C CHARMER054 442 posts · Joined 2008 Add to quote Only show this user #2 · Apr 28, 2017 Pm sent Sent from my SM-G920V using Tapatalk
KEVIN$ Discussion starter 5123 posts · Joined 2001 Add to quote Only show this user #3 · Apr 28, 2017 More Specs: Siemens Deka 80lb High Impedance Fuel Injector EV1 Part # 110324 830 cc/min, 80 lbs/hr, Siemens Mototron Deka IV Fuel Injectors Body Design: Pencil, composite plastic Injector type: standard long, saturated Spray nozzle: Single disc Flow rate: 3 BAR/43.5 PSI 830 cc/min 80 lbs/hr 9.89 g/sec Coil Resistance: 14 Ohms (high-impedance) Sample Latency: 0.714 ms at 14 volts No clue on how many miles but should be less than 10K miles. I bought the car with these in it and the car had a fresh engine build. O-rings are perfect, no issues. I just swapped them out Wednesday to install 160's for E85. ks
1 10_sec_98_cobra 25 posts · Joined 2016 Add to quote Only show this user #4 · Apr 29, 2017 Has e-85 been ran through those injectors?
KEVIN$ Discussion starter 5123 posts · Joined 2001 Add to quote Only show this user #5 · Apr 29, 2017 Nope.
M Montana88 21 posts · Joined 2013 Add to quote Only show this user #6 · Apr 30, 2017 I'll take them. PM me your paypal info.
KEVIN$ Discussion starter 5123 posts · Joined 2001 Add to quote Only show this user #7 · Apr 30, 2017 PM Sent...sale pending. ks
KEVIN$ Discussion starter 5123 posts · Joined 2001 Add to quote Only show this user #8 · Apr 30, 2017 Sold. ks
