A9L EEC ? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Engine Management Systems > EEC Tech
Old 05-06-2007, 03:49 PM   #1
yogibear357's Avatar
Trader Feedback: (35)
Question A9L EEC ?
I am thinking of putting a 9AL ECM in my 5.0. Does it really make that much differents? Need input
yogibear357 is offline
Old 05-06-2007, 04:00 PM   #2
INCINR8's Avatar
Its just a stock mustang computer/ECM for a 5.0, 5 speed. Whats your setup now???
__________________
"I know it's not safe up here, that's why they called us! Now cut that hole!"
I did not vote for Obama. Did you vote for obama?94 red gt vert: "Yes i did and glad i did."
"OWS, The lefts Tea Party"
INCINR8 is offline
Old 05-06-2007, 04:13 PM   #3
I have a stock ECM with SCT Chip some body told me 9AL is better I was just wondering what was better about it
Old 05-06-2007, 04:19 PM   #4
INCINR8's Avatar
What ECM do you have now? What year is the car?what type of motor ,trans did your car come with?
__________________
INCINR8 is offline
Old 05-06-2007, 04:20 PM   #5
vristang's Avatar
There are a lot of people who don't fully understand the differences between ecu's, but are more than willing to say that the A9L is the only one that should ever be used.
Was the SCT chip created for your current combo?
What ecu are you currently using?
What are the future goals, and what is your current setup?
There are some minor timing differences between the A9L and A9P, as well as fuel differences.
None of the differences, that I have found, will provide a performance advantage in either computer.
jason
__________________
SeattleBlueOvals.com
1990 GT - something 351w based... some day
1987 LX - n/a 2.3 daily driver, using an EDIS v8 ecu/QH
vristang is offline
Old 05-06-2007, 05:23 PM   #6
jason
I have my chip out at the moment It's SCT 4 band I have to look to see what the number of my ECU . RPM dyno tune my last motor told me he was putting in 9AL but It is not and he does not have my old ECU my set now
347 dart block, 185 AFR, comp 282xe, holley intake, 70 mm throttle body,80mm pro-m, Hi crane 6, stock ecu
Old 05-06-2007, 09:06 PM   #7
vristang's Avatar
Can you please type in complete sentences?
Not trying to be rude, but I am having a hard time keeping up.
As far as I know, there is no such thing as 9AL, so an A9L is most likely being discussed.
So your old setup had a dyno tune.
Now, the combo you have listed is in the car running on the factory ecu?
But you aren't sure what ECU that is, yet?
Either an A9L or A9P will work just fine in your application.
But there are other ecu's that will work just as well.
jason
__________________
vristang is offline
Old 05-06-2007, 09:38 PM   #8
jason
Yes I am running on factory ecu for now. I need to put more miles on my new motor before I have it tune again. I was told that A9L is a better ECU. I still have to check which ECU I have now. Sorry about my retardness writing wasn't my best subjects.
Old 05-06-2007, 09:45 PM   #9
vristang's Avatar
No problem.
Unless someone stuck a 'batch fire' ecu in your car, you won't realize any performance gains by swapping out your ecu.
Most of the MAF / 5.0 ecu's are very similar in calibration.
jason
__________________
vristang is offline
Old 05-10-2007, 06:49 PM   #10
Jason My Ecm numbers are E9AF14A624AA GTE
What is a batch fire
Old 05-11-2007, 01:28 AM   #11
vristang's Avatar
That was an attempt at being funny, but nerds are seldom funny...
Batch fire was used mostly in trucks. All 4 injectors on a bank were fired at the same time. Or maybe it wasn't split by bank? Regardless, the injectors were fired in groups instead of when each intake valve opened.
The only thing I can get out of the number you posted is the year of the part
E9 = 1989
Google may be able to help you match that number to a 'Catch Code'...
The catch code should be on the Ford sticker though...
jason
__________________
vristang is offline
Old 05-11-2007, 01:48 AM   #12
E9 = 1989
jason
these are the only numbers on it 680ECM
ISO-9001:2000
9001 1001
Old 05-12-2007, 11:16 AM   #13
IF anyone can give a little more info would be appreciated I did a search, went to a Ford dealer no luck there either. If not thanks for the help so far
Jeff
Old 05-12-2007, 12:12 PM   #14
TENGRAM's Avatar
IMPORTANT INFO NEEDED!!!
Originally Posted by yogibear357 View Post
Anyone can give a little more info I dad a seach went to a Ford dealer no luck there eirther. If not thanks for the help so far
Jeff
what year/model vehicle are you talking about? are you using the original computer?
__________________
89 GT T5, 3.73, mac 1 5/8 u/l,mac o/r h-pipe.3-chamber flow catback, mac CAI, C&L 73mm, cat pulleys, some weight removed
http://www.my5oh.com/
TENGRAM is offline
Old 05-12-2007, 12:28 PM   #15
1988 mustang 5speed LX 5.0. with Mass air
This guy that dyno tune my car said he put in a A9L it's not. Here is what I come up with for numbers on my new computer
680 ECM
ISO-9001:2000
9001 1001
E9AF 14A624 AA
GTE
Old 05-12-2007, 05:00 PM   #16
680 ECM
ISO-9001:2000
9001 1001
E9AF 14A624 AA
GTE
I found out what computor I have. It is a 1990 F-350 Ford dump 5spd 460 eng EFI one ton.
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
