2004 mustang wont start - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 06-11-2017, 03:41 PM Thread Starter
Unhappy 2004 mustang wont start
2004 v6 wont start after removing dash and replacing it no fuel and cooling fan comming on dash guages acting crazy
chipnick is offline
post #2 of 23 Old 06-11-2017, 11:11 PM
indy2000's Avatar
you got the wrong dash
pats??
put a scan toll on and see uf there is comm to dash module
indy2000 is offline
post #3 of 23 Old 06-12-2017, 09:31 AM
Steve03's Avatar
Trader Feedback: (32)
Sounds like the PATS fighting you
Steve
`03 GT
Steve03 is offline
post #4 of 23 Old 06-12-2017, 08:10 PM Thread Starter
same dash
chipnick is offline
post #5 of 23 Old 06-12-2017, 08:12 PM Thread Starter
theft light is blinking cant get it to reset i pulled dash to replace ac evap
chipnick is offline
post #6 of 23 Old 06-12-2017, 10:15 PM
indy2000's Avatar
then you have a bad connection
put a scan tool on it
if you don't have one, take it to someone that does
indy2000 is offline
post #7 of 23 Old 06-13-2017, 09:04 PM Thread Starter
got codes says d262 missing scp message 9681 pats signal not recieved
chipnick is offline
post #8 of 23 Old 06-13-2017, 09:32 PM
indy2000's Avatar
there you have it
indy2000 is offline
post #9 of 23 Old 06-13-2017, 10:04 PM Thread Starter
what to do next ????????? this bites
chipnick is offline
post #10 of 23 Old 06-13-2017, 10:48 PM
indy2000's Avatar
besides double checking wiring
a proper scan tool and lab scope is necessary to see the signal or lack there of
maybe you fried a module
who knows
without proper tools everything is just guess work.
indy2000 is offline
post #11 of 23 Old 06-17-2017, 11:35 AM Thread Starter
update found broke wire at pats trans sponder fix it but still the same shorted fuel tank conector think i messed up pcm thats why cooling fan on can i get new pcm flashed to vin or does dealer need to program keys also swaped out ccrm
chipnick is offline
post #12 of 23 Old 06-17-2017, 01:20 PM
indy2000's Avatar
retype in somewhat legible format
or point form
indy2000 is offline
post #13 of 23 Old 06-17-2017, 01:23 PM
indy2000's Avatar
did you rescan after repair?
indy2000 is offline
post #14 of 23 Old 06-17-2017, 04:32 PM Thread Starter
i think pcm bad . shorted at fuel tank pump cooling fan on
chipnick is offline
post #15 of 23 Old 06-17-2017, 08:39 PM
indy2000's Avatar
you think?
wouldn't you rather know?
or just throw parts at?
indy2000 is offline
post #16 of 23 Old 06-18-2017, 11:07 AM Thread Starter
well tell me the steps you would take dont want to go to dealer. ive checked fuses all good . changed ccrm because cooling fan on with key on . and found broke wire at pats transponder conection. got codes at gauge read out
chipnick is offline
post #17 of 23 Old 06-18-2017, 11:10 AM Thread Starter
car was starting before removed dash
chipnick is offline
post #18 of 23 Old 06-18-2017, 12:11 PM
indy2000's Avatar
first step,
is SCAN TOOL
need to KNOW what info is missing on the CAN-BUS ...
if you have a lab scope, and KNOW what the signal, digital pulses, are needed then you could try that difficult route.
indy2000 is offline
post #19 of 23 Old 06-18-2017, 12:19 PM
indy2000's Avatar
you have any questions about my profile page after visiting it?
indy2000 is offline
post #20 of 23 Old 06-18-2017, 01:07 PM Thread Starter
i dont doubt your wisdom im a simple guy trying to get simple answers .scan tool meaning obd tester???
chipnick is offline
post #21 of 23 Old 06-18-2017, 03:32 PM
indy2000's Avatar
no
a scan tool
indy2000 is offline
post #22 of 23 Old 06-18-2017, 04:16 PM Thread Starter
what kind???????? analprobe
chipnick is offline
post #23 of 23 Old 06-18-2017, 06:01 PM
indy2000's Avatar
yeah
indy2000 is offline
