual 1993 Cobra".
Sorry, but you can fool some of the people some of the time, but a True Mustang Enthusiast (such as myself) is a Tough Nut to Crack"!
Don't get me wrong, there are a few parts that are from a 1993 Cobra (listed such as the Computer) but then, check the Part Number of the "Lower-RF-F87E-9K461-BA" Intake Manifold. How can a 1993 Car have a 1998 Part number on it? The CORRECT Part number for the Lower Intake Manifold is F3ZZ-9424-D.
ETC!
Jon
post #14 of 16 Old 05-19-2017, 01:06 PM Thread Starter
Jon I am not trying to fool anyone, sorry. I had another member on here say the same thing and I did some more research. I will agree the lower is either a Ford Explorer lower or an FRPP intake. However, the car I took this out of was a 93 Cobra, and I have the engine and "z" spec trans too. At the time I took the motor out someone had replaced the GT-40 heads with E-7 heads
with 1.72 Ford Racing roller rockers, so maybe they took the true intake at that time. I definitely am not trying to undermine or pull a fast one on anyone. Regardless it's a great lower intake and if someone wants a working combo to go EFI minus a true lower then they are welcome to it. Again sorry not trying to be dishonest
tpndrcn1 is offline
post #15 of 16 Old 05-19-2017, 03:08 PM Thread Starter
BUMP! Edited 1st post to correct description for the lower intake, its not a factory 93' its either an Explorer GT-40 or FRPP kit lower. I don't want anyone misguided and thinking I am trying to rip them off.
Jesse
tpndrcn1 is offline
post #16 of 16 Old 05-20-2017, 11:02 AM Thread Starter
Everything is sold thank you all for the interest
tpndrcn1 is offline
