injector wiring problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-20-2013, 12:38 PM Thread Starter
I could nt find anything on this problem. I'm having an issue with both of my wires going to my injectors have power constantly need some info on causes
no_tread_left_91gt is offline
post #2 of 11 Old 05-20-2013, 01:29 PM
Madspeed's Avatar
what have you changed that caused this? Need more info
Shameless plug.... My Business
Use coupon code MADSPEED for a 20% discount!!
Madspeed is offline
post #3 of 11 Old 05-20-2013, 01:44 PM Thread Starter
when I hook up the light blue orange wire to my fuel pump relay it causes the wiring to the injectors to both have 12 volts of power
post #4 of 11 Old 05-21-2013, 12:50 AM
Why are you hooking a light blue/orange to the fuel pump relay?
After scanning an 88-91 EEC wiring diagram, there is not a Light Blue w/Orange stripe coded wire. Now, your number eight injector uses a Light Blue wire to command ground from pin 52 of the ECU. Each injector should have a constant VPWR 12v (Red) and a colored command ground wire from ECU.
Fuel pump relay has the same VPWR 12v (Red) from EEC Power Relay, Tan w/Lt Green from pin 22 as the fuel pump ground trigger for the relay, Black w/Orange battery ground and then the Pink w/Black which feeds power to the fuel pump AND sends a signal to the ECU pin 19.
kbscobravert is online now
post #5 of 11 Old 05-21-2013, 12:19 PM Thread Starter
The wire is definitely lightblue and striped either red or orange buy regardless that was the issue now everything is good to go it had fixed the no power and the relay to shut off the pump thanks for the input though who knows what year this harness is they could have hacked this up a long time ago
post #6 of 11 Old 05-23-2013, 12:33 AM Thread Starter
injectors wires
also both wires to your injectors should have power while in the run position when turning the engine over the nonred wire gets grounded to complete the circuit im more of a carb guy so this was confusing to me to begin with
post #7 of 11 Old 05-23-2013, 02:06 AM
No. Both wires do not get power. Your injector is a 2 wire (one positive and one ground) The ground circuit is completed in the ECU not the injector. Therefore the non-red wire or the signal wire should never have power, never. The injector gound wire is a ground signal output for the ECU.
post #8 of 11 Old 05-29-2013, 10:04 PM Thread Starter
injector wires
That's not what my test light tells me ..........when I turn the key forward and I put the test light in the red wire on my inj it shows power 12v then I test the other wire right next to the red one and my test light also lights up again........when I put my cm on the second wire and turn the car over it drops to 8v ish do I have the only car that runs this way?
post #9 of 11 Old 05-29-2013, 10:05 PM Thread Starter
Volt meter is what I mean when my fingers put cm
post #10 of 11 Old 05-30-2013, 01:39 AM
I find it hard to believe that you can read a signal from the PCM fast enough with a Voltmeter and not a scope.
Are you telling us that you test the NON-Red leg by placing your voltmeter positive lead in the back connector and ground lead to chasis/battery grnd and you are getting a voltage signal with the key on in run engine running?
Your injector COULD not work with both leads receiving +voltage. That would be AC and your car is DC.
post #11 of 11 Old 08-26-2013, 09:11 AM
keithnra's Avatar
Trader Feedback: (29)
that's correct the non red wire is grounded and when it fires it breaks the grouns
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
85 GT with T-tops yeah its rough!
86 coupe with 4 banger 96 GT vert 86 GT
keithnra is offline
