try going here to verify, if they work with a C4, site says you need to remover the dipstick to install, so tha t ooks like a yes.
Drag race headers
#401 Specs
These race quality headers have less than 3" of variation in primary tube lengths which is most critical from 4000 to 5500 rpm.
•Specify 8.2, 9.2 or 9.5 block when ordering.
•Specify primary length when ordering (30" to 33.5").
•Prices shown are with removable collectors, add $145 for fixed collectors.
•Designed to fit all Windsor blocks with 289, 302, and GT40 standard cast iron heads and most aftermarket heads such as: Trickflow Wilbert hi-port, Trickflow R, Dart, World Products, Edlebrock street, Edelbrock Race Victor, Canfield, Brodix standard, Brodix N351
•Transmissions:
C-4 & C6 will require moving the transmission dip stick or using a "flex" dip stick.
AOD require hack sawing interfering "ears" which can be done in the car.
Power glide requires major modification to the adapter plate.
•Lakewood Shield will require trimming the flange at several points.
•Power brakes ok on all sizes except 2" where power brake booster must be moved.
