How light is your stang? - Page 16 - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 10-16-2011, 04:00 PM   #526
tripleblackvert's Avatar
Trader Feedback: (66)
mine is down to 2810 with me(180) and a little over 3/4 tank of gas, so 2630 without driver..set of aluminum heads would get me well under 2600 lol
__________________
1987 Notch - N/A stock 302, TFS heads, Holley Systemax, FTI cam, Astro A5
Best so far: 10.92 @ 123mph with a 1.49 60ft
tripleblackvert is offline
Old 10-17-2011, 02:43 AM   #527
302army187's Avatar
dang, how are you guys dropping another 200lbs?
I estimate i could get to 2900 pretty easy with gutting the interior, and a few other odds and ends. Just cant decide if I really wanna pull the trigger on a gutted interior....
what else is there............ thats not expensive as all get out.....
__________________
'89 LX 'Vert; 302, H/C/I,V2 SQ Si-Trim 3.15upper, 8" lower, 4.10's, Cobra T5, some suspension mods, ETC, ETC
dyno/track times coming soon
http://www.youtube.com/user/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
302army187 is offline
Old 11-05-2011, 09:13 PM   #528
Originally Posted by 347notch View Post
i was looking to make my own aluminum door panels. any pics or pointers?
there is a guy on the bullet who sells carbon fiber door panels for a fair price. im wanting to say he said they weighed 1lbs
__________________
87 Notch
carbed fox on a diet in the works......someday
90 hatch
5lug small diet and a little suspension turbo 4cyl
Jasperstang308 is offline
Old 12-15-2011, 10:43 PM   #529
badbrad's Avatar
Trader Feedback: (32)
well, i added an al. rear bumper from a 79 from the jy, did a little "swiss cheezin" lol..after swapping out the fac. steel unit I saved 21lbs!!! the al., after i modded it, weighed 10.6lbs. the original steel one weighed 31.9lbs. I have an 89 vert. gotta get it weighed soon.
__________________
89 lx vert stock block/bore, tw 170's, xe266 comp cam
performer intake, 70mm tb, 76mm meter. 3:55's
constant work-in-progress
badbrad is offline
Old 12-16-2011, 08:09 PM   #530
302army187's Avatar
good info for me to have since my 'vert is a 89
__________________
Old 12-16-2011, 08:17 PM   #531
badbrad's Avatar
mine was from a 4cyl car. 79 was the yr. remember to carry a magnet with you. I pd $16 at a upullit jy. i will replace my front bumper setup with a bar, supposed to save 21lbs. Gonna go back to the jy and get the 4cyl. swaybar. Should save another 11 or 12lbs and still help handling. I am not corner carving here, justa dd. I have been following your youtube channel---lol, just seeing what info i can stumble on..
__________________
badbrad is offline
Old 12-16-2011, 08:23 PM   #532
302army187's Avatar
I've thought about the 4cyl swaybar, but my car already gets very light in the corners, and the front end starts bobbing around. So I haven't really felt right about that just yet. Maybe after a tubular k member.
thank's for following my channel! What do you mean by info you can stumble on?
__________________
Old 12-16-2011, 08:28 PM   #533
badbrad's Avatar
Just by reading,watching what other people have done to see what works and what doesn't. What does yours weigh? The only lightening i've done is al heads and the rear bumper so far---i installed a 4pt cage so that offsets the al heads(did the 4pt just for piece of mind)
__________________
badbrad is offline
Old 12-16-2011, 08:55 PM   #534
302army187's Avatar
I was 3060 last time on the scale. Ive removed and added a few things since then. I think im around 3090 now with 1/4 tank
__________________
Old 12-17-2011, 10:59 PM   #535
badbrad's Avatar
lost a few more lbs today: remove front sway bar , 24lbs..(will install a 4cyl setup next weekend if necessarry). took 8lbs out of stock hood. removed 6lbs from rear decklid luggage rack(i want the "clean" look anyway). A total of 60lbs in 2 days. Next, drop off al. driveshaft to be cut for the mustang: seats, trimming out decklid., and buying the front bumper bar(saves 21lbs). not much more. I may make a thread of MY progress. Gotta get it weighed to be accurate too.
__________________
badbrad is offline
Old 12-30-2011, 08:22 PM   #536
jds95's Avatar
3285 with the windsor and me in it.
__________________
86' GT, 414 windsor w/ Procomp heads.World Products dominator intake. Jerico DR4 w/Long vertigate shifter, Boninfante 10.5in clutch. Mini Tubbed. classicgearjammers.org
jds95 is offline
Old 01-06-2012, 12:39 AM   #537
whats the stock weight of a coupe with no power options (pw ect)?
Silver LX is offline
Old 02-06-2012, 05:31 PM   #538
yrtneg24's Avatar
Trader Feedback: (25)
'91 LX sunroof hatch, chrome pony's, all options 1/2 tank of gas 3,080 w/o me
-al. driveshaft
-no smog equip.
yrtneg24 is offline
Old 02-06-2012, 08:54 PM   #539
blownholley50's Avatar
My lx hatch is heavy. It weighs 3094 and 3300 w me in it. It has to weigh 3200 for my local class anyhow. It had 6/7 gallons of fuel. Full factory interior with full factory carpet. Mild steel 12 point cage. Dart block. Alum heads. Ati super glide. 3.5" chromly driveshaft. Tubular frnt end. Frnt n rear coil overs. Full baseline rear suspension. Glenns sumped tank. 16v battery. Mild steel wild rides rear bumper support/chute mount. Cm tubular frnt bumper support. Champion frt wheels w strange brakes. Weld rears w drum brakes. Holley intake w ysi blower(no intercooler). Pulled all factor wiring out and re wired in racecar form. 4" motorcity solutions hood. Etc. etc. heavy pig!!!!
__________________
WestTexasMeanStreet-5.53/1.27/126.4@3700'DA 5.58@5275' https://www.facebook.com/groups/WTMS275/
93 LX Hatch 275DR ,YSI, 363, Freezy, XFI, Baseline
Harlow Sammons,Southwest Perf. & Machine,
http://www.youtube.com/user/blownholley50?feature=mhee
blownholley50 is offline
Old 02-06-2012, 09:09 PM   #540
My stock block turbo car weighs 2900 with me in it at 180lbs. This is with a mild steel kit. Front mounted a/a intercooler, meth injection and full mild steel exhaust with tailpipes out the back. Still has power windows and stereo in it but engine harness was cleaned up, door bars and seat belt braces in the quarters removed. Also has boxed through the floor subframes and mild steel cage
mayer5oh is offline
Old 02-06-2012, 09:17 PM   #541
How the he'll do you move the engine back 2" and down 2"? I barely have room as it is to get to any bolts for the bellhousing
mayer5oh is offline
Old 04-10-2012, 07:08 PM   #542
I've got mine down to 2630 lbs with me in the seat. With 5 gall of fuel and two full bottles.
__________________
-337 ci 10.5comp, fogger,out/box afr185s,supervic
-tko600 9.05@141 1.35 60ft
-clutchless 8.56@157 1.32 60ft best 1.22
Hauling ass with small stuff on a 26x10 tire
337stroker is online now
Old 04-14-2012, 11:27 PM   #543
pillowofwinds's Avatar
Weighed the notch the other day for the first time since aluminum heads and a few other items that 'fell off'.
Surprised me! I would a guessed more like 2900.
Sent from my Galaxy Nexus using Tapatalk 2
__________________
90 lx coupe - bolt ons, 3.73s
11.82@116 NA stock bottom end
pillowofwinds is offline
Old 04-23-2012, 02:36 AM   #544
My 99 cobra last time i weighed it was before i started my carb swap was at 2785 race weight.
Since then a whole lot came out and a few things went in so well see what im at now. Not bad for a new edge.
99Mystic is offline
Old 04-29-2012, 09:06 PM   #545
king cobra 2003's Avatar
Just weighed my 95 coupe turbo car a/w intercooler.
2718 w/o driver
__________________
95 gt.... Bolt ons, weight reduction, slicks, 150 shot
2795lbs w/ driver.... 1.44 60' 11.29 @ 120mph.
New setup: 347ci SBF/88mm turbo/Powerglide
8.18 @ 172mph... W/ only a 1.34 60'
king cobra 2003 is offline
Old 04-29-2012, 11:22 PM   #546
nick5oh's Avatar
Mark that's feather weight! List the weight reduction mods please....
__________________
302ci,svo j302,victor jr intake,demon 650,HR cam,T5,4.10,26X10S,2785lbs
11.56@118+MPH.....1.49 60' ALL MOTOR!!!
10.70@124+MPH.....70HP plate,c4,28X9@2850lbs
PSP Race Team.....1320 CREW
nick5oh is offline
Old 04-29-2012, 11:33 PM   #547
nick5oh's Avatar
I was 2850 me in it....50 lbs for both front seats as opposed to the 43 lb each stock seats....no heater core or hvac box....ac deleted...ps deleted....full smog deleted....no front sway bar...tube k and a arms....coil overs....no floor tar...50 Resto non mass back carpet (saved 15lbs)....no rear seats or hatch area carpet....no spare or jack...no radio or speakers.....10 gal fuel cell.....aluminum heads....aluminum carb.....drag lites....slicks....skinnies....
Still have steel bumpers front and rear....door bars....all steel body....power windows....locks....hatch and fuel door....all glass no lexan....all stock brakes....no lightweight engine internals or chassis parts other than what I listed... So basically I have a lot of weight I could remove just no $ to remove it lol
__________________
nick5oh is offline
Old 05-01-2012, 11:00 PM   #548
2718 w/o driver
In your signature it states that your at 2795 raceweight. 2718 just car. That is some diet your on.
__________________
99 Cobra Stock Long Block
N/A Sullivan AED 650 Carb
EFI-11.62@113
Carb- 11.34 @ 116.98
99Mystic is offline
Old 05-02-2012, 06:27 PM   #549
That was the stock motor and nitrous setup. Weighed 2795 with me. Now it weighs 2930 with me.
__________________
Old 05-09-2012, 12:16 PM   #550
Mine is around 2300LBS..........
ETracer is offline
Old 05-09-2012, 09:48 PM   #551
coastalref's Avatar
2680 with no driver no ballast
3050 race weight
Iron heads, stock k member, stock control arms
__________________
Matt
NMRA Factory Stock #8
Thanks to: Ed Curtis @ FTI; Larry's Auto Machine; DeCordre Automotive and Performance
coastalref is offline
Old 05-12-2012, 05:47 PM   #552
ssomustang50's Avatar
Trader Feedback: (39)
stock 93 notchback,smog delete kit still has all the stuff uninstalled for the smog.has ac,17" cobra rims,stock interior & everything else,AOD
3180 without me
3360 with me
thought it would be lighter,guess its time to diet
__________________
1993 Reef Blue Notchback,Stock with GT40 Tubular intake, 70mm TB,AOD Tranny,3.73's,Full Flow Master Exhaust.
ssomustang50 is offline
Old 05-13-2012, 09:12 PM   #553
3180 without me
3360 with me
u guys think this scale is right? My title says 3010. I just thought this would weigh less than it does,even stock. I weighed my 90 GT w/HCI, alum rad,alum driveshaft,no ac,no spare tire,no front sway bar,summit pro star wheels,skinnies up front & it weighed 3250 w/me (not same scale)
__________________
Old 05-14-2012, 09:20 AM   #554
2962 lbs with a 1/2 tank of gas and me in it. 56% front, 44% rear.
__________________
1993 LX Coupe, Vortech V-2 SQ, TKO600, Aluminum heads, 90mm SCT MAF, 3.55 gears, B- Cam, Stock block 302, 450 RWHP
Havranasty is offline
Old 05-28-2012, 01:24 PM   #555
stihl-066's Avatar
2460 without me and my racing suit. 2705 race weight
__________________
1982 GT,408w 12.8.1 comp AFR225's SV intake Pro System950 custom CI Cam 3.73's,1 7/8 kooks UCC 5500 stall 8.8 33 spline spooled full cage. MSD 6AL. strange adj.front struts strange rear shocks baseline suspension.6.05 113 mph 1.35 60ft. 9.58 139.98mph.
stihl-066 is offline
Old 06-15-2012, 02:47 PM   #556
This thread is awesome.... I weighed my 93' Cobra a few months ago and almost fell over. With only reductions being afr heads, and alum driveshaft it came in at 3465 with me in it (200lbs) + 1/4 tank of gas. By far the heaviest fox I've ever owned! Car has dynamat on the doors but that's about all I can think of as far as added weight. Since I refuse to cut up the car I'll be buying another fox in the near future and the weight reduction will start that same day. LOL..
SLO-SVT is offline
Old 07-09-2012, 11:59 AM   #557
88 Coupe, 25.5 Chrome moly cage, BB, glide, fabbed 9, ladder bars, wheelie bars, fire bottle, two nitrous bottles, duel battiers, duel seats, only fiberglass is hood and front nose, tags and insurance, chute, roll up windows, working head light and tail light including back up lights, wing, 3 kits race ready with weight 2,710 pounds after pass.. Now if they will just lower our min. weight some more!!!!
spray power is offline
Old 07-11-2012, 06:13 PM   #558
Now thats impressive! What class are you racing?
__________________
Old 07-11-2012, 09:14 PM   #559
We run true 10.5" classes here in Arkansas and King of the Street @ Mokan Raceway in MO. Don't get to run the car alot, but have been 1.10-60 ft., 3.10- 330ft, 4.78- 1/8 @ 150 on a single fogger with a .026" jet. Starting to work on the secound kit, with a .026" in it. Will see what we can do with it soon.... Thanks
Old 07-11-2012, 10:18 PM   #560
Papa Cosmos's Avatar
My 88 lx vert was down to 3138 last I had it on a scale. I want to see what it is down to after I switch the iron heads for the TW alum ones I have , and lose a few more things it no longer needs.
Sent from my SGH-T999 using Tapatalk 2
Papa Cosmos is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
