Billet Bypass Regulator - Designed for use with an electric fuel pump where fuel pressure is steadily delivered. By-Pass feature is unrestricted and anodized top has a fitting for boost referenced applications. Comes with laser cut stainless mounting bracket and hardware. #8 AN O-Ring fittings required.
Designed to operate within 4.5 - 9 PSI; Preset at 7 PSI
.350" (7/20") restriction
Can be used with gas, alcohol and E85 fuels
Compatible with QFT? billet fuel pressure regulator logs, part number 30-1900, brand new in the wrapper $85 shipped paypal
